BPI-AIM7 uses Rockchip RK3588, a new generation flagship eight-core 64-bit processor with a main frequency of up to 2.4GHz, 6 TOPS computing power NPU, and can be equipped with up to 32GB of large memory. While the interface is fully compatible with NVIDIA Jetson Nano, the PCIe interface has been upgraded to PCIe3.0 4-lane and PCIe2.1 1-lan.
BPI-AIM7 can be applied to ARM PC, edge computing, cloud server, artificial intelligence, cloud computing, virtual/augmented reality, blockchain, smart NVR and other fields
Rockchip RK3588 design Banana Pi BPI-M7 AI SBC design Rockchip RK3576 deisgn Banana Pi BPI-M5 Pro AI SBC design Rockchip RK3576 deisgn Banana Pi BPI-CM5 Pro AI core board kit design Rockchip RK3588s deisgn Banana Pi BPI-M7S AI SBC design Rockchip RK3588 design Banana Pi BPI-AIM7 Core board fully compatible with Jetson Nano/TX2 NX Rockchip RK3588 design Banana Pi BPI-W3 LGA core board kit Rockchip RK3588 design Banana Pi BPI-LM7 LGA core board Rockchip RK3588 design BPI-RK3588 core board and kit Introduction Core boards |
SOC: Rockchip RK3588
CPU: RK3588 quad-core Cortex-A76 @ 2.4GHz + quad-core Cortex-A55 @ 1.8GHz, 8nm process
GPU: ARM Mali-G610 MP4
NPU: Computing power up to 6 TOPS (INT8), supports INT4/INT8/INT16 mixed computing
VPU/Codec:
Hardware decoding: 8K@60fps H.265/VP9/AVS2, 8K@30fps H.264 AVC/MVC, 4K@60fps AV1, 1080P@60fps MPEG-2/-1/VC-1/VP8
Hardware encoding: 8K@30fps H.265 / H.264
RAM: 8GB/16GB/32GB (max 32GB) 64bit LPDDR4x, default LPDDR4x 8GB
Flash: 32GB/64GB/128GB eMMC, default eMMC 32GB
Interface type: 260pin SO-DIMM connector, compatible with Jetson TX2 NX
Working voltage: 5V DC
Temperature: Operating temperature: 0°C to 80°C, Storage temperature: -20°C to 85°C
Humidity: Relative humidity: Operation: 10% to 90%, Storage: 5% to 95%
operating system:
Rockchip official support: Android 12.0, Debian11, Buildroot
Third-party support: Armbian 23.07, Ubuntu 20.04, Ubuntu22.04, Kylin OS
PCB: 12-layer PCB board design
Size: 69.6 mm x 45 mm
Boasting up to 6 TOPs AI performance, AIM7 supports Large Language Model (LLM) such as GPT, LLaMA, ChatGLM, and Bloom. It also enables multi-chip parallel acceleration for handling very large model inferences.
| All pins of AIM7 are compatible with NVIDIA Jetson TX2 & NVIDIA Jetson Nano, with the same dimensions |
| Category | Function |
