BPI-AIM7 uses Rockchip RK3588, a new generation flagship eight-core 64-bit processor with a main frequency of up to 2.4GHz, 6 TOPS computing power NPU, and can be equipped with up to 32GB of large memory. While the interface is fully compatible with Jetson Nano, the PCIe interface has been upgraded to PCIe3.0 4-lane and PCIe2.1 1-lan.
Rockchip RK3588 design Banana Pi BPI-AIM7 Core board fully compatible with Jetson Nano/TX2 NX
Power supply
System Installation (Choose one)
Onboard eMMC boot
USB Type-C data cable: Write the image to the AIM development kit from the Type-C port. You will need a Type-C data cable to connect the AIM development kit to a PC.
MicroSD/TF card boot
MicroSD/TF card: Class 10 or above, at least 8GB SDHC, and a card reader.
The following are high-speed TF cards tested and verified by the ArmSoM team:
SanDisk 32GB TF (MicroSD) (Recommended for developers)
SanDisk 32GB TF (MicroSD) Dashcam & Security Surveillance Card (Recommended for long-term operation)
SanDisk TF 8G Class10 microSD
SanDisk TF 128G Class10 microSD XC TF 128G 48MB/S
You can set up the AIM development kit as an interactive desktop computer or a headless computer that can only be accessed via the network. To set up the AIM development kit as a headless computer, configure the hostname, user account, network connection, and SSH when installing the OS for the first time. If you want to use the AIM development kit directly, you will need the following additional accessories:
Optional Items
Keyboard & Mouse
HDMI monitor and HDMI cable
DP monitor and DP cable
Ethernet cable
Camera module
It is recommended to use the camera-module1.
LCD display
It is recommended to use the Display 10 HD.
The table below shows the power specifications required to power the AIM development kit. You can use any high-quality power supply that provides the correct power mode.
| Model | Recommended Power (Voltage/Current) | Power Mode |
AIM7 + AIM-IO |
5V/3A, 9V/2A, 12V/2A, 15V/2A |
DC adapter, 2.5mm |
AIM5 + AIM-IO |
DC adapter, 2.5mm |
The AIM development kit supports multiple system images, and you can choose the appropriate image to download according to your needs.
| A system image includes the Linux kernel, basic programs, etc., which are essential for running the AIM development kit, so you need to install the image before running the product. |
Visit the Baidu Cloud resource page to obtain the system image:
Baidu Cloud Link: https://pan.baidu.com/share/init?surl=4qfAZM3QqgJPuFVjKRSBUw&pwd=arms
1,The default account/password for the official image is armsom/armsom, linaro/linaro, root/1234. 2,The Debian system is adapted and compiled using the SDK provided by RK, making it more suitable for users with ISP, GPU, codec, and NPU needs. It can be burned to eMMC using RKDevTool or to an SD card using SDDiskTool. 3,Ubuntu, Armbian, and OpenWrt are additional options provided by ArmSoM for open-source enthusiasts. |
Burning the OS image to microSD via Etcher
This method is suitable for burning the system to an SD card and is available on Windows, macOS, and Linux x64 operating systems.
PREPARATION 1. A microSD card 2. An SD card reader 3. Download the Ubuntu/Armbian/OpenWrt system image for the respective product. 4. Insert the SD card into the SD card reader, then insert the SD card reader into the computer’s USB port. |
1.Download balenaEtcher from the: balena official website, and select the appropriate host system. The Linux version is in AppImage format.
2.Insert the MicroSD card into the MicroSD card reader.
3.Open the Etcher window, first select "Flash from file," find the location where you downloaded the image, and double-click to select it.
4.Then click "Select target" and choose the MicroSD card you want to burn.
5.Click "Flash" and wait for the burning process to complete. This will take some time.
6.Once the burning is successful, it will show as pictured below:
BURNING FAILED 1. On Windows, burning the image requires running "as administrator," and some Linux users may need to use the chmod command to make it executable. 2. If there is an error during the burning process, please try again. |
1.Download the Win32DiskImager tool.
2.Open Win32DiskImager.
3.Click the folder icon button and then select the image you want to burn.
4.After completing the above steps, click the "Write" button to start burning the image, then wait for the burning process to complete.
Burning an image to eMMC requires using the RKDevTool and the RK Driver Assistant (DriverAssistant).
Click to enter the Baidu Cloud Link: https://pan.baidu.com/share/init?surl=4qfAZM3QqgJPuFVjKRSBUw&pwd=arms
Unzip the DriverAssistant software package and double-click DriverInstall.exe to enter the driver installation interface.
