BPI-7604 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. BPI-7604 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. BPI-7604 provides a Class 0 signature. BPI-7604 DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
IP Cameras
Wireless access point
Security and alarm systems
VOIP telephone
Point of sale network terminal equipment
IEEE802.3af compliant
Integrated LAN Filters
Regulated 12V DC output
Low output ripple and noise
Wide Input voltage range
Overload and short-circuit protection
1500V isolation (input to output)
Simple installation
CE and FCC part 15 certified
Enables PoE functionality for legacy products
1 |
Input Voltage: 36 to 57 Vdc |
2 |
Output power: 13W max. |
3 |
Output current and voltage: 1.08A max. @ 12V +/-0.5V |
4 |
Ripple: Typical 100mVp-p |
5 |
Connectors: 2 x 8pin 1x 4pin 1.25mm |
6 |
Ethernet Supported: 10/100-Base-T IEEE 802.3af |
7 |
PoE Pin Assignment: 3/6, 1/2 or 4/5, 7/8 |
8 |
Storage Temperature: -30°C to +80°C |
9 |
Operating Humidity: 10% to 90%, non-condensing |
10 |
Storage Humidity: 5% to 95%, non-condensing |
11 |
Emissions & Immunity: FCC Part 15 Class A EN55022 (CISPR 22) Class B EN55024 (CISPR 24) |
12 |
Safety: CE IEC 60950 |
13 |
Reliability MTBF: 100,000 hours @ 25°C |
14 |
Warranty : 1 Year |
15 |
Dimensions: Height: 38 mm Width: 38mm Depth: 18mm Weight: 20 g |
16 |
Operating Temperature: -20°C to +70°C |
J1 |
AUX IN 1.25mm |
J3 |
DC Putout 2 2.0mm |
1 |
Ethernet cable spare pair 7,8 |
1 |
12V Output |
2 |
Ethernet cable spare pair 4,5 |
2 |
12V Output - |
3 |
DC Auxiliary input 12V- |
4 |
DC Auxiliary input 12V+ |
J2 |
POE_IN 1.25mm |
J4 |
NET out 1.25mm |
1 |
LED- Internal connection J3 |
1 |
12V Output - |
2 |
LED+ Internal connection J3 |
2 |
12V Output |
3 |
Ethernet cable 6 |
3 |
LED- Internal connection J1 |
4 |
Ethernet cable 3 |
4 |
LED+ Internal connection J1 |
5 |
Ethernet cable 2 |
5 |
Ethernet cable 1 |
6 |
Ethernet cable 1 |
6 |
Ethernet cable 2 |
7 |
Ethernet cable 3 |
8 |
Ethernet cable 6 |
Products can be customized according to customer needs
