Banana Pi BPI-F3 is a industrial grade RISC-V development board, it design with SpacemiT K1 8 core RISC-V chip, CPU integrates 2.0 TOPs AI computing power. 4G DDR and 16G eMMC onboard.2x GbE Ethernet prot, 4x USB 3.0 and PCIe for M.2 interface, support HDMI and Dual MIPI-CSI Camera.
SpacemiT K1 is an octa-core 64-bit RISC-V AI CPU. Base on RISC-V open instruction set architecture,we are committed to create more energy efficient and more commonly used AI processor platform,promote global open source and open ecological computing power construction.
SpacemiT K1 is mainly used for single board computer,network storage,cloud computer,smart robort,industrial control,edge computer,etc.
Single-core general computing power equivalent to 1.3 times Cortex-A55
Supports 32-bit LPDDR4/4X, with a maximum of 16GB of memory
4K decoding and encoding
5-lane PCIE2.1 expansion capability
1x USB 3.0 + 2x USB 2.0 interfaces
12x UART serial ports
Operating temperature range: -40°C to 85°C
NAS
Laptop
Intelligent robotics
Industrial control
AI edge computing
HardWare Specification of Banana Pi BPI-F3 RISC-V SBC | |
CPU |
SpacemiT K1 8 core RISC-V chip |
AI |
2.0Tops from RlSC-V Core |
Memory |
4 GB LPDDR4 (Supports up to 8G LPDDR4) |
Storage |
16G eMMC flash.optional 4M SPI NOR,32M SPI NAND |
SD card |
MicroSD card slot (Greater than 256MB) |
Wireless |
2.4G/5G WiFi and Bluetooth 4.2 |
Ethernet |
2x GbE Ethernet port(supports PoE with add-on PoE HAT) |
HDMI |
1x full-size HDMI digital Audio output(HDMI1.4,up to 1080p@60fps ) |
Audio |
Speaker,Mic, Earphone |
Camera |
MIPI-CSI, Dual-shot support |
USB |
4x USB 3.0 Type-A HOST, 1x USB 2.0 Type-C OTG |
PCIe |
PCIE2.1 2lane * 2. |
GPIO |
26-pin header |
Buttons |
Reset, Power and Burn |
IR |
IR-Rx |
LED |
Power Status |
Power |
DC in and TYPE-C in |
Size |
148x100 mm |
Weight |
200g |
PIN | Function | Function | PIN |
1 |
VCC3V3_SYS |
VCC5V0_OUT |
2 |
3 |
AP_I2C4_SDA_3V3 |
VCC5V0_OUT |
4 |
5 |
AP_I2C4_SCL_3V3 |
GND |
6 |
7 |
GPIO_70_3V3 |
R_UART0_TXD_3V3 |
8 |
9 |
GND |
R_UART0_RXD_3V3 |
10 |
11 |
GPIO_71_3V3 |
GPIO_74_3V3 |
12 |
13 |
GPIO_72_3V3 |
GND |
14 |
15 |
GPIO_73_3V3 |
GPIO_91_3V3 |
16 |
17 |
VCC3V3_SYS |
GPIO_92_3V3 |
18 |
19 |
SPI3_MOSI_3V3 |
GND |
20 |
21 |
SPI3_MISO_3V3 |
GPIO_49_3V3 |
22 |
23 |
SPI3_SCLK_3V3 |
SPI3_CS_3V3 |
24 |
25 |
GND |
GPIO_50_3V3 |
2 |
Holding a 1080P screen (JL-M101N013-P12WU-M402632), the screen socket model is FH35C-31S-0.3SHW (50)
1 |
MIPI_DSI1_LANE0_DN |
MIPI_DSI1_LANE0_DP |
2 |
3 |
GND |
MIPI_DSI1_LANE1_DN |
4 |
5 |
MIPI_DSI1_LANE1_DP |
GND |
6 |
7 |
MIPI_DSI1_CLK_N |
MIPI_DSI1_CLK_P |
8 |
9 |
GND |
MIPI_DSI1_LANE2_DN |
10 |
11 |
MIPI_DSI1_LANE2_DP |
GND |
12 |
13 |
MIPI_DSI1_LANE3_DN |
MIPI_DSI1_LANE3_DP |
14 |
15 |
GND |
MIPI_LCD_ADC_1V8 |
16 |
17 |
LCD_PWR_EN_1V8 |
LCD_RST_1V8 |
18 |
19 |
LCD_BL_EN_1V8 |
LCD_BL_PWM_1V8 |
20 |
21 |
GND |
TP_INT_1V8 |
22 |
23 |
TP_RST_1V8 |
AP_I2C6_SCL |
24 |
25 |
AP_I2C6_SDA |
LCD_VCC18 |
26 |
27 |
GND |
GND |
28 |
29 |
LCD_VCC5V0 |
LCD_VCC5V0 |
30 |
31 |
LCD_VCC5V0 |
By default, it supports a 16M camera module, which can be modified After blocking the configuration, hold the 8M camera module and adopt a uniform spacing 0.4mm 30 pin socket (model QG1330421Y-M08-7H).