Click "Install Driver" to start installing the driver. If you are unsure whether a previous version of the driver was installed, first click "Uninstall Driver" to remove the old version, then click "Install Driver."
RKDevTool is a dedicated USB burning tool for Rockchip, available on the Windows platform, which can be used to download system images to the product via the USB interface.
After unzipping the package, you can use it without installation. Double-click RKDevTool.exe to enter the software interface.
The software mainly has three sections: Download Image (burn image by address), Upgrade Firmware, and Advanced Functions.
This mode is suitable for products that have not yet been burned with a system or where the burned system is damaged and cannot run (suitable for all situations).
Open the RKDevTool burning tool and set the product to burn mode.
Entering Loader Mode
1. Prepare a Type-C cable for burning the image.
2. Disconnect all cables that might power the product, such as the power cable, USB cable, etc.
3. Use a Type-C cable to connect the product’s OTG interface to a USB port on the computer, then open the RKDevTool software.
4. Short pin 10 (FC REC) and pin 9 (GND) on the 12-pin connector, then power the product via DC.
5. Wait for the software to prompt "Loader device found" (as shown below), then release the buttons.
6. If unsuccessful, repeat steps 2-5.
Entering MASKROM Mode
4. Short the solder points on the core board, then power the product via DC.
Start burning the system:
1.Select the "Download Image" option.
2.Confirm that the board has entered MASKROM/Loader mode.
3.Click the blank cells to select the MiniLoaderAll and Image files to use. The corresponding MiniLoaderAll and Image files are stored on Baidu Cloud.
4.In the "Storage" option, select the target medium "EMMC
Installing SDDiskTool
To burn the image to eMMC, you need to use the SDDiskTool_version.exe tool.
Click the following link to access it: Baidu Cloud Link
After extracting the compressed file, you can use the software without installation. Simply double-click the SD_Firmware_Tool.exe file to open the tool.
Open the SDDiskTool executable file (SD_Firmware_Tool.exe) and insert the SD card.
First, select the correct SD card you want to burn. Then, set the function mode to SD Boot and choose the image you want to burn. Finally, click the "Create" button to start creating the bootable SD card.
Please be patient as the SD card is being burned. The larger the image, the longer the burning process will take.
1.If you encounter an error saying it cannot burn the image after clicking "Create," try closing the error window and starting the creation process again. If that doesn’t work, try formatting the SD card. 2.The firmware downloaded from Baidu Cloud must be extracted before it can be loaded. On a Windows PC, you need to run the tool with administrator privileges. |
We will use the RKDevTool to burn the image and put the product into burning mode.
2. Disconnect all cables that might power the product, such as the power cord and USB cables.
3. Connect one end of the Type-C cable to the OTG port on the product and the other end to the USB port on the computer, then open the RKDevTool software.
4. Hold down the Recovery button and power the product using the DC supply.
5. Wait for the software to indicate that a LOADER device has been detected (as shown below), then release the button.
The burning progress will be shown on the right. Once completed, the tool will notify you:
Connect the USB to TTL serial cable as shown below:
| AIM7 | Connection | Serial Module |
GND (pin 11) |
GND |
RX (pin 3) |
TX |
TX (pin 4) |
RX |
First, plug one end of the Ethernet cable into the ArmSoM-AIM’s Ethernet port and connect the other end to a router, ensuring the network is functional.
After booting, the system will automatically assign an IP address to the Ethernet card via DHCP without any additional configuration.
To check the IP address in the ArmSoM-AIM Linux system, use the following command:
root@armsom-aim7:/# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether c2:ed:bc:48:3b:7a brd ff:ff:ff:ff:ff:ff
inet 192.168.10.106/24 brd 192.168.10.255 scope global dynamic noprefixroute eth0
valid_lft 86396sec preferred_lft 86396sec
inet6 fe80::7351:88a9:9b4c:11be/64 scope link noprefixroute
After the ArmSoM-AIM boots, there are three ways to check the IP address:
Connect to an HDMI display, log into the system, and use the terminal to enter the ip a command.
Use the debug serial port terminal to enter the ip a command to check the IP address.
If there is no debug serial port or HDMI display, you can check the ArmSoM-AIM’s IP address through the router’s management interface. However, this method often fails to display the ArmSoM-AIM’s IP address. If not visible, follow these troubleshooting steps:
First, check whether the Linux system has booted properly. If the ArmSoM-AIM’s green LED is solid, it generally indicates a normal boot. If only the red LED is on, the system hasn’t booted correctly.
Ensure the Ethernet cable is securely connected, or try a different cable.
Test with another router, as many issues arise from routers not assigning IP addresses correctly or assigning them but not displaying them in the management interface.
