The BPI-5400 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af and IEEE 802.3at Power-over-Ethernet(PoE) standard.
The BPI-5400 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 30W power to the port.
The DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
IEEE802.3at and IEEE802.3af compliant
Maximum 30W output power
Input voltage range 36V to 57V
Integral high efficiency DC/DC converter.
Low output ripple and noise
High performance with low price
Short-circuit protection
Transformer isolation ,1500V isolation (input to output)
Easy to use, with a minimum number of external components.
IP Cameras
Wireless access point
Security and alarm systems
VOIP telephone
Point of sale network terminal equipment
| Recommended PCB hole diameter PTH = 1.2 ± 0.05 |
| Part Number | Nominal Output | Max Output Power | Integrated bridge | Marking | Package |
5400BS |
-12V |
30W |
NO |
RT5400B |
DIP |
5400BS |
-24V |
30W |
NO |
RT5400B-24V |
DIP |
5400B |
-12V |
30W |
YES |
RT5400B |
DIP |
5400B |
-24V |
30W |
YES |
RT5400B-24V |
DIP |
| Pin | Name | Description |
1 |
VA1 |
RX Input (1). This input pin is used in conjunction with VA2 and connects to the centre tap of the transformer connected to pins 1 & 2 of the RJ45 connector (RX) - it is not polarity sensitive.(5400-S, POE Direct Input . This pin connects to the positive () output of the POE input bridge rectifiers.) |
2 |
VA2 |
TX Input (2). This input pin is used in conjunction with VA1 and connects to the centre tap of the transformer connected to pins 3 & 6 of the RJ45 connector (TX) - it is not polarity sensitive.(5400-S,POE Direct Input -. POE Direct Input -. This pin connects to the negative (-) output of the POE input bridge rectifiers..) |
3 |
VB1 |
Direct Input (1). This input pin is used in conjunction with VB2 and connects to pin 4 & 5 of the RJ45 connector - it is not polarity sensitive. |
4 |
VB2 |
Direct Input (2). This input pin is used in conjunction with VB1 and connects to pin 7 & 8 of the RJ45 connector - it is not polarity sensitive. |
5 |
cap+ |
Internal cap, need Match Dynamic load ,connecting A 22uf-100uf 63V |
6 |
cap- |
7 |
-VDC |
DC Return. This pin is the return path for the +VDC output. |
8 |
+VDC |
DC Output. This pin provides the regulated output from the DC/DC converter. |
9 |
ADJ |
Output Adjust. The output voltage can be adjusted from is nominal value, by connecting an external resistor from this pin to either the +VDC pin or the -VDC pin. |
10 |
-VDC |
| Num | Parameter | Symbol | Min | Max | Units |
1 |
DC Supply Voltage |
VCC |
-0.3 |
60 |
V |
2 |
DC Supply Voltage Surge for 1ms |
VSURGE |
-0.6 |
80 |
V |
3 |
Storage Temperature |
TS |
-40 |
100 |
OC |
The RT5400B classification is fixed at Class 4, this means that an IEEE802.3at Type 1 or an IEEE802.3af PSE will default to Class 0. However an IEEE802.3at PSE will recognise the Class 4 as a Type 2 PD.
| Num | Parameter | Symbol | Min | Typ | Max | Units |
1 |
Input Supply Voltage1 |
VIN |
36 |
48 |
57 |
V |
2 |
Under Voltage Lockout |
VLOCK |
30 |
36 |
V |
3 |
Operating Temperature2 |
TOP |
-20 |
25 |
70 |
Ta / °C |
4 |
Operating Temperature 24W Continuous |
TOP |
-40 |
25 |
50 |
Ta / °C |
5 |
Operating Temperature 18W Continuous |
TOP |
-40 |
25 |
70 |
Ta / °C |
| Num | DC Characteristic | Sym | Min | Typ1 | Max | Units | Test Comments |
1 |
Nominal Output Voltage |
+VDC |
11.5 |
12.0 |
12.5 |
V |
12V |
2 |
Line Regulation |
VLINE |
0.1 |
@ 50% Load |
3 |
Load Regulation |
VLOAD |
1 |
@ VIN=48V |
4 |
Output Ripple and Noise 2 |
VRN |
180 |
mVp-p |
@ Max load2 |
5 |
Minimum Load 3 |
RLOAD |
200 |
mA |
@ 12V out |
6 |
Short-Circuit Duration |
TSC |
sec |
7 |
Efficiency @ 80% Load |
EFF |
86 |
RT5400X |
8 |
Isolation Voltage (I/O) |
VISO |
1500 |
VPK |
Impulse Test |
9 |
Temperature Coefficient |
TC |
0.02 |
Per °C |
1: Typical figures are at 25°C with a nominal 52V supply and are for design aid only. Not Guaranteed 2: The output ripple and noise can be reduced with an external filter 3: The module can emit an audible noise if operated at less than the specified minimum load and may cause the PSE to fail its MPS . |
