| In order to ensure that your roaming signal can be connected to the antenna of the corresponding module. |
Find the corresponding SIM card slot and insert the SIM card. There are roughly two types of slots.
The first type of card slot is similar to R4.This requires that Cato be plugged into the SIM card slot.
The other type is similar to R3mini.
The system will automatically make a call and obtain the IP address.
If your board does not have automatic dialing function, please use the "quectel-CM &" command to make the call.
Successful dialing is as follows:
RM500U-CN
quectel-CM &
root@OpenWrt:~# [12-30_09:32:59:019] QConnectManager_Linux_V1.6.8
[12-30_09:32:59:019] Find /sys/bus/usb/devices/4-1.1 idVendor=0x2c7c idProduct=0x900, bus=0x004, dev=0x003
[12-30_09:32:59:020] Auto find qmichannel = /dev/ttyUSB2
[12-30_09:32:59:020] Auto find usbnet_adapter = usb0
[12-30_09:32:59:020] netcard driver = cdc_ncm, driver version = 6.6.93
[12-30_09:32:59:020] Modem works in ECM_RNDIS_NCM mode
[12-30_09:32:59:025] /proc/6297/fd/7 -> /dev/ttyUSB2
[12-30_09:32:59:025] /proc/6297/exe -> /sbin/quectel-CM
[12-30_09:33:01:026] atc_fd = 7
[12-30_09:33:01:026] AT> ATE0Q0V1
[12-30_09:33:01:036] AT< OK
[12-30_09:33:02:036] AT> AT+QCFG="usbnet"
[12-30_09:33:02:040] AT< +QCFG: "usbnet",5
[12-30_09:33:02:040] AT< OK
[12-30_09:33:02:040] AT> AT+QNETDEVCTL=?
[12-30_09:33:02:042] AT< +QNETDEVCTL: (1-8),(0-3),(0,1)
[12-30_09:33:02:042] AT< OK
[12-30_09:33:02:042] AT> AT+CGREG=2
[12-30_09:33:02:054] AT< OK
[12-30_09:33:02:054] AT> AT+CEREG=2
[12-30_09:33:02:059] AT< OK
[12-30_09:33:02:059] AT> AT+C5GREG=2
[12-30_09:33:02:064] AT< OK
[12-30_09:33:02:064] AT> AT+QNETDEVSTATUS=?
[12-30_09:33:02:067] AT< +QNETDEVSTATUS: (1-8)
[12-30_09:33:02:067] AT< OK
[12-30_09:33:02:067] AT> AT+QCFG="NAT"
[12-30_09:33:02:071] AT< +QCFG: "nat",0
[12-30_09:33:02:071] AT< OK
[12-30_09:33:02:071] AT> AT+CGMR
[12-30_09:33:02:074] AT< RM500UCNVAAR03A05M2G_01.001.01.001
[12-30_09:33:02:074] AT< OK
[12-30_09:33:02:074] AT> AT+CPIN?
[12-30_09:33:02:076] AT< +CPIN: READY
[12-30_09:33:02:076] AT< OK
[12-30_09:33:02:076] AT> AT+QCCID
[12-30_09:33:02:079] AT< +QCCID: 89860117801482589811
[12-30_09:33:02:079] AT< OK
[12-30_09:33:02:079] requestGetICCID 89860117801482589811
[12-30_09:33:02:079] AT> AT+CIMI
[12-30_09:33:02:081] AT< 460011637112108
[12-30_09:33:02:081] AT< OK
[12-30_09:33:02:081] requestGetIMSI 460011637112108
[12-30_09:33:02:081] AT> AT+QICSGP=1
[12-30_09:33:02:086] AT< +QICSGP: 3,"3gnet","","",0
[12-30_09:33:02:086] AT< OK
[12-30_09:33:02:086] requestGetProfile[1] 3gnet///0/IPV4V6
[12-30_09:33:02:086] AT> AT+COPS=3,0;+COPS?;+COPS=3,1;+COPS?;+COPS=3,2;+COPS?
[12-30_09:33:02:097] AT< +COPS: 0,0,"",11
[12-30_09:33:02:105] AT< +COPS: 0,1,"N-V▒T▒",11
[12-30_09:33:02:112] AT< +COPS: 0,2,"46001",11
[12-30_09:33:02:113] AT< OK
[12-30_09:33:02:113] AT> AT+C5GREG?
[12-30_09:33:02:117] AT< +C5GREG: 2,1,"774B01","770F9D18E",11,9,01.000000
[12-30_09:33:02:117] AT< OK
[12-30_09:33:02:117] AT> AT+QNETDEVSTATUS=1
[12-30_09:33:02:211] AT< +QNETDEVSTATUS: 10.3.1.80,255.255.255.0,10.3.1.1,,120.80.80.80,221.5.88.88,2408:8459:d002:bd17:1885:f46d:9a4a:f9aa,,,,2408:8888:0000:8888:0000:0000:0000:0008,2408:8899:0000:8899:0000:0000:0000:0008
[12-30_09:33:02:211] AT< OK
[12-30_09:33:02:211] AT< +QNETDEVSTATUS: 1,1,"IPV4V6",0
[12-30_09:33:02:211] AT> AT+QNETDEVCTL=1,0,0
[12-30_09:33:02:475] AT< OK
[12-30_09:33:02:475] AT> at+cops?
