BPI-3A5000 is a Mini PC developed by Banana Pi open source community Loongson 3th-generation 3A5000 processor + Loongson 7A1000 bridge chip.
BPI-3A5000 can be applied to enterprise office, personal minicomputs, high-performance industrial computer, as well as education, medical, finance, edge computing and other fields. It has the advantages of high performance computing, portability, low energy consumption and easy management. The Loongson BPI-3A5000 MINIPC supports two DDR4 SODIMM slots, the memory rate is 3200M, a single memory supports 8GB/16GB/32GB, and the maximum memory capacity is 16GB. Storage Supports one M.2 2280-size NVME SSD slot and one 2.5-inch SATA disk expansion.
BPI-3A5000 Longson minicomputeruses mini case design, unique high density heat dissipation structure design, high performance, high density and high reliability in one; It is easy to move and saves space when it meets various application scenarios.
In addition to conventional computing applications, the BPI-3A5000 can also be pre-installed with the following industrial control applications, including but not limited to:
300+ Industry general/industry specific protocol library
Video access transmission/control/recording/linkage function
Computational programming capabilities
Industrial firewall function
Soft PLC programming function
C/S architecture SCADA system functions
B/S architecture SCADA system functions
Mini size
The volume of the whole machine is less than 1L, which is 40 times smaller than the desktop
Small size, easy to carry, easy to organize, one hand
Can support wall hanging, can be hung behind the monitor/TV series, save desktop space
High performance
Using the fourth generation of Loongson 3A5000 CPU+7A1000 bridge
Supports two DDR4 SODIMM slots
Supports memory rates up to 3200Mbps
Supports multiple CPU cores, up to 4 physical cores and 8 logical cores
High reliability
Advanced memory fault-tolerant ECC function (currently not supported by existing BIOS)
The use of all copper fin cooling architecture, so that the CPU performance is fully developed, full load performance is still reliable
Support intelligent speed adjustment function, the fan speed dynamically adjusts with the system temperature, effectively reducing the system noise and power consumption
Interface rich
Multiple interface types, can meet the needs of multiple scenarios at the same time
Dual display interface to achieve dual HDMI + VGA output at the same time, create a multi-screen working environment, improve efficiency and entertainment experience
NVMe and SATA interface dual hard disk design, easy to expand, increase storage space
| Item | Specifications |
CPU |
Supports the third generation of Loongson 3A5000 4-core 8-thread processor, 2.0GHz |
Large capacity Level 3 cache (64KB/256KB/16MB) |
RAM |
One memory slot for supporting the DDR43200 memory rate |
Expandable up to 16GB memory, supports only SODIMM |
Storage |
support 1 x M.2 2280 NVMe SSD (PCIE3.0 x 4 ) |
Display |
VGA+ HDMI Dual display interface,Bridge chip built-in integrated GPU, 1Gb video memory, maximum resolution 1920x1080 |
Wireless |
Support dual-band wireless WiFi 5G/2.4G,support 802.11AC |
External interface |
2 x USB 3.0 + 4 x USB 2.0 ,On the front panel of the chassis |
1 x HDMI + 1 x VGA,on the rear panel of the chassis |
1 x RJ-45 Gigabit network ,on the rear panel of the chassis |
1 x 3.5mm The earphone/microphone audio port |
Reserved debugging interface |
1 x TTL Level UART debugging interface, 2.54mm pin |
1 x LA-JTAG ,Mainly used for CPU debugging |
Size |
138mm x 128mm x 48.5 mm(Long x Wide x High) |
Power dissipation |
Maximum power consumption: No more than 30W |
DC Power |
DC19V 3.42A, 5.5/2.5mm |
Cooling system |
1 special custom cooling module |
Operating system |
Loongnix/UOS/Kylin OS; |
Operating system support is subject to change without notice |
| Item | explain |
operating temperature |
0℃~+70℃ |
storage temperature |
-40~+80℃ |
operating humidity(RH) |
5%~95% non-condensing |
Storage Humidity(RH) |
altitude |
<5000m |
lightning protection |
Built-in lightning protection element, support outdoor use, in line with high-level EMC standards |
level of protection |
IP40 |
heat-dissipating method |
Fans&Heatsink |
electromagnetic compatibility |
EMC III grade, |
GB/T17626、GB/T15153、IEC61850-3、EN61000-6-5 |
safety standard |
GB/T7621-2008 |
CE certification |
CE & FCC &RoHS |
In addition to PCBA design and production, Banana Pi open source community can also provide Loongson Mini PC complete machine, so that users can quickly complete the standard product design. CNC aluminum housing
Interface Identifier:
| Number | Name | Number | Name |
3 |
USB 2.0 x 2 interface |
4 |
USB 2.0 x 2 interace |
5 |
2 |
Headset interface |
Interface specification:
| Name | Type | quantity | explain |
USB 3.0 interface |
TYPE-A |
2 |
standard USB 3.0 TYPE-A |
USB 2.0 interface |
TYPE-A |
4 |
standard USB 2.0 TYPE-A |
Headset interface |
standard 3.5mm |
1 |
Audio input/output interface |
6 |
Ethernet interface |
7 |
VGA interface |
8 |
HDMI interface |
9 |
Power |
LAN |
RJ-45 |
1 |
Connect the Ethernet port of the device to the switch using a network cable. Note: Support 1000M/100M/10M adaptive |
VGA |
HDMI 1.4 |
1 |
To output video, use an HDMI video cable to connect the video output port to the display. Note: The HDMI video cable is not in the installation accessory package, and needs to be purchased by the user. Please select a shielded cable with a length less than 3M. |
HDMI |
HDMI 1.4 |
1 |
Power input i |
5.5/2.5mm |
1 |
DC 19V/65W,3.42A |
