BPI-3A6000 is a Mini PC developed by Banana Pi open source community Loongson 4th-generation 3A6000 processor + Loongson 7A2000 bridge chip.
BPI-3A6000 can be applied to enterprise office, personal minicomputs, high-performance industrial computer, as well as education, medical, finance, edge computing and other fields. It has the advantages of high performance computing, portability, low energy consumption and easy management. The Loongson BPI-3A6000 MINIPC supports two DDR4 SODIMM slots, the memory rate is 3200M, a single memory supports 8GB/16GB/32GB, and the maximum memory capacity is 32GB. Storage Supports one M.2 2280-size NVME SSD slot and one 2.5-inch SATA disk expansion.
BPI-3A6000 Longson minicomputeruses mini case design, unique high density heat dissipation structure design, high performance, high density and high reliability in one; It is easy to move and saves space when it meets various application scenarios.
Loongson 3A6000 design: Banana Pi BPI-3A6000 Industrial grade Mini PC Loongson 2K1000 design: Banana Pi BPI-5202 Embedded single board industrial computer |
In addition to conventional computing applications, the BPI-3A6000 can also be pre-installed with the following industrial control applications, including but not limited to:
300+ Industry general/industry specific protocol library
Video access transmission/control/recording/linkage function
Computational programming capabilities
Industrial firewall function
Soft PLC programming function
C/S architecture SCADA system functions
B/S architecture SCADA system functions
Mini size
The volume of the whole machine is less than 1L, which is 40 times smaller than the desktop
Small size, easy to carry, easy to organize, one hand
Can support wall hanging, can be hung behind the monitor/TV series, save desktop space
High performance
Using the fourth generation of Loongson 3A6000 CPU+7A2000 bridge
Supports two DDR4 SODIMM slots
Supports memory rates up to 3200Mbps
Supports multiple CPU cores, up to 4 physical cores and 8 logical cores
High reliability
Advanced memory fault-tolerant ECC function (currently not supported by existing BIOS)
The use of all copper fin cooling architecture, so that the CPU performance is fully developed, full load performance is still reliable
Support intelligent speed adjustment function, the fan speed dynamically adjusts with the system temperature, effectively reducing the system noise and power consumption
Interface rich
Multiple interface types, can meet the needs of multiple scenarios at the same time
Dual display interface to achieve dual 1080P output at the same time, create a multi-screen working environment, improve efficiency and entertainment experience
NVMe and SATA interface dual hard disk design, easy to expand, increase storage space
| Banana Pi BPI-3A6000 Hardware Specifications | |
Type |
Specifications |
CPU |
the fourth generation of Loongson 3A6000 4-core 8-thread processor, 2.0-2.5GHz |
Large capacity Level 3 cache (64KB/256KB/16MB) |
RAM |
2 x memory slots |
Supports the DDR4 3200 memory rate |
Maxs support 32GB memory |
only support SODIMM |
Flash |
support 1 个 M.2 2280 NVMe SSD (PCIE3.0 x4 ) |
Display |
2 x HDMI display interface,Built-in bridge GPU,1GB video memory,maximum resolution 1920x1080 |
WIfi |
support dual-band wireless WiFi 5G/2.4G,support 802.11AC |
support Bluetooth 5.0(RTL8822CE wireless network card does not support Bluetooth) |
External interface |
2 x USB 3.0 |
1 x TypeC PD,Support data transmission and external power supply (PD3.0 fast charge protocol) |
4 x USB2.0 |
2 x HDMI |
2 x RJ-45 Gigabit network |
1 x 3.5mm Headphone/microphone audio |
Reserved debugging interface |
1 x TTL level UART debugging interface,2.54mm |
1 x LA-JTAG interface,Mainly used for CPU debugging |
Size |
156mm x 154mm x 42 mm(长 x 宽 x 高) |
Power Supply |
Maximum power consumption: no more than 80W |
Adapter spec:DC19V 3.42A, 5.5/2.5mm |
cooling system |
1 x special custom cooling module |
operating system |
Loongnix/UOS/Kylin OS; |
Operating system support is subject to change without notice |
| Item | explain |
operating temperature |
0℃~+70℃ |
storage temperature |
-40~+80℃ |
operating humidity(RH) |
5%~95% non-condensing |
Storage Humidity(RH) |
altitude |
<5000m |
lightning protection |
Built-in lightning protection element, support outdoor use, in line with high-level EMC standards |
level of protection |
IP40 |
heat-dissipating method |
Fans&Heatsink |
electromagnetic compatibility |
EMC III grade, |
GB/T17626、GB/T15153、IEC61850-3、EN61000-6-5 |
safety standard |
GB/T7621-2008 |
CE certification |
CE & FCC &RoHS |
In addition to PCBA design and production, Banana Pi open source community can also provide Loongson Mini PC complete machine, so that users can quickly complete the standard product design. CNC aluminum housing
| ID | interface | ID | interface |
1 |
USB 3.0,TYPE-C |
2 |
USB 3.0,TYPE-A |
3 |
PD,TYPE-C |
4 |
Power |
interface explanation:
| Name | type | quantity | explain |
USB3.0 |
TYPE-C |
1 |
standard Type-C,support PD protocol fast charge, maximum support 15W |
USB3.0 |
TYPE-A |
2 |
standard USB3.0 TYPE-A |
1 |
Wifi antenna interface |
2 |
Power input interface |
3/4 |
USB 2.0 |
5 |
HDMI out |
6 |
Network |
7 |
Audio +MIC interface |
Power input |
5.5/2.5mm |
1 |
DC 19V/65W,3.42A |
USB |
USB 2.0 TYPE-A |
4 |
USB supports hot swap of storage devices |
HDMI out |
HDMI 1.4 |
2 |
To output video, use an HDMI video cable to connect the video output port to the display. |
LAN |
RJ-45 |
2 |
Supports 1000M/100M/10M auto-adaptation, But the BIOS does not support LAN2 now |
Audio |
Mic/headset jack |
1 |
standard 3.5mm Audio interface, input/output |