Display |
1x DP interface |
1x HDMI/eDP combo interface |
Up to 7680 x 4320@60 Hz for HDMI and DP, and 3840 x 2160@60 Hz for eDP |
Camera |
3x 4-lane or 5x 2-lane MIPI CSI interfaces, each lane up to 2.5Gbps |
Network |
1 GMAC, with RGMII / RMII interface |
Supports 10/100/1000Mbps data transfer rate |
PCIe |
PCIe 3.0 x4: Each channel supports up to 8Gbps data rate, supports 4 configuration modes: 1x4, 2x2, 4x1, 1x2+2x1, each channel supports up to 8Gbps data rate |
PCIe 2.1 x1: Each PCIe 2.1 interface supports 1 lane, up to 5Gbps data rate |
USB |
1x USB 3.0 (Gen1) |
3x USB 2.0 |
Others |
UART DEBUG x1, UART+flow control x2 |
SPI x2 |
I2C x4 |
CAN x1 |
I2S x2 |
SD 4.0, SDHOST 4.0, and SDIO 3.0 |
PWM x3, multiple GPIOs |
| Specifications BPI-AIM7(Rockchip) VS Jetson Nano (NVIDIA) | ||
Specifications |
BPI-AIM7(Rockchip RK3588) |
CPU Cores |
Quad-core ARM® Cortex®-A76 + Quad-core ARM®Cortex®-A55 |
Quad-core ARM® Cortex®-A57 MPCore processor |
GPU Cores |
ARM Mali-G610 MP4 |
128-core Maxwell GPU |
Memory |
8GB/32GB 64-bit LPDDR4x, 2112MHz |
4GB 64-bit LPDDR4, 1600MHz |
Storage |
microSD card, 32GB eMMC 5.1 flash storage |
microSD card, 16GB eMMC 5.1 flash storage |
Video Encoding |
8K @30fps H.265/H.264 |
250 MP/sec, 1x 4K@30 (HEVC), 2x 1080p@60 (HEVC), 4x 1080p@30 (HEVC) |
Video Decoding |
8K@60fps H.265/VP9/AVS2, 8K@30fps H.264 AVC/MVC, 4K@60fps AV1, 1080P@60fps MPEG-2/-1/VC-1/VP8 |
500 MP/s, 1x 4K@60 (HEVC), 2x 4K@30 (HEVC), 4x 1080p@60 (HEVC), 8x 1080p@30 (HEVC) |
USB Ports |
1 USB 3.0, 3 USB 2.0 |
Ethernet |
1 10/100/1000 BASE-T |
CSI Interfaces |
12 channels (4x2) MIPI CSI-2 D-PHY1.1 (18 Gbps) |
12 channels (3x4 or 4x2) MIPI CSI-2 D-PHY 1.1 (18 Gbps) |
I/O |
3 UARTs, 2 SPIs, 2 I2S, 4 I2Cs, multiple GPIOs |
3 UARTs, 2SPIs, 2 I2S, 4 I2Cs, multiple GPIOs |
PCIE |
1 1/2/4lane PCIE3.0 & 1 1lane PCIE2.0 |
1 1/2/4lane PCIE2.0 |
HDMI Output |
1 HDMI OUT2.1 / 1 eDP 1.4 |
1 HDMI 2.0 |
DP Interface |
1 DP1.4a |
1 DP1.2 |
eDP/DP Interface |
1 eDP 1.4 / 1 HDMI OUT2.1 |
1 eDP 1.4 / 1 DP |
DSI Interface |
1 DSI (1 x2) 2 sync |
OS Support |
Support debian, ubuntu, armbian, kernel 5.10 |
NVIDIA JetPack software suite |
Size |
69.6 mm x 45 mm |
69.6 mm x 45 mm |
Form Factor |
260-pin edge connector |
| BPI-AIM7 function | Pin number | Pin number | BPI-AIM7 function |
GND_1 |
1 |
2 |
GND_2 |
