Banana Pi BPI-F5 design with Allwinner Octa-core ARM Cortex-A55 T527 chip design.have a RISC-V CPU, up to 200 MHz,HiFi4 Audio DSP,ARM G57 MC1 GPU,Up to 2 TOPS NPU, support 2/4G RAM and 8-32G eMMC.
Allwinner T527 Octa-core A55, NPU up to 2Tops for edge intelligent AI applications.
T527 series is a high-performance embedded processor with optional AI function in the field of intelligent industrial control and automotive. It is suitable for embedded devices with media and AI functions such as high-performance industrial robots, display and control all-in-one machines, edge intelligent boxes and vehicle terminals.
T527 is used in commercial display/cash register, cloud computer, robot, industrial intelligence, edge computing gateway, post-installation central control, commercial vehicle, industrial computer and other fields
| Main spec for Allwinner T527 chip | |
CPU |
Octa-core ARM Cortex-A55 in a DynamlQ big.LITTLE configuration, up to 1.8 GHz |
32KB L1 I-cache and 32KB L1 D-cache per A55 core |
Optional 64KB L2 cache per“LITTLE”core |
Optional 128KB L2 cache per“big”core |
GPU |
ARM G57 MC1 GPU |
Supports OpenGL ES 3.2/2.0/1.1, Vulkan 1.1/1.2/1.3, and OpenCL2.2 |
Anti-aliasing algorithm |
High memory bandwidth and low power consumption in 3D graphics processing |
NPU |
2 TOPS NPU |
Embedded 512KB internal buffer |
Supports deep learning frameworks:TensorFlow, Pytorch, Caffe, Onnx NN, TFLite… |
Video decoder |
H.265 MP decoder up to 4K@60fps |
H.264 BL/MP/HP decoder up to 4K@30fps |
VP9 decoder up to 4K@60fps |
Multi-format 1080p@60fps video playback,including VP8,MPEG1/2SP/MP,MPEG4,SP/ASP,AVS+/AVS JIZHUN |
Video encoder |
H.264 encoder up to 4K@25fps |
MJPEG encoder up to 4K@15fps |
JPEG encoder up to 8K x 8K resolution |
Audio DSP |
HiFi4 Audio DSP,Frequency up to 600MHz |
32KB I-cache +32KB D-cache |
widely used in the special fields of image, audio and digital signal processing to provide exclusive computing power for audio and video entertainment and industrial production |
RISC-V MCU |
Independence RISC-V CPU, up to 200 MHz,support RTOS system |
16 KB I-cache and 16 KB D-cache·RV32IMAFC instructions |
Real-time processing, high-speed response and industrial-grade stable operation on industrial and robotic systems provide important guarantees |
Display |
HDMI2.0b up to 4K@60fps |
4+4-lane MIPI-DSI output,supporting up to 2.5K@60fps and 4K@45fps |
2xLVDS interface with dual link, up to I080p@60fps |
2xRGB interfaces with DE/SYNC mode, up to I080p@60fps |
eDP1.3 up to 2.5K@60fps and 4K@30fps |
Camera |
Parallel CSl interface:8/10/12/16-bit width,Supports BT.656 up to 4720P@30fps and BT.1120 up to 41080P@30fps |
MIPI CSI interface:24 lane/42 lane/4+2*2 lane MIPICSI,flexible combination, up to 2.0 Gbit/s per lane in HS transmission,compliant with MIPI-CSI2V1.1 and MIPI DPHYV1.1 Maximumvideocaptureresolution of 8M@30fps |
SoC: Allwinner T527
CPU: Octa-core ARM Cortex-A55 in a DynamlQ big.LITTLE configuration, up to 1.8 GHz
GPU: ARM G57 MC1 GPU
NPU: Up to 2 TOPS (INT8), Embedded 512KB internal buffer
RISC-V MCU for Real-time operating system (etc:RTOS)
DSP: 600MHz HiFi4
RAM: 2GB/4GB(max 4GB), default 4GB LPDDR4x
Storage: 8GB/32GB eMMC, default 32GB eMMC
Industrial grade temperature: -40°C to 80°C
| Allwinner T527 Datasheet |
Baidu Cloud: https://pan.baidu.com/s/1IY2uEspzYj9M3otU1HY3mw?pwd=8888 (pincode:8888)
| AXP323&AXP717C Datasheet |
Baidu Cloud: https://pan.baidu.com/s/1_m6JpbHnr2OT8hIIH3DC-g?pwd=8888 (pincode:8888)
