Banana Pi BPI-CM5 is a computer module with Amlogic A311D2 quad-core Cortex-A73 and quad-core Cortex-A53 SOC, Mali-G52 GPU MP8 GPU,4GB LPDDR4/LPDDR4x (Max 8G),16G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
Amlogic A311D2,quad-core Cortex-A73 and quad-core Cortex-A53 SOC
Designed with Board to Board connectors for enhanced stability same as RasPi CM4
One on-board Gigabit Ethernet
One PCIe2.0 interface expansion, can flexibly add related modules
One USB3.0 port up to 5Gbps
One USB2.0 high-speed USB/IO witch support USB OTG
Three HDMI2.1 receiver ports
one HDMI2.1 transmitter port with CEC
two 8-lane V-by-One output can support up to 4Kx2K resolution(Multiplexing with MIPI-DSI/eDP/LVDS)
two 4-lane MIPI-CSI camera interface with 16Mp ISP
support Android and Linux system.
we also design a full function IO board for BPI-CM5,so you can use it for developemnt . also you can easy to design a new base IO board for your product.
BPI-CM5 computer module same size as Raspberry Pi CM4, 2x100 PIN can compatible RPI CM4 base board ,if you want use all function with BPI-CM5,you need use BPI-CM5 base board.
| OEM&ODM please contact : [email protected] |