CSI1_D0_N |
3 |
4 |
CSI0_D0_N |
CSI1_D0_P |
5 |
6 |
CSI0_D0_P |
GND_3 |
7 |
8 |
GND_4 |
CSI1_CLK_N |
9 |
10 |
CSI0_CLK_N |
CSI1_CLK_P |
11 |
12 |
CSI0_CLK_P |
GND_5 |
13 |
14 |
GND_6 |
CSI1_D1_N |
15 |
16 |
CSI0_D1_N |
CSI1_D1_P |
17 |
18 |
CSI0_D1_P |
GND_7 |
19 |
20 |
GND_8 |
CSI3_D0_N |
21 |
22 |
CSI2_D0_N |
CSI3_D0_P |
23 |
24 |
CSI2_D0_P |
GND_9 |
25 |
26 |
GND_10 |
CSI3_CLK_N |
27 |
28 |
CSI2_CLK_N |
CSI3_CLK_P |
29 |
30 |
CSI2_CLK_P |
GND_11 |
31 |
32 |
GND_12 |
CSI3_D1_N |
33 |
34 |
CSI2_D1_N |
CSI3_D1_P |
35 |
36 |
CSI2_D1_P |
GND_13 |
37 |
38 |
GND_14 |
TYPEC0_SSRX1N/DP0_TXD0_N |
39 |
40 |
CSI4_D2_N |
TYPEC0_SSRX1P/DP0_TXD0_P |
41 |
42 |
CSI4_D2_P |
GND_15 |
43 |
44 |
GND_16 |
TYPEC0_SSTX1N/DP0_TXD1_N |
45 |
46 |
CSI4_D0_N |
TYPEC0_SSTX1P/DP0_TXD1_P |
47 |
48 |
CSI4_D0_P |
GND_17 |
49 |
50 |
GND_18 |
TYPEC0_SSRX2N/DP0_TXD2_N |
51 |
52 |
CSI4_CLK_N |
TYPEC0_SSRX2P/DP0_TXD2_P |
53 |
54 |
CSI4_CLK_P |
GND_19 |
55 |
56 |
GND_20 |
TYPEC0_SSTX2N/DP0_TXD3_N |
57 |
58 |
CSI4_D1_N |
TYPEC0_SSTX2P/DP0_TXD3_P |
59 |
60 |
CSI4_D1_P |
GND_21 |
61 |
62 |
GND_22 |
HDMI_TXD2_N/EDP_TX0_D2N |
63 |
64 |
CSI4_D3_N |
HDMI_TXD2_P/EDP_TX0_D2P |
65 |
66 |
CSI4_D3_P |
GND_23 |
67 |
68 |
GND_24 |
HDMI_TXD1_N/EDP_TX0_D1N |
69 |
70 |
DSI_D0_N |
HDMI_TXD1_P/EDP_TX0_D1P |
71 |
72 |
DSI_D0_P |
GND_25 |
73 |
74 |
GND_26 |
HDMI_TXD0_N/EDP_TX0_D0N |
75 |
76 |
DSI_CLK_N |
HDMI_TXD0_P/EDP_TX0_D0P |
77 |
78 |
DSI_CLK_P |
GND_27 |
79 |
80 |
GND_28 |
HDMI_CLK_N/EDP_TX0_D3N |
81 |
82 |
DSI_D1_N |
HDMI_CLK_P/EDP_TX0_D3P |
83 |
84 |
DSI_D1_P |
GND_29 |
85 |
86 |
GND_30 |
GPIO0/GPIO1_C5/VBUS_DET |
87 |
88 |
DP0_HPD |
SPI0_MOSI |
89 |
90 |
DP0_AUX_N |
SPI0_SCK |
91 |
92 |
DP0_AUX_P |
SPI0_MISO_M2 |
93 |
94 |
HDMI_HPD |
SPI0_CS0 |
95 |
96 |
HDMI_CEC |
SPI0_CS1 |
97 |
98 |
HDMI_SDA / EDP_TX0_AUXN |
UART0_TXD |
99 |
100 |
HDMI_SCL / EDP_TX0_AUXP |
UART0_RXD |
101 |
102 |
GND_31 |
UART0_RTS |
103 |
104 |
SPI1_MOSI |
UART0_CTS |
105 |
106 |
SPI1_SCK |
GND_32 |
107 |
108 |
SPI1_MISO |
USB0_D_N |
109 |
110 |
SPI1_CS0 |
USB0_D_P |
111 |
112 |
SPI1_CS1 |
GND_33 |
113 |
114 |
CAM0_PWDN |
USB1_D_N |
115 |
116 |
CAM0_MCLK |
USB1_D_P |
117 |
118 |
GPIO01/GPIO3_A7/CAM1_PWDN |
GND_34 |
119 |
120 |
CAM2_MCLK/PCIE30X2_CLKREQN_M1 |
USB2_D_N |
121 |
122 |
CAM2_PWDN |
USB2_D_P |
123 |
124 |
GPIO02/GPIO3_A3/MIPI_CAM2_PDN |
GND_35 |
125 |
126 |
GPIO03/GPIO3_D0/PCIE20X1_2_WAKEN_M0 |
GPIO04/GPIO4_A4/PCIE_30X1_0_WAKE |
127 |
128 |
GPIO05/GPIO4_B0/PCIE30X2_PERSTN_M1 |
GND_36 |
129 |
130 |
GPIO06/GPIO4_A7/PCIE_30X2_WAKE |
PCIE0_RX0_N |
131 |
132 |
GND_37 |
PCIE0_RX0_P |
133 |
134 |
PCIE0_TX0_N |
GND_38 |
135 |
136 |
PCIE0_TX0_P |
PCIE0_RX1_N |
137 |
138 |
GND_39 |
PCIE0_RX1_P |
139 |
140 |
PCIE0_TX1_N |
GND_40 |
141 |
142 |
PCIE0_TX1_P |
CAN_RX |
143 |
144 |
GND_41 |
CAN_TX |
145 |
146 |
GND_42 |
GND_43 |
147 |
148 |
PCIE0_TX2_N |
PCIE0_RX2_N |
149 |
150 |
PCIE0_TX2_P |
PCIE0_RX2_P |
151 |
152 |
GND_44 |
GND_45 |
153 |
154 |
PCIE0_TX3_N |
PCIE0_RX3_N |
155 |
156 |
PCIE0_TX3_P |
PCIE0_RX3_P |
157 |
158 |
GND_46 |
GND_47 |
159 |
160 |
PCIE0_CLK_N |
PCIE20_2_RXN/SATA30_2_RXN/USBSS_RX_N |
161 |
162 |
PCIE30_CLK_P |
PCIE20_2_RXP/SATA30_2_RXP/USBSS_RX_P |
163 |
164 |
GND_48 |
GND_49 |
165 |
166 |
PCIE20_2_TXN/SATA30_2_TXN/USBSS_TX_N |
PCIE1_RX_N/SATA30_0_RXN |
167 |
168 |
PCIE20_2_TXP/SATA30_2_TXP/USBSS_TX_P |
PCIE1_RX_P/SATA30_0_RXP |
169 |
170 |
GND_50 |
GND_51 |
171 |
172 |
PCIE1_TX_N/SATA30_0_TXN |
PCIE1_CLK_N |
173 |
174 |
PCIE1_TX_P/SATA30_0_TXP |
PCIE1_CLK_P |
175 |
176 |
GND_52 |
GND_53 |
177 |
178 |
MOD_SLEEP |
PCIE_30X4_WAKE |
179 |
180 |
PCIE_30X4_CLKREQ |
PCIE_30X4_RST |
181 |
182 |
PCIE_20X1_2_CLKREQ |
PCIE_20X1_2_RST |
183 |
184 |
GBE_MDI0_N |
I2C0_SCL |
185 |
186 |
GBE_MDI0_P |
I2C0_SDA |
187 |
188 |
GBE_LED_LINK |
I2C1_SCL |
189 |
190 |
GBE_MDI1_N |
I2C1_SDA |
191 |
192 |
GBE_MDI1_P |
I2S0_DOUT |
193 |
194 |
GBE_LED_ACT |
I2S1_SDI0_M0/PCIE_30X1_0_RST |
195 |
196 |
GBE_MDI2_N |
I2S1_LRCK_M0/PCIE_30X1_1_RST |
197 |
198 |
GBE_MDI2_P |
I2S0_SCLK/PCIE_30X1_1_WAKE |
199 |
200 |
GND_54 |
GND_55 |
201 |
202 |
GBE_MDI3_N |
UART1_TXD |
203 |
204 |
GBE_MDI3_P |
UART1_RXD |
205 |
206 |
GPIO07/GPIO3_A0/PWM10 |
UART1_RTS |
207 |
208 |
GPIO08/GPIO1_C6/PWM15_IR |
UART1_CTS |
209 |
210 |
32KOUT |
I2S1_MCLK_M0/PCIE30X1_1_CLKREQN_M1 |
211 |
212 |
GPIO10/GPIO4_A3/PCIE_30X1_0_CLKREQ |
CAM_I2C_SCL |
213 |
214 |
RECOVERY_KEY |
CAM_I2C_SDA |
215 |
216 |
GPIO11/GPIO3_B0/MIPI_CAM3_CLKOUT |
GND_56 |
217 |
218 |
GPIO12/I2S2_MCLK_M1/MIPI_CAM3_PDN |
SDMMC_DAT0 |
219 |
220 |
I2S1_DOUT |
SDMMC_DAT1 |
221 |
222 |
I2S1_DIN |
SDMMC_DAT2 |
223 |
224 |
I2S1_FS |
SDMMC_DAT3 |
225 |
226 |
I2S1_SCLK |
SDMMC_CMD |
227 |
228 |
GPIO08 |
SDMMC_CLK |
229 |
