More about this project ,please see :
Awinner A40I for Industrial control gateway design
Realtek RTD1296 Intelligent voice, video processing platform
MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53
(1-2)G DDR and 8G eMMC flash
1x5G port , Use USB 3.0 or PCIe bus.
4x4G LTE , support OpenMPTCProuter Multiple polymerization protocol.
5xGigabit port. support VPN ,router function.
wifi 802.11 b/g/n/ac function support.
IoT expanding application
Base on Banana Pi BPI-R64 hardware design
Moere,please see here:
Discuss on forum : http://forum.banana-pi.org/t/bpi-4-0-bpi-r64-for-5g-4g-lte-wifi-ac-gigabit-for-converged-communication-gateway/9555
Use ESP32 design , suppor WiFi and BT to connect network.
More Spec ,please see :
More Spec,please see : http://forum.banana-pi.org/t/bpi-4-0-4g-lte-router-design/9277
Dojo official webstie: https://dojo.bullguard.com/
PCBA base on BPI-M3 with allwinner A83T chip design
Forum discuss: http://forum.banana-pi.org/t/banana-pi-bpi-4-0-oem-odm-project-magic-mirror-base-bpi-m3-allwinner-a83t-chip-design/7410
This is base on BPI-R2, with 4 4G module desin. We can work with our customers to provide overall solutions
Chassis design file : https://drive.google.com/file/d/1C9LuXVgexsUN3K8DqApFNG4FLpwn54Ms/view?usp=sharing
Product website: https://www.aixiaocao.com/
| 2018-10-12 update, OpenMPTCProuter use MultiPath TCP (MPTCP) to aggregate multiple Internet connections and OpenWrt. and have official support BPI-R2. |
Image download: https://www.openmptcprouter.com/download
Source code on github: https://github.com/Ysurac/openmptcprouter
Pcba inside:
Case design:
SIZE: two-deck, 88x88 mm
CPU Chipset: A20 ARM Cortex™-A7 Dual-Core 1 GHz
GPU Chipset: ARM Mali400MP2Complies with OpenGL ES 2.0/1.1
Memory: 1 GB DDR3
Storage Slot: micro SD Card 16G Bytes
Network Ethernet: – 10/100/1000Mbps WAN x 1 – 10/100/1000Mbps LAN x 4
WIFI: – 3x 2.4GHz, Support IEEE 802.11b/g/n,Up to 300Mbps – 1x 5GHz,Support IEEE 802.11a/n/ac,Up to 433Mbps – External High-Gain Antenna 2.4GHz x3,5GHz x1 –WIFI model MT7632 or AP6335
4G LTE – SimCom Sim7100C, FDD B3 LTE 1800, – Model SIM7100C – External High-Gain Antenna 4G x1
USB: USB Host 2.0 x 1
CAMERA: Camera x 1, Screen resolution HD 1280x720 pixels, 30 FPS, UVC H.264 encoding technology, CSI Connector
AUDIO Input: Microphone x 1
VIDEO Outputs: HDMI out x 1
AUDIO Outputs: 3.5mm Jack and HDMI
SPEAKER: BP-5032-44, 1xSpeaker, Diameter 50mm, Depth 32mm, Power 4w, Impedance 4±15%Ω
KEY: POWER KEY x 1 Touch Sensor Power Button RESET KEY x 1
LED: RJ45 LED (Upload, Download) x 5 WIFI LED (2.4G, 5.8G) x 2 POWER STATUS LED x 1 GPIO LED (4 pins LED) x 1 USB LED x 1 CAMERA LED x 1 4G LED x 1 AUDIO LED x1 MICROPHONE LED x1
Debugging: Serial Console, JTAG
Reserved Pin: GPIO PIN x 26, UART, 12C bus, SPI bus with two chip selects, CAN bus, ADC, PWM, +5V, +3.3V, GND
IR Receiver: x1
Power Source: Micro-USB Power DC 5V/2A
Battery: Li-ION 4400 mAh 3.7V, Battery Connector: x1
Adaptor: DC Adaptor 5V/2A with micro-USB cable
Easy to add zigbee, z-wave ,NB-IoT and other IoT function.
What we do : hardware design, quantity production
This product is for STEAM education with KANO scratch app:
Image download link: https://www.eblocker.com/en/download/
PCBA inside:
PCBA inside:
4G watch PCBA:
4G watch Spec
Interface Configuration:
Software Configuration:
Necessary Accessories:
