SpacemiT K1 Open source SBC : Banana Pi BPI-F3
Base on RISC-V open instruction set architecture,we are committed to create more energy efficient and more commonly used AI processor platform,promote global open source and open ecological computing power construction.
K1 is mainly used for single board computer,network storage,cloud computer,smart robort,industrial control,edge computer,etc.
Octa-core RISC-V AI CPU,provided 50KDMIPS CPU computing power and 2.0 TOPS AI computing power.The computing power for single core in K1 is 30% ahead of ARM A55.
The world’s first RISC-V AI CPU supports RVA22 Profile and 256-bit RVV 1.0 standard, provides 2 times SIMD parallel processing capability than Neon.
Provides AI computing power by CPU core fusion,achieve rapid integration with all mainstream AI ecosystems.
Lean and superior micro-architecture,the computing power efficiency is 20% higher than A55.
Integrates multiple interfaces including PCIe,USB,GMAC,SPI,etc,provides comprehensive selection of peripheral connections.
CPU can provide stable continuous power output under temperatures from -40 degree to -85 degree,which can meet the demanding needs of industrial applications.
K1 is an octa-core X60™ intelligent computing processor
Eight-stage dual-issue in-order pipelin
Supports 256-bit RVV1.0 standard.
CPU combines 2.0 TOPS AI computing power.
1MB of shared L2 Cache for every eight cores.
X60TM extends 16 AI instructions, including matrix multiplication and sliding window calculation.
It’s an open system with instruction sets and operator libraries that can run all AI algorithm from AlexNet to Llama-2-7b.
Follows the development method of general-purpose CPUs, a programming model can cover the entire process of AI development.
Supports RISC-V PMP security specifications and ePMP security extensions.
Supports secure boot, secure storage, signature verifications.
Supports algorithms like AES, SHA, RSA, SM2, SM3, SM4,etc.
Supports product lifecycle security management.
Memory
32bit LPDDR4 - 2400MT
32bit LPDDR4X - 2666MT
Max to 16 GB.
Bandwidth max to 10.6GB/s
Supports SPI flash
Supports eMMC 5.1
Supports SDIO3.0 SD card.
Supprts SSD:NVMe over PCle
Supports 3D graphics engine,compatibility with OpenCL 3.0, OpenGLES 3.2, Vulkan 1.2
Supports 4K H.265/H.264/VP9/VP8, and other encoding/decoding formats.
* Dual-screen display support, with a maximum resolution of 1920*1440@60fps. -By MIPI-DSI,HDMI output.
Supports triple camera inputs, with a single camera of up to 16MP.
Supports stereo sound output.
5×PCIe2.1(Combination of x2+x2+x1,5Gbps/Lane)
1×USB3.0(Combo PCIe2.1 x1)
2×USB2.0(OTG + Host)
2×GMAC(RGMII&1000M)
4×SPI、7×I2C、12×UART、2×CAN-FD、30×PWM
Bianbu OS
Linux(Mainstream distribution versions)
RTOS
Package type:FCCSP
Pin pitch:0.65mm == Power Consumption
TDP: 3~5W