230 |
GPIO14 |
GND_57 |
231 |
232 |
I2C2_SCL |
SHUTDOWN_REQ |
233 |
234 |
I2C2_SDA |
PMIC_BBAT |
235 |
236 |
UART2_TXD |
POWER_EN |
237 |
238 |
UART2_RXD |
SYS_RESET |
239 |
240 |
SLEEP/WAKE |
GND_58 |
241 |
242 |
GND_59 |
GND_60 |
243 |
244 |
GND_61 |
GND_62 |
245 |
246 |
GND_63 |
GND_64 |
247 |
248 |
GND_65 |
GND_66 |
249 |
250 |
GND_67 |
VDD_IN_1 |
251 |
252 |
VDD_IN_2 |
VDD_IN_3 |
253 |
254 |
VDD_IN_4 |
VDD_IN_5 |
255 |
256 |
VDD_IN_6 |
VDD_IN_7 |
257 |
258 |
VDD_IN_8 |
VDD_IN_9 |
259 |
260 |
VDD_IN_10 |
Two MIPI DC (DPHY/CPHY) combo PHY
Support USE DPHY or CPHY
Each MIPI DPHY V2.0, 4 lanes, 4.5 Gbps per lane
Each MIPI CPHY V1.1, 3 lanes, 2.5 Gbps per lane
Four MIPI CSI DPHY
Each MIPI DPHY V1.2, 2 lanes, 2.5 Gbps per lane
Support combine 2 DPHY together to one 4-lan
CSI pin descriptions:
| Pin | Pin name | Signal description | Direction Pin type |
10 |
MIPI_CSI0_RX_CLK0N |
Camera, CSI 0 Clock– |
Input MIPI D-PHY |
12 |
MIPI_CSI0_RX_CLK0P |
Camera, CSI 0 Clock+ |
Input MIPI D-PHY |
4 |
MIPI_CSI0_RX_D0N |
Camera, CSI 0 Data 0– |
Input MIPI D-PHY |
6 |
MIPI_CSI0_RX_D0P |
Camera, CSI 0 Data 0 + |
Input MIPI D-PHY |
16 |
MIPI_CSI0_RX_D1N |
Camera, CSI 0 Data 1– |
Input MIPI D-PHY |
18 |
MIPI_CSI0_RX_D1P |
Camera, CSI 0 Data 1+ |
Input MIPI D-PHY |
9 |
MIPI_CSI0_RX_CLK1N |
Camera, CSI 1 Clock– |
Input MIPI D-PHY |
11 |
MIPI_CSI0_RX_CLK1P |
Camera, CSI 1 Clock+ |
Input MIPI D-PHY |
3 |
MIPI_CSI0_RX_D2N |
Camera, CSI 1 Data 0– |
Input MIPI D-PHY |
5 |
MIPI_CSI0_RX_D2P |
Camera, CSI 1 Data 0+ |
Input MIPI D-PHY |
15 |
MIPI_CSI0_RX_D3N |
Camera, CSI 1 Data 1– |
Input MIPI D-PHY |
17 |
MIPI_CSI0_RX_D3P |
Camera, CSI 1 Data 1+ |
Input MIPI D-PHY |
28 |
MIPI_CSI1_RX_CLK0N |
Camera, CSI 2 Clock– |
Input MIPI D-PHY |
30 |
MIPI_CSI1_RX_CLK0P |
Camera, CSI 2 Clock+ |
Input MIPI D-PHY |
22 |
MIPI_CSI1_RX_D0N |
Camera, CSI 2 Data 0– |
Input MIPI D-PHY |
24 |
MIPI_CSI1_RX_D0P |
Camera, CSI 2 Data 0+ |
Input MIPI D-PHY |
34 |
Camera, CSI 2 Data 1– |
Input MIPI D-PHY |
36 |
Camera, CSI 2 Data |
Input MIPI D-PHY |
27 |
MIPI_CSI1_RX_CLK1N |
Camera, CSI 3 Clock– |
Input MIPI D-PHY |
29 |
MIPI_CSI1_RX_CLK1P |
Camera, CSI 3 Clock+ |
Input MIPI D-PHY |
21 |
MIPI_CSI1_RX_D2N |
Camera, CSI 3 Data 0– |
Input MIPI D-PHY |
23 |
MIPI_CSI1_RX_D2P |
Camera, CSI 3 Data 0+ |
Input MIPI D-PHY |
33 |
MIPI_CSI1_RX_D3N |
