Allwinner A20 design: Banana Pi BPI-M1 SBC Allwinner A20 design: Banana Pi BPI-M1+ SBC Allwinner A20 design: Banana Pi BPI-R1 Router Allwinner R64 design: Banana Pi BPI-M64 SBC Allwinner A83T design: Banana Pi BPI-M3 SBC |
Allwinner A83T Octa-core 1.8GHz Powerful CPU
2 GB LPDDR3 memory
8 GB eMMC storage
HDMI out
IR control
WiFi & Bluetooth onboard
MIPI DSI ingerface
CSI camera interface
| HardWare Specification of Banana Pi M3 | |
CPU |
Allwinner A83T ARM Cortex-A7 Octa-Core 1.8 GHz, 512KB L1 cache and 1MB L2 cache |
GPU |
PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
Memory |
2 GB LPDDR3 (shared with GPU) |
Storage |
On Board 8GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port (USB-to-SATA bridge) |
Network |
10/100/1000 Mbit/s Ethernet (Realtek RTL8211E/D) + Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
Video Input(s) |
A CSI input connector allows for the connection of a designed camera module |
Video Output(s) |
HDMI 1.4 (Type A Full), MIPI Display Serial Interface (DSI) for raw LCD Panel |
Audio Input(s) |
On board microphone |
Audio Output(s) |
3.5mm jack and HDMI |
USB ports |
USB 2.0 PORT (x2), USB OTG (x1) |
Remote |
IR Receiver (x1) |
GPIO |
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). Some of I/O Pin can be used for specific functions as UART, I2C, SPI or PWM |
Switches |
Reset, Power and U-boot |
LED |
Power Status and 8P8C |
Power Source |
5 volt @2A via DC Power and/or Micro USB (OTG) |
Size & Weight |
92x60mm, 48g |
OS |
Android and Linux |
| 40 PIN GPIO of Banana pi BPI-M3 | |||
GPIO Pin Name |
Default Function |
Function2:GPIO |
Function3 |
CON1-P01 |
VCC-3V3 |
CON1-P02 |
DCIN |
CON1-P03 |
TWI2-SDA |
PH5-EINT5 |
CON1-P04 |
DCIN |
CON1-P05 |
TWI2-SCK |
PH4-EINT4 |
CON1-P06 |
GND |
CON1-P07 |
S-PWM |
PL10-S-EINT10 |
CON1-P08 |
UART2-TX |
PB0-EINT0 |
CON1-P09 |
GND |
CON1-P10 |
UART2-RX |
PB1-EINT1 |
CON1-P11 |
PC4 PC4 |
CON1-P12 |
UART2-CTS |
PB3-EINT3 |
CON1-P13 |
PC7 |
PC7 |
CON1-P14 |
GND |
CON1-P15 |
PC17 |
PC17 |
CON1-P16 |
UART2-RTS |
PB2-EINT2 |
CON1-P17 |
VCC-3V3 |
CON1-P18 |
PL8-ENT8 |
PL8-S-ENT8 |
CON1-P19 |
SPI0_MOSI |
PC0 |
CON1-P20 |
GND |
CON1-P21 |
SPI0_MISO |
PC1 |
CON1-P22 |
PL9-EINT9 |
PL9-S-EINT9 |
CON1-P23 |
SPI0_CLK |
PC2 |
CON1-P24 |
SPI0_CS |
PC3 |
CON1-P25 |
GND |
CON1-P26 |
PH10-ENT10 |
PH10-ENT10 |
CON1-P27 |
TWI1-SDA |
PH3-EINT3 |
CON1-P28 |
TWI1-SCK |
PH2-EINT2 |
CON1-P29 |
PC18 |
PC18 |
CON1-P30 |
GND |
CON1-P31 |
I2S1-BCLK |
PG10-EINT10 |
UART3-TX |
CON1-P32 |
I2S1-DIN |
PG13-EINT13 |
UART3-CTS |
CON1-P33 |
I2S1-LRCK |
PG11-EINT11 |
UART3-RX |
CON1-P34 |
GND |
CON1-P35 |
I2S1-DOUT |
PG12-EINT12 |
UART3-RTS |
CON1-P36 |
