BPI-AI(also name Web:AI for Webduino) design with K210 RISC-V chip design.
An integrated artificial intelligence SOC chip solution that can accommodate neural network models, using a new risc-v instruction set for the field of artificial intelligence and edge computing.
The main target market is the AIoT and STEAM education market, it support screen and camera.
So easy to do many AI application, cowork with Webduino team. and support Webduino blockly for STEAM education.
Also support Arduino IDE,MixPy.
AI for Edge Computing
Smart Building
Medical equipment
Automation & Process Control
Robot
IoT applications
STEAM education
64-bit RISC-V CPU Dual-Core, up to 400MHz
IMAFDC (RV64GC) ISA extension
Hardware FPU (Float Point Unit), Double Precision
32 KB I-Cache per core and 32 KB D-Cache per core
8MB On-Chip SRAM 128Kbit One-Time Programmable Memory (OTP) ,Read Only Memory (ROM)
DMA
Camera and screen interface
WiFI (ESP8285)
JTAG, OpenOCD support
The Kendryte K210 is a system-on-chip (SoC) that integrates machine vision and machine hearing.
Using TSMC’s ultra-low-power 28nm advanced process with dual-core 64-bit processors for better power performance, stability and reliability.
The program strives for zero threshold development and can be deployed in the user’s products in the shortest time, giving the product artificial intelligence.
The Kendryte K210 is located in the SoC of the AI and IoT markets and is a very convenient MCU.
Kendryte Chinese means surveying intelligence, while surveying intelligence is taken from surveying and searching.
The main application field of this chip is in the field of Internet of Things, and it is developed in the field of Internet of Things.
Therefore, this chip mainly provides artificial intelligence solutions, which are explored in the field of artificial intelligence.
| HardWare Specification of Banana Pi BPI-AI | |
CPU |
Kendryte K210 64-bit RISC-V CPU Dual-Core, up to 400MHz,with neural processing unit (NPU) |
Memory |
SPI flash and The accelerator has its own memory, with 6MB of static RAM given over to the dual-core CPU and a further 2MB for the NPU coprocessor. |
Camera |
5 million pixel cameras |
WIFI |
ESP8285 wifi module support 802.11.b/g/n |
Audio Output(s) |
Built-in MEMS microphone supports 3W speaker output |
LCD Screen |
8bit MCU 2.3 LCD,DPI 320x240 |
Socket |
Compatible with BPI: BIT Micro:bit Goldfinger,TF card ,Speaker,lithium battery interface |
Development environment |
Arduino IDE, MaixPy IDE ,Webduino |
Switches |
Reset, A/B key |
Power Source |
5volt@2A via Micro USB ,lithium battery interface(3.7-4.2V) |
Size & Weight |
51.6mm×67mm, 58g |
| K210 chip official Source code on github: https://github.com/kendryte |
| Web:AI for maixpy : https://github.com/webduinoio/webai-maixpy |
| Web:AI initialization Settings teaching : https://www.youtube.com/watch?v=ZSGkZUQQXcI |
| K210 chip datasheet(English): https://drive.google.com/file/d/1AavU-bCoyA2BWSDB3NQBp41A7CvdJvBL/view?usp=sharing |
| K210 chip datasheet(Chinese): https://drive.google.com/file/d/1_xQ3waq4ENHIlfJ7ujrfRSAClNAk6beL/view?usp=sharing |
| K210 SDK(drive)、documents、compiler、OpenOCD Debugging software : https://kendryte.com/downloads/ |
| jacklab K210 wiki page : http://wiki.jackslab.org/K210 |
| OEM&ODM, please contact: [email protected] |