Camera, CSI 3 Data 1– |
Input MIPI D-PHY |
35 |
MIPI_CSI1_RX_D3P |
Camera, CSI 3 Data 1+ |
Input MIPI D-PHY |
52 |
MIPI_DPHY0_RX_CLKN |
Camera, CSI 4 Clock– |
Input MIPI D/C-PHY |
54 |
MIPI_DPHY0_RX_CLKP |
Camera, CSI 4 Clock+ |
46 |
MIPI_DPHY0_RX_D0N |
Camera, CSI 4 Data 0– |
48 |
MIPI_DPHY0_RX_D0P |
Camera, CSI 4 Data 0+ |
58 |
MIPI_DPHY0_RX_D1N |
Camera, CSI 4 Data 1– |
60 |
MIPI_DPHY0_RX_D1P |
Camera, CSI 4 Data 1+ |
40 |
MIPI_DPHY0_RX_D2N |
Camera, CSI 4 Data 2– |
42 |
MIPI_DPHY0_RX_D2P |
Camera, CSI 4 Data 2+ |
64 |
MIPI_DPHY0_RX_D3N |
Camera, CSI 4 Data 3– |
66 |
MIPI_DPHY0_RX_D3P |
Camera, CSI 4 Data 3+ |
| Pin | Pin name | Signal description | Direction | Pin type |
213 |
CAM_I2C_SCL |
Camera I2C Clock. 2.2kΩ pull-up to 3.3 V on the module. |
Bidir |
Open Drain –3.3V |
116 |
CAM0_MCLK |
Camera 0 Reference Clock |
Output |
CMOS – 1.8V |
114 |
CAM0_PWDN |
Camera 0 Powerdown or GPIO |
Output |
CMOS – 1.8V |
122 |
CAM1_MCLK |
Camera 1 Reference Clock |
Output |
CMOS – 1.8V |
120 |
CAM1_PWDN |
Camera 1 Powerdown or GPIO |
Output |
CMOS – 1.8V |
HDMI/eDP TX interface
Support x1, x2 and x4 configuration for each interface
Support all the data rates for HDMI FRL: 3, 6, 8, 10 and 12Gbps
Support 1.62Gbps, 2.7Gbps and 5.4Gbps for eDP
Support up to 7680x4320@60Hz for HDMI TX, and 4K@60Hz for eDP
Support RGB/YUV(up to 10bit) format for HDMI TX
Support RGB, YCbCr 4:4:4, YCbCr 4:2:2 and 8/10 bit per component video format for eDP
Support DSC 1.2a for HDMI TX
Support HDCP2.3 for HDMI TX, and HDCP1.3 for eDP
DP TX interface
Support 2 DP TX 1.4a interface which combo with USB3.1 Gen1
Support 1/2/4lanes for each interface
Support 1.62Gbps, 2.7Gbps, 5.4Gbps and 8.1Gbps Serializer
Support up to 7680x4320@30Hz
Support Single Stream Transport(SST)
Support DP Alt mode on USB Type-C
Support HDCP2.3, HDCP 1.3
MIPI DSI interface
Support 2 MIPI DPHY 2.0 interfaces
Support 4 data lanes and 4.5 Gbps maximum data rate per lane
Support max resolution 4K@60 Hz
Support dual MIPI display: left-right mode
Support RGB (up to 10 bits) format
Support DSC 1.1/1.2a
==== DSI pin descriptions
76 |
MIPI_DPHY1_TX_CLKN |
DSI Clock– |
Output |
MIPI D-PHY |
78 |
MIPI_DPHY1_TX_CLKP |
DSI Clock+ |
Output |
MIPI D-PHY |
70 |
MIPI_DPHY1_TX_D0N |
DSI Data 0– |
Output |
MIPI D-PHY |
72 |
MIPI_DPHY1_TX_D0P |
DSI Data 0+ |