PE5 |
PE5 |
CON1-P37 |
PE4 |
PE4 |
CON1-P38 |
OWA-DOUT |
PE18 |
CON1-P39 |
GND |
CON1-P40 |
PE19 |
PE19 |
| CSI camera GPIO of Banana pi BPI-M3 | ||
CSI Pin Name |
Default Function |
Function2:GPIO |
CN7-P01 |
IPSOUT |
CN7-P02 |
AFVCC |
CN7-P03 |
IPSOUT |
CN7-P04 |
IOVDD |
CN7-P05 |
GND |
CN7-P06 |
GND |
CN7-P07 |
CSI2-D3N |
CN7-P08 |
AVDD-CSI |
CN7-P09 |
CSI2-D3P |
CN7-P10 |
DVDD-CSI-R |
CN7-P11 |
GND |
CN7-P12 |
NC |
CN7-P13 |
CSI2-D2N |
CN7-P14 |
CSI-RST-R |
PE16 |
CN7-P15 |
CSI2-D2P |
CN7-P16 |
CSI-STBY-R |
PE17 |
CN7-P17 |
GND |
CN7-P18 |
CSI-PCLK |
PE0 |
CN7-P19 |
CSI2-CKN |
CN7-P20 |
CSI-MCLK |
PE1 |
CN7-P21 |
CSI2-CKP |
CN7-P22 |
CSI-HSYNC |
PE2 |
CN7-P23 |
GND |
CN7-P24 |
CSI-VSYNC |
PE3 |
CN7-P25 |
CSI2-D1N |
CN7-P26 |
CSI-D9 |
PE13 |
CN7-P27 |
CSI2-D1P |
CN7-P28 |
CSI-D8 |
PE12 |
CN7-P29 |
GND |
CN7-P30 |
CSI-D7 |
PE11 |
CN7-P31 |
CSI2-D0N |
CN7-P32 |
CSI-D6 |
PE10 |
CN7-P33 |
CSI2-D0P |
CN7-P34 |
CSI-D5 |
PE9 |
CN7-P35 |
GND |
CN7-P36 |
CSI-D4 |
PE8 |
CN7-P37 |
CSI-SCK |
PE14 |
CN7-P38 |
CSI-D3 |
PE7 |
CN7-P39 |
CSI-SDA |
PE15 |
CN7-P40 |
CSI-D2 |
PE6 |
| MIPI DSI PIN define of Banana pi BPI-M3 | ||
CSI Pin Name |
Default Function |
Function2:GPIO |
CN6-P01 |
VCC-MIPI |
CN6-P02 |
IPSOUT |
CN6-P03 |
VCC-MIPI |
CN6-P04 |
IPSOUT |
CN6-P05 |
GND |
CN6-P06 |
IPSOUT |
CN6-P07 |
GND |
CN6-P08 |
IPSOUT |
CN6-P09 |
NC |
CN6-P10 |
GND |
CN6-P11 |
NC |
CN6-P12 |
DSI-D0N |
CN6-P13 |
NC |
CN6-P14 |
DSI-D0P |
CN6-P15 |
NC |
CN6-P16 |
GND |
CN6-P17 |
TWI0-SDA |
PH1-EINT1 |
CN6-P18 |
DSI-D1N |
CN6-P19 |
TWI0-SCK |
PH0-EINT0 |
CN6-P20 |
DSI-D1P |
CN6-P21 |
TP-INT |
PL7-S-EINT7 |
CN6-P22 |
GND |
CN6-P23 |
TP-RST |
PL6-S-EINT6 |
CN6-P24 |
DSI-CKN |
CN6-P25 |
GND |
CN6-P26 |
DSI-CKP |
CN6-P27 |
LCD-BL-EN |
PD29 |
CN6-P28 |
GND |
CN6-P29 |
LCD-RST |
PD26 |
CN6-P30 |
DSI-D2N |
CN6-P31 |
LCD-PWR-EN |
PD27 |
CN6-P32 |
DSI-D2P |
CN6-P33 |
GND |
CN6-P34 |
GND |
CN6-P35 |
LCD-PWM |
PD28 |
CN6-P36 |
DSI-D3N |
CN6-P37 |
GND |
CN6-P38 |
DSI-D3P |
CN6-P39 |
AP-RESET# |
CN6-P40 |
GND |
CON2 P03 |
UART0-TXD |
PB9 |
CON2 P02 |
UART0-RXD |
PB10 |
CON2 P01 |
GND |
| BPI-M3 Linux BSP code : https://github.com/BPI-SINOVOIP/BPI-M3-bsp |
| BPI-M3 android 5.1 source code : https://drive.google.com/open?id=0B\_YnvHgh2rwjaGhIeUE0eERTZU0 |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| BPI-M3 schematic diagram :google driver |
| BPI-M3 DXF file : https://drive.google.com/file/d/0B4PAo2nW2KfnNm54VjBlUXhXekU/view |
| BPI-M3 3D design file : https://drive.google.com/file/d/0B4PAo2nW2KfnYXVGWXBURDFSeTA/view |
| A83T chip Datasheet V1.4 : https://drive.google.com/file/d/0B4PAo2nW2KfnM2VqeTR3SXpGdVE/view?usp=sharing |
