The BPI-9600 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af Power-over-Ethernet(PoE) standard. The BPI-9600 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 15W power to the port. The BPI-9600 provides a Class 0 signature.
The DC/DC converter operates over a wide input voltage range and provides a regulated output. The DC/DC converter also has built-in short-circuit output protection.
IEEE802.3af compliant
Input voltage range 36V to 57V
Integral high efficiency DC/DC converter.
Low output ripple and noise
High performance with low price
Short-circuit protection
Adjustable Output
Optional multi-voltage output 3.3V 5V 12V 24V
Transformer isolation ,1500V isolation (input to output)
Easy to use, with a minimum number of external components.
IoT gateway
IP Cameras
Wireless access point
Security and alarm systems
VOIP telephone
Point of sale network terminal equipment
| BPI-9600 PoE module | ||||
Part Number |
Nominal Output Voltage |
Maximum Output Power |
Marking |
Package |
BPI-9600-3.3V |
3.3V |
6.6W |
3.3V |
SIL |
BPI-9600 -5V |
5V |
10W |
5V |
SIL |
BPI-9600 -12V |
12V |
12W |
12V |
SIL |
BPI-9600 -24V |
24V |
12W |
24V |
SIL |
At 25°C with VIN = 48V
Pin # |
Name |
Description |
1 |
VA1 |
RX Input (1). This input pin is used in conjunction with VA2 and connects to the centre tap of the transformer connected to pins 1 & 2 of the RJ45 connector (RX) - it is not polarity sensitive. |
2 |
VA2 |
TX Input (2). This input pin is used in conjunction with VA1 and connects to the centre tap of the transformer connected to pins 3 & 6 of the RJ45 connector (TX) - it is not polarity sensitive. |
3 |
VB1 |
Direct Input (1). This input pin is used in conjunction with VB2 and connects to pin 4 & 5 of the RJ45 connector - it is not polarity sensitive. |
4 |
VB2 |
Direct Input (2). This input pin is used in conjunction with VB1 and connects to pin 7 & 8 of the RJ45 connector - it is not polarity sensitive. |
5 |
-VDC |
DC Return. This pin is the return path for the +VDC output. |
6 |
+VDC |
DC Output. This pin provides the regulated output from the DC/DC converter. |
| BPI-9600 PoE module | |||||
Parameter |
Symbol |
Min |
Max |
Units |
1 |
DC Supply Voltage |
VCC |
-0.3 |
60 |
V |
2 |
DC Supply Voltage Surge for 1ms |
VSURGE |
-0.6 |
80 |
V |
3 |
Storage Temperature |
TS |
-40 |
100 |
OC |
| BPI-9600 PoE module | |||||||
Parameter |
Symbol |
Min |
Typ |
Max |
Units |
Units |
1 |
Input Supply Voltage1 |
VIN |
36 |
48 |
57 |
V |
V |
2 |
Under Voltage Lockout |
VLOCK |
30 |
36 |
V |
V |
3 |
Operating Temperature2 |
TOP |
-20 |
25 |
70 |
Ta / OC |
BPI-9600 |
Note:
With minimum load
See Section Operating Temperature Range
Extended use close to, or at the maximum operating temperature can reduce the life time of the device.
Note:
Typical figures are at 25°C with a nominal 48V supply and are for design aid only. Not Guaranteed
The output ripple and noise can be reduced with an external filter, see application note.
Continuous short circuit duration is applicable at 25’C ambient temperature in free air. At higher temperatures or with restricted airflow (e.g. in a sealed enclosure) the duration will need to be limited to avoid overheating.
Banana pi BPI-P2 Zero IEEE 802.3af PoE function test: https://www.youtube.com/watch?v=RCrDmhjxfCU&feature=youtu.be
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/item/2251832735292314.html?gatewayAdapt=4itemAdapt |
| Bipai Aliexpress Shop: https://www.aliexpress.com/item/3256804449759983.html?gatewayAdapt=4itemAdapt |
| Taobao: https://item.taobao.com/item.htm?id=602820039973&spm=a1z10.5-c-s.w4002-25059194413.15.6cfc3fafMTGBQw |
| OEM&ODM: please contact: [email protected] |
