Banana Pi BPI-S64 core use Actions SOC S700 design. S700 chip with ARM Cortex-A53 Quad-Core CPU,Mali450 MP4 GPU. BPI-S64 core with 2G LPDDR3 and 8G eMMC flash onboard.
BPI-S64 core modules are small enough to fit all kinds of hardware.In addition,S64 core also provides I/O boards with GPIO ports, as well as USB, MicroUSB, CSI, DSI, HDMI, and MicroSD and other many interfaces.
CPU: Actions SOC S700,ARM Cortex-A53 Quad-Core CPU
GPU:Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5
2GB LPDDR3
8GB eMMC flash onboard
| HardWare Specification of Banana pi BPI-S64 core | |
CPU |
Actions SOC S700,ARM Cortex-A53 Quad-Core CPU,Mali450 MP4 GPU |
Memory |
2GB LPDDR3 |
Storage |
8GB eMMC |
interface |
SODIMM-DDR3,204 PIN , all S700 GPIO support |
size |
67.5 x 30 mm |
| HardWare Specification of Banana pi BPI-S64 core kit | |
CPU |
GPU |
Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5 |
Memory |
2GB LPDDR3 |
Storage |
8GB eMMC |
Power |
5V @ 2A via DC power |
Low-level peripherals |
26 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. |
Onboard Network |
1 x 10/100/1000Mbps Ethernet |
Wifi/Bluetooth |
AP6212 WiFi and BT 4.0 |
On board Storage |
MicroSD \(TF\) card; 8G eMMC;SIM card slot |
Display |
HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP ;LVDS |
Video decoder/encode |
support Real-time vide decode of most popular vide formats ,such as MPEG-4,H.264,H.265. support video encoder for baseline H.264 |
Audio |
support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 1 MIC in |
HDMI Out/In |
1* HDMI 1.4 |
Audio outputs/Inputs |
HDMI, I2S audio,Audio micro out |
4G |
USB standard 4G LTE interface |
USB 3.0 |
1x USB 3.0 host |
USB 2.0 |
1x USB 2.0 OTG, 1 x USB port |
Display |
1* Mini DP ,1* LVDS lcd, |
Camera |
1 x DVP camera interface ,1 x MIPI interface |
RTC battery |
RTC battery power interface |
battery |
3.7V battery interface. |
Buttons |
Reset button, Power button, ADC button |
Leds |
Red, Green, Blue |
Other |
IR reciever |
Sizes |
Power |
DC 5V/2A |
Weight |
150g |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
