Banana Pi BPI-AI2N System-on-Module (SoM) and BPI-AI2N carrier board are open-source hardware solutions designed to leverage the advanced capabilities of the RZ/V2N Vision AI MPU. Designed with a flexible, community-driven ecosystem, the BPI-AI2N platform empowers developers to accelerate innovation and streamline application development. Powered by the RZ/V2N MPU, it delivers industry-leading AI acceleration of 15 TOPS (Sparse) and high-performance computing with 4x Arm® Cortex®-A55 processors, making it an ideal choice for creating cutting-edge vision AI solutions.
Small Form Factor: Compact SO-DIMM 260PINs design (SOM module size: 45x69.6mm)
Open-source development kit, including SOM, BPI-AI2N Carrier board and a rich ecosystem of tools and support from the Banana Pi developer community
Customizable hardware & software by OEM&ODM
Yocto and other open-source software support
Memory & storage: 8GB LPDDR4x, 32GB eMMC, 64MB QSPI Flash
Wide operating temperature range from -40℃ to 85℃
| HardWare Specification of BPI-AI2N | |
SoC |
RZ/V2N |
System Memory |
8GB LPDDR4X |
Storage |
64 MB SPI NAND flash |
32GB eMMC |
SD card Slot |
Button |
Sleep button |
Power button |
recovery button |
Networking |
2 x GbE RJ45 port |
USB |
2x USB 3.0 Type-A port |
DSI |
1x MIPI DSI |
CSI |
2x MIPI CSI |
FAN |
PH-3PIN Connector(5V FAN with PWM) |
Debugging |
USB TypeC Console |
M.2 KEY |
M.2 KEYM For SSD (2280) |
RTC |
support RTC onboard(CR1220) |
WiFi |
WiFi module on board |
GPIO |
40PIN GPIO |
Power Supply |
12V USB-PD on USB-C port |
DC12V IN |
Size |
79 x 100 mm compatible with BPI-AI2N |
| V2N datasheet: http://renesas.com/en/products/rz-v2n |
| BPI-AI2N-Carrier-V11_ASSY.pdf |
Baidu: https://pan.baidu.com/s/1WcI0hORq8NtA-7m_SjiDLg?pwd=8888 code: 8888
| BPI-AI2N-Carrier-V11-SCH-20250521-Release.pdf |
Baidu: https://pan.baidu.com/s/1cQWpGZbI_dHCeybN0lQNLw?pwd=8888 code: 8888
| BPI-AI2N-Core-V11_ASSY.pdf |
Baidu: https://pan.baidu.com/s/1kZc02ibslznrzENGnqaVNA?pwd=8888 code: 8888
| BPI-AI2N-Core-V11-SCH-20250512.pdf |
Baidu: https://pan.baidu.com/s/177iqvUA8cJeoi8Y2zq5I6w?pwd=8888 code: 8888
Yocto oss package:
Baidu: https://pan.baidu.com/s/1Q6qTbbPI0kPFkrjoeHREyg?pwd=8888 pincode: 8888
| Note: The bootloader binaries are built from the Yocto source code. |
Baidu: https://pan.baidu.com/s/1yEEZX-WHzlz1neyPGk323A?pwd=8888 pincode: 8888
Baidu: https://pan.baidu.com/s/15UVcJJEhhxz8fq9_IiS8wQ?pwd=8888 pincode: 8888
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=1074257311649
Banana Pi official Online Shop: https://www.bpi-shop.com/products/bananapi-bpi-ai2n-with-renesas-rzv2n-ai-chip-design.html
SINOVOIP aliexpres shop: https://ko.aliexpress.com/item/1005012968747728.html?gatewayAdapt=glo2kor
Bipai aliexpres shop: https://www.aliexpress.com/item/1005012978900333.html
