Banana Pi BPI-RV2 open source gateway is a device based on Siflower SF21H8898 SoC, 1 × 2.5G WAN network interface, 5 Gigabit LAN network interface, onboard 512MB DDR3 memory, 128 MiB NAND, 16 MiB NOR, M.2 interface, MINI PCIE and USB 2.0 interface, etc.
Banana Pi BPI-RV2 open source gateway is a collaboration between Siflower and Banana Pi open source community (Banana Pi)
SF21H8898 is a high performance industrial-grade SOC gateway chip developed by Siflower Communications. It adopts advanced TSMC 12nm FFC process and integrates four cores inside 64-bit RISC-V processor and dedicated network processing accelerator (NPU) (supports L2/L3 hardware processing, IPv4/IPv6 dual stack, 20Gbps switching capacity, full byte wire-speed forwarding), network-side support for QSGMII, SGMII/HSGMII and RGMII interfaces. IEEE 1588 PTP functionality is supported for time synchronization. It supports external DDR3/DDR3L/DDR4 SDRAM and NAND/NOR SPI Flash. The high-speed interface is USB2.0, PCIE2.0, and the low-speed interface is SPI, UART, I2C, PWM, etc. It can be used as enterprise gateway and industrial control gateway.
Siflower SF21H8898 4 core RISC-V processor
With Siflower NPU, enterprise-class gateway level data forwarding processing capability can be achieved.
512MB DDR3 RAM
1 x 2.5GbE network and 5 x giga port
128 MB SPI NAND and 16 MB SPI NOR flash Ensure that the onboard system is indestructible,
M.2 2242/2230 interface support NVMe SSD (PCIe gen 2 x1)
RTC
PoE Network power support
| item | introduce |
SoC |
Siflower SF21H8898 4 core RISC-V @ 1.25GHz |
RAM |
512MB DDR3 |
Storage |
128 MB SPI NAND Flash is used in U-boot and Linux systems |
16 MB SPI NOR flash,For U-boot and Linux systems, write protected by default (refresh can be enabled by jumper) |
M.2 2242 interface support NVMe SSD hardsik(PCIe gen 2 x1) |
Network |
1 x 2.5GbE RJ45 port |
5 x giga RJ45 port |
USB |
Use the USB Type-C (device, console) port of the UART to USB chip |
1x USB 2.0 Type-A USB HOST port |
PCIE |
M2 keyB, Supported Rates PCIe gen 2 x1,Can be used to connect SSD hard drives, 5G modules, etc |
MINI PCIE,Supported Rates PCIe gen 2 x1,Can be used to connect WiFi module, wired network card, etc |
Debug |
Console connected via USB-C port or 3-pin connector |
RTC |
Support for on-board RTC real-time clock |
Others |
Reset and user buttons |
Boot choose:NAND(normal) Or NOR(Reset) |
(I2C interface) RTC,Backup battery holder with CR1220 button battery |
support add 802.3at/af PoE module |
Size |
148 x 100.5 mm |
| OpenWrt 24.10, kenrnel 6.6 source code : https://github.com/BPI-SINOVOIP/BPI-RV2-SF21H8898-OPENWRT-24.10-BSP |
| Source code on github: https://github.com/BPI-SINOVOIP/BPI-RV2-SF21H8898-OPENWRT-BSP |
| U-Boot Source code |
Baidu cloud: https://pan.baidu.com/s/1oFlxdsLcUN_kqV2d78iP7Q?pwd=8888 (pincode: 8888)
Siflower SF21H8898 chip datasheet
Google drive: https://drive.google.com/file/d/1BVvNwteQebjtbWdKuvHRDl12ohuWtIpZ/view?usp=sharing
Baidu cloud: https://pan.baidu.com/s/1d1V4fodomJYZRdPHk9-Qrw?pwd=8888 (pincode: 8888)
BPI-RV2 Schematic
Google drive: https://drive.google.com/file/d/1AUH27rbHZarVmgD7Y-irOCWQNWNwVC_t/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1ZJlW8xOOzvRHRbktJM2vHA?pwd=8888 (Pincode: 8888)
BPI-RV2 DXF file
Google drive: https://drive.google.com/file/d/1dsvwKbeDpPVPoz0bbb2n4Rpo1a0yZN8x/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/19OnUj3bEN9saLANb9LIxIQ?pwd=8888 (pinoode): 8888
BPI-RV2-V11-assambly
Google drive: https://drive.google.com/file/d/1Aa1punVTgTtPJT75dnekCCEEUEFzQSCV/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1U8mPcXFSnxlmiB_qd81TZg?pwd=8888 (pincode: 8888)
| Compiled using BPI-RV2-SF21H8898-OPENWRT-BSP |
Baidu cloud: https://pan.baidu.com/s/1sgFzscEDuJYMsh8jrB8wAw?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1SCI74X2x0MYWqiep45r7E3eOb2LXayvI/view?usp=sharing
Baidu cloud: https://pan.baidu.com/s/1iMbPKkwKE8es1hW1Zy6AGg?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1Szv0ARqT30inLvEWdtbdD-EcZanYq3Rp/view?usp=sharing
Baidu Cloud: https://pan.baidu.com/s/1LL1mbWxmWMhUYw_-db9pMw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1K2CJ0Uco6LmCNopPUk5Qn8fcHV5NQXmY/view?usp=sharing
| Compiled using BPI-RV2-SF21H8898-OPENWRT-24.10-BSP |
Baidu cloud: https://pan.baidu.com/s/1I5yS0DaubCmg2r8aWbLMyQ?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/file/d/1unNID1V0dsaWJZpz868v_nbUeC9AXPFK/view?usp=sharing
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-rv2-risc-v-gateway-board-design-with-siflower-sf21h8898-chip-design.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/item/3256808648294805.html?gatewayAdapt=4itemAdapt |
| Bipai Aliexpress Shop: https://www.aliexpress.com/item/3256808648467727.html?gatewayAdapt=4itemAdapt |
| Taobao Shop: https://item.taobao.com/item.htm?id=911397743956&spm=a213gs.v2success.0.0.4f2348313LU7Ma |
| BPI-RV2 case SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/1005009130374990.html |
| BPI-RV2 case BIPAI Aliexpress shop: https://www.aliexpress.com/item/1005009130612951.html |
| BPI-RV2 case Taobao shop: https://item.taobao.com/item.htm?id=828591909710&spm=a213gs.v2success.0.0.41b74831L8aQQs |
| OEM&ODM, please contact: [email protected] |
