This module have HDMI interface on baord ,so it support BPI-M1,BPI-M1+,BPI-M2,BPI-M3,BPI-M64,BPI-M2U,BPI-M2B,BPI-R1.
LCD module for Banana Pi board via an conversion board to connect to the LCD connector designed specifically for interfacing to LCD.
Banana pi LCD Connector :The LCD Connector is a stander Type-A HDMI connector which can connect to HDMI-TX.
it support two touch panel
HardWare Specification of 10.1 HDMI panel |
TFT LCD MODULE |
HC101TK20050 |
TP MODULE |
GT9271 |
Panel Size |
10.1 inches |
Resolution |
1024 (RGB) x 600 |
Display Interface |
HDMI |
TP Interface |
USB-HID |
Color Depth |
16.7M |
Viewing Direction |
6 o’clock |
Active Area(mm) |
222.72(H)x125.28(V) |
OutlineDimension(mm) |
235(W)×143(H)×5.0( D) |
Display Format |
RGB vertical stripe |
Display Mode |
Normally White |
Operation Temperature |
-20~70℃ |
Weight (g) |
TBD |
TFT LCD MODULE |
HC101I35025NB |
TP MODULE |
ILI2511 |
Panel Size |
10.1 inches |
Resolution |
1280 (RGB) x 800 |
Display Interface |
HDMI |
TP Interface |
USB-HID |
Color Depth |
16.7M |
Viewing Direction |
6 o’clock |
Active Area(mm) |
216.96(W) × 135.60(H) |
229.46(W) ×149.1(H) ×2.50(D) |
Display Format |
Display Mode |
Normally White |
-20~70℃ |
Weight (g) |
TBD |
Back:
BPI 10.1 touch panel support HDMI interface
We have finished all Banana pi boards driver , it support Android,Linux and windows.
Banana pi BPI-10 1 HDMI touch screen demo with Linux: https://www.youtube.com/watch?v=R4OKR4vj1Ow&feature=youtu.be