16M camera:
1 |
GND |
GND |
2 |
3 |
GND |
FS_DUALCAM |
4 |
5 |
CAM_MCLK0 |
GND |
6 |
7 |
GND |
CAMERA0_RST |
8 |
9 |
MIPI_CSI1_DN0 |
CAMERA0_PDN |
10 |
11 |
MIPI_CSI1_DP0 |
CAM_I2C0_SDA |
12 |
13 |
GND |
CAM_I2C0_SCL |
14 |
15 |
MIPI_CSI1_CLKN |
CSI_DVDD12 |
16 |
17 |
MIPI_CSI1_CLKP |
CSI_VCCIO18 |
18 |
19 |
GND |
GND |
20 |
21 |
MIPI_CSI1_DN1 |
CSI_AVDD28 |
22 |
23 |
MIPI_CSI1_DP1 |
CSI_AFVCC28 |
24 |
25 |
GND |
GND |
26 |
27 |
MIPI_CSI1_DN2 |
MIPI_CSI1_DP3 |
28 |
29 |
MIPI_CSI1_DP2 |
MIPI_CSI1_DN3 |
30 |
8M camera:
1 |
MIPI_CSI3_DP3 |
CAM_MCLK1 |
2 |
3 |
MIPI_CSI3_DN3 |
CAMERA1_RST |
4 |
5 |
GND |
CAMERA1_PDN |
6 |
7 |
MIPI_CSI3_DP2 |
GND |
8 |
9 |
MIPI_CSI3_DN2 |
CAM_I2C1_SDA |
10 |
11 |
GND |
CAM_I2C1_SCL |
12 |
13 |
MIPI_CSI3_DP1 |
GND |
14 |
15 |
MIPI_CSI3_DN1 |
CSI_VCCIO18 |
16 |
17 |
GND |
CSI_AVDD28 |
18 |
19 |
MIPI_CSI3_CLKP |
CSI_AFVCC28 |
20 |
21 |
MIPI_CSI3_CLKN |
CSI_DVDD12 |
22 |
23 |
GND |
FLASH_LED0+ |
24 |
25 |
MIPI_CSI3_DP0 |
FLASH_LED1+ |
26 |
27 |
MIPI_CSI3_DN0 |
GND |
28 |
29 |
GND |
GND |
30 |
We design PoE function for BPI-F3 ,so easy to add PoE module to support PoE function.Weld the RT5400B POE module and power it through the RJ45-2 interface.
After connecting to the MINI PCIE interface and inserting the SIM card, it can be used.
Bianbu source code: https://gitee.com/bianbu-linux/linux-6.1 |
Bianbu uboot code: https://gitee.com/bianbu-linux/uboot-2022.10 |
Bianbu OpenSBI code: https://gitee.com/bianbu-linux/opensbi |
BPI-F3 schematic |
Baidu cloud: https://pan.baidu.com/s/1CMp7kVKa5aeSdgB3Ri1PJw?pwd=8888 (pincode:8888)
BPI-F3 DXF file |
Baidu cloud: https://pan.baidu.com/s/1igwBjsLC54KbGH_y54tZQA?pwd=8888 (pincode:8888)
BPI-F3 run Ubuntu Linux test 8 Core CPU performance and AI function: https://www.youtube.com/watch?v=Ym-VcJgaGIY |
BPI-F3 SpacemiT K1 run OpenWRT: https://www.youtube.com/watch?v=ejV5KFww8Xo |
BPI-F3 run visual AI+ large models simultaneously: https://www.youtube.com/watch?v=Kn7GYiOxato |
Bringing up BPI-F3 : https://dev.to/luzero/bringing-up-bpi-f3-part-1-3bm4 |
Bianbu-23.10-k1-v1.0rc3-release-20240525131412.img |
Baidu cloud: https://pan.baidu.com/s/1H0ww8qVIgHRuuA43JszF6g?pwd=8888 (pincode: 8888)
Account/Password: root/bianbu
Bianbu-23.10-nas-k1-v1.0rc1-release-20240429192450.img |
Baidu cloud: https://pan.baidu.com/s/15owwUEjIU_i26cI1iigAew?pwd=8888 (pincode: 8888)
Bianbu-23.10-desktop-k1-v1.0rc1-release-20240429194149.img |
Baidu cloud: https://pan.baidu.com/s/1zvFkX92f5gpZdKjP-vGJvA?pwd=8888 (pincode: 8888)
2024-05-24-Armbian-unofficial_24.5.0-trunk_Bananapi-F3 |
Baidu cloud: https://pan.baidu.com/s/1H6drAJ3uIa5CImJAcR6GsA?pwd=8888 (pincode: 8888)
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/3256806735430070.html |
Bipai Aliexpress shop: https://www.aliexpress.com/item/3256806735645440.html |
Taobao Shop: https://item.taobao.com/item.htm?id=789483353026&spm=a213gs.v2success.0.0.220c4831vddhXz |
OEM&ODM,please contact : [email protected] |