[12-30_09:33:02:483] AT< +COPS: 0,2,"46001",11
[12-30_09:33:02:483] AT< OK
[12-30_09:33:02:483] AT> at+qeng="servingcell"
[12-30_09:33:02:703] AT< +QENG: "servingcell","SEARCH"
[12-30_09:33:02:703] AT< OK
[12-30_09:33:02:703] AT> AT+QNETDEVSTATUS=1
[12-30_09:33:02:797] AT< +QNETDEVSTATUS: 10.3.1.80,255.255.255.0,10.3.1.1,,120.80.80.80,221.5.88.88,2408:8459:d002:bd17:1885:f46d:9a4a:f9aa,,,,2408:8888:0000:8888:0000:0000:0000:0008,2408:8899:0000:8899:0000:0000:0000:0008
[12-30_09:33:02:797] AT< OK
[12-30_09:33:02:797] AT> AT+QNETDEVSTATUS=1
[12-30_09:33:02:882] AT< +QNETDEVSTATUS: 10.3.1.80,255.255.255.0,10.3.1.1,,120.80.80.80,221.5.88.88,2408:8459:d002:bd17:1885:f46d:9a4a:f9aa,,,,2408:8888:0000:8888:0000:0000:0000:0008,2408:8899:0000:8899:0000:0000:0000:0008
[12-30_09:33:02:882] AT< OK
[12-30_09:33:02:882] requestGetIPAddress 10.3.1.80
[12-30_09:33:02:882] ip link set dev usb0 up
[12-30_09:33:02:885] busybox udhcpc -f -n -q -t 5 -i usb0
udhcpc: started, v1.36.1
udhcpc: broadcasting discover
udhcpc: broadcasting select for 10.3.1.80, server 10.3.1.1
udhcpc: lease of 10.3.1.80 obtained from 10.3.1.1, lease time 86400
[12-30_09:33:03:229] udhcpc: ip addr add 10.3.1.80/255.255.255.0 broadcast + dev usb0
[12-30_09:33:03:231] udhcpc: setting default routers: 10.3.1.1
[12-30_09:33:03:234] AT> at+cops?
[12-30_09:33:03:239] AT< +COPS: 0,2,"46001",11
[12-30_09:33:03:239] AT< OK
[12-30_09:33:03:240] AT> at+qeng="servingcell"
[12-30_09:33:03:450] AT< +QENG: "servingcell","SEARCH"
[12-30_09:33:03:451] AT< OK
[12-30_09:33:03:451] AT> AT+QNETDEVSTATUS=1
[12-30_09:33:03:535] AT< +QNETDEVSTATUS: 10.3.1.80,255.255.255.0,10.3.1.1,,120.80.80.80,221.5.88.88,2408:8459:d002:bd17:1885:f46d:9a4a:f9aa,,,,2408:8888:0000:8888:0000:0000:0000:0008,2408:8899:0000:8899:0000:0000:0000:0008
[12-30_09:33:03:535] AT< OK
[12-30_09:33:03:535] AT> AT+QNETDEVSTATUS=1
[12-30_09:33:03:613] AT< +QNETDEVSTATUS: 10.3.1.80,255.255.255.0,10.3.1.1,,120.80.80.80,221.5.88.88,2408:8459:d002:bd17:1885:f46d:9a4a:f9aa,,,,2408:8888:0000:8888:0000:0000:0000:0008,2408:8899:0000:8899:0000:0000:0000:0008
[12-30_09:33:03:613] AT< OK
Quectel RM520N-GL
Quectel RM520N-GL
wwan0 Link encap:Ethernet HWaddr A6:35:F7:7A:9E:A7
UP RUNNING NOARP MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:1272 (1.2 KiB) TX bytes:1932 (1.8 KiB)
wwan0_1 Link encap:Ethernet HWaddr A6:35:F7:7A:9E:A7
inet addr:10.46.121.135 Mask:255.255.255.240
RX bytes:1292 (1.2 KiB) TX bytes:1932 (1.8 KiB)
root@R4CN:/#
root@R4CN:/# lsusb
Bus 002 Device 002: ID 2109:0822 VIA Labs, Inc. USB3.1 Hub
Bus 001 Device 003: ID 2109:8822 VIA Labs, Inc. USB Billboard Device
Bus 001 Device 002: ID 2109:2822 VIA Labs, Inc. USB2.0 Hub
root@R4CN:/#
^C
root@R4CN:/#
RM500U-CN
usb0 Link encap:Ethernet HWaddr 5E:3B:9C:76:7C:46
inet addr:10.95.9.23 Bcast:10.95.9.255 Mask:255.255.255.0
inet6 addr: fe80::5c3b:9cff:fe76:7c46/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:34 errors:0 dropped:0 overruns:0 frame:0
TX packets:62 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7908 (7.7 KiB) TX bytes:10100 (9.8 KiB)
root@R4CN:/#
root@R4CN:/# lsusb
Bus 002 Device 003: ID 2c7c:0900 Quectel RM500U-CN
root@R4CN:/#
PING www.baidu.com (2409:8c54:870:34e:0:ff:b024:1916): 56 data bytes
64 bytes from 2409:8c54:870:34e:0:ff:b024:1916: seq=0 ttl=51 time=55.105 ms
64 bytes from 2409:8c54:870:34e:0:ff:b024:1916: seq=1 ttl=51 time=38.725 ms
64 bytes from 2409:8c54:870:34e:0:ff:b024:1916: seq=2 ttl=51 time=39.890 ms
^C
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 38.725/44.573/55.105 ms
root@R4CN:/#