If no alternative router is available, connect an HDMI display or use the debug serial port to check the IP address.
| It is important to note that the ArmSoM-AIM automatically assigns an IP address via DHCP without any settings required. |
Use the ping command to check network connectivity.
The command to test network connectivity is as follows. You can interrupt the ping command by using the Ctrl+C shortcut:
armsom@armsom-aim7:~$ ping www.baidu.com
PING www.a.shifen.com (183.2.172.185): 56 data bytes
64 bytes from 183.2.172.185: icmp_seq=0 ttl=53 time=8.370 ms
64 bytes from 183.2.172.185: icmp_seq=1 ttl=53 time=8.917 ms
64 bytes from 183.2.172.185: icmp_seq=2 ttl=53 time=8.511 ms
64 bytes from 183.2.172.185: icmp_seq=3 ttl=53 time=8.673 ms
^C
--- www.a.shifen.com ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max/stddev = 8.370/8.618/8.917/0.203 ms
| Model | AIM7 | AIM5 |
Resolution |
8Kp60 |
4Kp120 |
Use an HDMI cable to connect the ArmSoM-AIM to an HDMI display.
If the HDMI display outputs an image after the Linux system boots, the HDMI interface is functioning properly.
| Note that many laptops have HDMI ports that only support output functionality. This means they cannot display HDMI output from other devices on their screens. When attempting to connect the development board’s HDMI to a laptop HDMI port, please confirm whether your laptop supports HDMI input functionality. If no display is shown, first check whether the system version includes a desktop environment, as server versions only show the terminal. |
Resolution |
4Kp60 |
4Kp60 |
Use a DP cable to connect the ArmSoM-AIM to a DP display.
If the DP display outputs an image after the Linux system boots, the DP interface is functioning properly.
| Model | AIM7 |
USB |
1* Type-C 2.0, 4x USB3.0 |
| The USB interface can be connected to a USB hub to expand the number of USB ports. |
Plug a USB keyboard into the ArmSoM-AIM’s USB port.
Connect the ArmSoM-AIM to an HDMI display.
If the mouse or keyboard operates normally within the system, the USB interface is functioning properly (note: the mouse works only in desktop versions).
First, insert a USB flash drive or external USB hard drive into the ArmSoM-AIM’s USB port. Execute the following command; if you see output for sdX, it indicates the USB drive is recognized:
armsom@armsom-aim7:/# cat /proc/partitions | grep "sd*"
major minor #blocks name
8 0 122880000 sda
Use the mount command to mount the USB drive to /mnt, allowing you to view files on the drive:
armsom@armsom-aim7:/# sudo mount /dev/sda1 /test/
After mounting, you can check the USB drive’s capacity usage and mount point with the df -h command:
armsom@armsom-aim7:/test# df -h | grep "sd"
/dev/sda 4.7G 4.7G 0 100% /test
1.Prepare a USB camera that supports the UVC protocol and connect it to the board’s USB port.
2.Use the v4l2-ctl command to view the USB camera’s device node information, which should be /dev/video0:
armsom@armsom-sige7:/# v4l2-ctl --list-devices
Logitech HD Webcam C93 (usb-xhci-hcd.5.auto-1):
/dev/video40
/dev/video41
/dev/media4
3.On a desktop system, you can use Cheese/V4L2 test bench to open the USB camera directly.
You can also use terminal commands to preview the camera:
armsom@armsom-sige7:/# gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! xvimagesink;
To capture a photo:
armsom@armsom-sige7:/# gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/armsom/test.jpg;
To record a video:
gst-launch-1.0 v4l2src num-buffers=512 device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 ! tee name=t ! queue ! mpph264enc ! queue ! h264parse ! mpegtsmux ! filesink location=/home/armsom/test.mp4
TROUBLESHOOTING BURNING FAILURES If you encounter a "Download Boot Fail" error or other errors during the burning process (as shown below), it is usually due to a poor USB connection, low-quality cables, or insufficient power from the computer’s USB port. Try replacing the USB cable or using a different USB port on the computer to troubleshoot. |
WHAT IS THE DIFFERENCE BETWEEN MASKROM MODE AND LOADER MODE? Maskrom Mode: When the Flash is not yet burned with firmware, the chip will enter Maskrom mode for the initial firmware burning. During development, if the Loader mode fails to start properly, Maskrom mode can also be used to burn the firmware. Loader Mode: This mode is triggered during the uboot startup when a specific pin is pressed. In Loader mode, firmware burning and upgrading can be performed. You can also burn individual partition images for easier debugging. |
