Use WebComponents integration Breakout.
Use WebSocket(Firmata) to interacting with the server.
Server use TCP/IP(Firmata) to control webduino terminal.
| Webduino project VS Arduino and micro:bit project | |||
item compared |
Webduino |
Arduino |
Micro:bit |
development |
language |
HTML/JavaScript |
C/C++ Python/JavaScript |
development |
environment WEB browser |
Arduino IDE |
JavaScript Blocks |
Simulator |
Webduino Simulator |
Third-party support |
Microsoft MakeCode |
graphical programming |
Wbduino blockly |
Third-party |
Scratch Blockly |
Cloud Server |
webduino cloud |
N/A |
N/A |
attended mode |
WiFi |
USB |
USB |
Update the program |
web online update |
USB burn |
USB disk |
More webduino function now is open source , and code update to github.
Board a total of three power supply, you can choose one
USB cable power supply, bit board design has a Micro USB interface, in daily life wire is relatively common, it is quite convenient to use.
Power is supplied through 2Pin battery socket, which can supply power to the board through lithium battery, battery pack, etc. The interface has anti-stay design, and there is no need to worry about the problem of inverting the power supply
Through the goldfinger power supply, the lower end of the board goldfinger contains a power interface, while both input and output functions, compatibility is very high.
BPI-Bit has been programmed Webduino firmware by default. Only when you reprogram the flash with other firmware, will you need to program Webduino firmware again.
How to : Webduino firmware programming
BPI-Bit for webduino support OTA cloud upgrade , it is easy to use this function to update newest version.
Power on bit ,Press the A button when flash white light, unpress A booton when when the green light is on, so start to update.
Initialization of Webduino Bit: https://www.webduino.com.cn/site/en/docs/setting.html
If you can connect BPI-Bit to internet ,so you can use webduino blockly to use webduino all functions.
Download link : https://github.com/BPI-STEAM/BPI-BIT-Webduino/releases
Please download the newest version and one key to install
Web:bit offline education version support auto upgrade.When you start it, it updates automatically
Online doucments: https://doc.bpi-steam.com/en/latest/bpi-web/tutorials/index.html , we will keep update.
Webduino Blockly and simulator
Webduino online Blockly (english): https://bit.webduino.com.cn/blockly/?lang=en
Webduino online Blockly (chinese) https://bit.webduino.io/blockly/?lang=zh-hant
Quick start BPI:bit with Webduino Blockly and simulator http://www.webduino.com.cn/site/en/tutorials.html
Get to know Webduino Blockly Bit : https://www.webduino.com.cn/site/en/docs/blockly.html
BPI-bit Through the photosensitive resistors built into Webduino Bit on the left and right sides, it is easy to determine which side the gesture comes from
Code link: https://bit.ly/2lFNeYL
Using Webduino Bit nine shaft sensor "attitude Angle" + full color dot matrix, simple implementation ~ _ interesting effects
Code link: https://bit.ly/2MAhHTF
Webduino Bit Detail: https://www.webduino.com.cn/site/en/docs/detail.html
5x5 RGB LED matrix: https://www.webduino.com.cn/site/en/docs/rgbmatrix.html
Light Detection : https://www.webduino.com.cn/site/en/docs/photocell.html
