The camera V3 module is specifically designed for BPi-M3.It include two CMOS sensor module, one is OV5640(5M Pixel),and the other is OV8865(8M Pixel),so you can choose one or two campera for this board.
Camera can support 2 scene. One is OV5640 and one is OV8865
Connect the camera module and BPi-M3 with a 40PIN FFC cable, like the pictures below :
Note: For BPI-M2+ , camera is not same as BPI-M2,BPI-M1…. , it support OV5640 module, not need extend board. you just can direct use OV5640 modue on CSI interface.
If you have BPI-M1/M1+/M2 camera module ,you can remove camera module from extend bard ,and can use on BPI-M2+.
Connect way:
How to use this module on BPI-M2+ : https://docs.banana-pi.org/en/BPI-M2_Plus/GettingStarted_BPI-M2_Plus#_camara_function
| BPI camera SCH download: https://drive.google.com/file/d/1gyiDM7mpnWsADAtnXcwEcd6oXQQg_WuT/view?usp=sharing |
| OV5640 datasheet download: https://drive.google.com/file/d/0B4PAo2nW2KfnbE03bldrdXdSQ1E/view?usp=sharing |
| OV8865 datasheet download: https://drive.google.com/file/d/0B4PAo2nW2KfnUy1yOTB2YllBSGM/view?usp=sharing |