| Allwinner A83T chip User_Manual V1.5.1 : https://drive.google.com/file/d/0B4PAo2nW2KfnRjlQaU9uR0J0elE/view?usp=sharing |
| Android 5.0 development document(chinese): https://drive.google.com/file/d/0B4PAo2nW2KfnekpvMnlNZ2p6NWs/view?usp=sharing |
| Allwinner chip online datasheet and documents : http://dl.linux-sunxi.org/ |
| Linux-sunxi wiki : http://linux-sunxi.org/Banana_Pi_M3 |
| BPI-M3 quality guarantee |
BPI-M3 WIFI Lab test report : https://bananapi.gitbooks.io/bpi-m3/content/en/bpi-m3wifilabtest.html
BPI-M3 Validation test report : https://bananapi.gitbooks.io/bpi-m3/content/en/bpi-m3validationtest.html
BPI-M3 CE,FCC RoHS Certification : http://forum.banana-pi.org/t/bpi-m3-ce-fcc-rohs-certification/984
| How to burn Linux image to eMMC : https://bananapi.gitbooks.io/bpi-m3/content/en/howtoburnlinuximagetoemmc.html |
| GPU for kernel 3.4 : https://bananapi.gitbooks.io/bpi-m3/content/en/gpuforkernel34.html |
| How to rotate display screen : https://bananapi.gitbooks.io/bpi-m3/content/en/howtorotatedisplayscreen.html |
| How to use fatload uEnv.txt & script.bin & kernel uImage : https://bananapi.gitbooks.io/bpi-m3/content/en/howtousefatloaduenvtxtscriptbinkernel_ui.html |
| How to burn android image to eMMC under windows : https://bananapi.gitbook.io/bpi-m3/zh/how_to_burn_android_image_to_emmc |
| BPI-M3 How to control GPIO on Android : https://bananapi.gitbook.io/bpi-m3/zh/howtosetupdockerenvtobuildgithubsourcecod |
| 2018-06-05 update |
HDMI-Version
Baidu Cloud : https://pan.baidu.com/s/1byqwqzz9SOIWHYfOabXKNw
LCD-Version
Baidu Cloud : https://pan.baidu.com/s/19l7a6Z75FuZb_f9Ls0fN5w
| 2017-05-11 update |
HDMI-Version
Baidu Cloud : https://pan.baidu.com/s/1pKF3Ggj
MD5: d7b7abf3443a49fb0f178ccf2f6e82d0
LCD-Version
Baidu Cloud : https://pan.baidu.com/s/1mi2YOeG
MD5: b27dd45ac5fd1fd3b02db8ffd92c2871
| 2021-08-03 release, Ubuntu Mate Desktop 16.04 with kernel 3.4.39 |
MD5: 4cd6cfb9ed3a2d382dbc32bb478ac149
| 2021-08-03 release, Ubuntu Server 16.04 with kernel 3.4.39 |
MD5: ea5abe3fd6988931df85a2376808501a
| 2018-07-18 BPI-M3 Ubuntu 16.04 Mate Desktop (new eMMC) |
Baidu Drive : https://pan.baidu.com/s/1ND5QqoBevzM2TykwqZCkAA
Forum pthread: http://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-new-emmc-ubuntu16-04-debian9-release-2018-07-18/6294
| 2018-07-18 M3 Ubuntu Server (new eMMC) |
Baidu Drive : https://pan.baidu.com/s/10vSo0AmIiMrVLNPkQ63leQ
| 2018-05-31 update ubuntu 16.04 mate desktop |
HDMI verison baidu cloud : https://pan.baidu.com/s/1UDktbDgGtXpbqIZn_TI1Tg
| 2017-07-13 update ubuntu 16.04 mate desktop |
HDMI version
Baidu cloud : http://pan.baidu.com/s/1nu6hJs9
Forum pthread: http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-ubuntu-16-04-mate-desktop-beta-bpi-m3-ov8865-sd-emmc-2017-07-13/3542
LCD 7 verison
Baidu cloud : http://pan.baidu.com/s/1o8Uc4Y2
Forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-m3-new-image-ubuntu-16-04-mate-desktop-beta-bpi-m3-lcd7-ov8865-sd-emmc-img-2017-7-13/3543
LCD 5 Version
Baidu cloud : http://pan.baidu.com/s/1hsIJygG
| 2018-07-18 BPI-M3 Debian Jessie 9 (new eMMC) |
Baidu Drive : https://pan.baidu.com/s/1yQYG1iOEIrJADV_j-qvdwQ
| 2021-08-03 release, Raspbian Stretch with kernel 3.4.39 |
MD5: a9890cedbd779a29ff551a7fc5e1eae6
| 2018-5-28 update : Raspbian 8.0 V1.1 |
Baidu cloud : https://pan.baidu.com/s/1Pz_6btHxj6F9w_6aw90Dww
| Armbian_23.02.0-trunk_Bananapim3_jammy_edge_6.1.11_xfce_desktop.img |
| Armbian_23.02.0-trunk_Bananapim3_bullseye_edge_6.1.0_xfce_desktop.img |
Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-bpi-m3-new-armbian-image/15138
| 2022-12-06 Armbian_22.11.0-trunk_Bananapim3_bullseye_edge_6.0.9.img.xz |
Baidu Cloud: https://pan.baidu.com/s/18M5Tsc91z57NUzBm4rcqlg?pwd=8888 (pincode: 8888)
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m3-new-image-release-armbian-bullseye/14450
| 2022-09-07 Armbian_22.11.0-trunk_Bananapim3_jammy_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1FjNBqpJ0Kv83EpiKt9sZmw?pwd=mtk5 (pincode: mtk5)
| 2022-09-07 Armbian_22.11.0-trunk_Bananapim3_bullseye_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1w00wkfX15G6D60W2WH52ug?pwd=awza (pincode: awza)
| Armbian with 4.17.y for M3 |
Test build: http://ix.io/1fUK
Broken: wired, wireless network, Bluetooth, …
Works: serial console, 8 cores, DVFS, USB, SATA, HDMI, DRM video driver, …
Forum pthread: http://forum.banana-pi.org/t/armbian-with-4-17-y-for-m3/6174
| FreeBSD on Allwinner (sunxi) systems for banana pi |
Allwinner A20 (sun7i), a dual-core Cortex-A7 BPI-M1/BPI-M1+/BPI-R1
Allwinner A31 and A31s (sun6i), a quad-core Cortex-A7 BPI-M2
Allwinner A64 (sun50i), a quad-core Cortex-A53 BPI-M64
Allwinner A83T (sun8i), an octa-core Cortex-A7 BPI-M3
Allwinner H3 (sun8i), a quad-core Cortex-A7 BPI-M2+/BPI-M2+ EDU/
| Simplenas image : https://simplenas.com/download/other/banana-m3 |
Banana Pi M2+ with H3 chip
Banana Pi M3 with A83T chip
BPI-M1 and BPI-M1+ use A20 chip
More about this : https://bananapi.gitbooks.io/bpi-m3/content/en/lakkatv.html
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-m3.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M3/1100417230_40000003593419.html |
| Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M3/1101951077_40000003551100.html |
| OEM&ODM, please contact: [email protected] |
