Banana Pi BPI-AI2H System-on-Module (SoM) and BPI-AI2H carrier board are open-source hardware solutions designed to leverage the advanced capabilities of the RZ/V2H Vision AI MPU. Designed with a flexible, community-driven ecosystem, the BPI-AI2H platform empowers developers to accelerate innovation and streamline application development. Powered by the RZ/V2H MPU, it delivers industry-leading AI acceleration via the DRP-AI3 accelerator (8 TOPS/dense, 80 TOPS/sparse) and high-performance computing with 4x Arm® Cortex®-A55 processors, making it an ideal choice for creating cutting-edge vision AI solutions..
Small Form Factor: Compact SO-DIMM 260PINs design (SOM module size: 45x69.6mm)
Open-source development kit, including SOM, BPI-AI2H Carrier board and a rich ecosystem of tools and support from the Banana Pi developer community
Customizable hardware & software by OEM&ODM
Yocto and other open-source software support
Memory & storage: 16GB LPDDR4x, 32GB eMMC, 64MB QSPI Flash
Wide operating temperature range from -40℃ to 85℃
| HardWare Specification of BPI-AI2H | |
SoC |
RZ/V2H |
System Memory |
16GB LPDDR4X |
Storage |
64 MB SPI NAND flash |
32GB eMMC |
SD card Slot |
Button |
Sleep button |
Power button |
recovery button |
Networking |
2 x GbE RJ45 port |
USB |
2x USB 3.0 Type-A port |
1x USB2.0 Type-A On back |
1x USB3.0 Type-A On back |
DSI |
1x MIPI DSI |
CSI |
4x MIPI CSI |
FAN |
PH-3PIN Connector(5V FAN with PWM) |
Debugging |
USB TypeC Console |
M.2 KEY |
M.2 KEYM For SSD (2280) |
RTC |
support RTC onboard(CR1220) |
WiFi |
WiFi module on board |
GPIO |
40PIN GPIO |
Power Supply |
12V USB-PD on USB-C port |
DC12V IN |
Size |
79 x 100 mm compatible with BPI-AI2N |
| V2H datasheet: https://www.renesas.com/en/products/rz-v2h |
Yocto oss package:
Baidu: https://pan.baidu.com/s/1Q6qTbbPI0kPFkrjoeHREyg?pwd=8888 pincode: 8888
| Note: The bootloader binaries are built from the Yocto source code. |
Baidu: https://pan.baidu.com/s/1G7Ze1kp8bEcLqOX9XBjxDg?pwd=8888 pincode: 8888
Baidu: https://pan.baidu.com/s/1LB40au66bcD1LLcl-02qpA?pwd=8888 pincode: 8888