Output |
MIPI D-PHY |
82 |
MIPI_DPHY1_TX_D1N |
DSI Data 1– |
Output |
MIPI D-PHY |
84 |
MIPI_DPHY1_TX_D1P |
DSI Data 1+ |
Output |
MIPI D-PHY |
==== DP & eDP/HDMI pin descriptions
39 |
TYPEC0_SSRX1N/DP0_TX0N |
Display Port 0 Lane 0- |
Output |
DP |
41 |
TYPEC0_SSRX1P/DP0_TX0P |
Display Port 0 Lane 0+ |
Output |
DP |
45 |
TYPEC0_SSTX1N/DP0_TX1N |
Display Port 0 Lane 1– |
Output |
DP |
47 |
TYPEC0_SSTX1P/DP0_TX1P |
Display Port 0 Lane 1+ |
Output |
DP |
51 |
TYPEC0_SSRX2N/DP0_TX2N |
Display Port 0 Lane 2– |
Output |
DP |
53 |
TYPEC0_SSRX2P/DP0_TX2P |
Display Port 0 Lane 2+ |
Output |
DP |
57 |
TYPEC0_SSTX2N/DP0_TX3N |
Display Port 0 Lane 3– |
Output |
DP |
59 |
TYPEC0_SSTX2P/DP0_TX3P |
Display Port 0 Lane 3+ |
Output |
DP |
90 |
TYPEC0_SBU2/DP0_AUXN |
Display Port 0 Aux– |
Bidir |
DP |
92 |
TYPEC0_SBU1/DP0_AUXP |
Display Port 0 Aux+ |
Bidir |
DP |
88 |
DP0_HPDIN_M2 |
Display Port 0 Hot Plug Detect |
Input |
Open Drain–1.8V |
63 |
HDMI_TX0_D2N/EDP_TX0_D2N |
HDMI/EDP Lane 2– |
Output |
HDMI/EDP |
65 |
HDMI_TX0_D2P/EDP_TX0_D2P |
HDMI/EDP Lane 2+ |
Output |
HDMI/EDP |
69 |
HDMI_TX0_D1N/EDP_TX0_D1N |
HDMI/EDP Lane 1– |
Output |
HDMI/EDP |
71 |
HDMI_TX0_D1P/EDP_TX0_D1P |
HDMI/EDP Lane 1+ |
Output |
HDMI/EDP |
75 |
HDMI_TX0_D0N/EDP_TX0_D0N |
HDMI/EDP Lane 0– |
Output |
HDMI/EDP |
77 |
HDMI_TX0_D0P/EDP_TX0_D0P |
HDMI/EDP Lane 0+ |
Output |
HDMI/EDP |
81 |
HDMI_TX0_D3N/EDP_TX0_D3N |
HDMI/EDP Clk Lane– |
Output |
HDMI/EDP |
83 |
HDMI_TX0_D3P/EDP_TX0_D3P |
HDMI/EDP Clk Lane+ |
Output |
HDMI/EDP |
98 |
HDMI_TX0_SDA_M0 / EDP_TX0_AUXN |
HDMI/EDP DDC SDA |
Bidir |
Open-Drain,3.3V |
100 |
HDMI_TX0_SCL_M0 / EDP_TX0_AUXP |
HDMI/EDP DDC SCL |
Output |
Open-Drain,3.3V |
96 |
HDMI_TX0_HPD_M0 |
HDMI/EDP Hot Plug Detect |
Input |
Open Drain–1.8V |
94 |
HDMI_TX0_CEC_M0 |
HDMI/EDP CEC |
Bidir |
Open Drain–3.3V |
Compatible with SDIO3.0 protocol
4-bit data bus width
SDIO pin descriptions
229 |
SDMMC0_CLK |
SD Card or SDIO Clock |
Output |
CMOS – 1.8V/3.3V |
227 |
SDMMC0_CMD |
SD Card or SDIO Command |
Bidir |
CMOS – 1.8V/3.3V |
219 |
SDMMC0_D0 |
SD Card or SDIO Data 0 |
Bidir |
CMOS – 1.8V/3.3V |
221 |
SDMMC0_D1 |
SD Card or SDIO Data 1 |
Bidir |
CMOS – 1.8V/3.3V |
223 |
SDMMC0_D2 |
SD Card or SDIO Data 2 |
Bidir |
CMOS – 1.8V/3.3V |
225 |
SDMMC0_D3 |
SD Card or SDIO Data 3 |
Bidir |
CMOS – 1.8V/3.3V |
Gigabit Ethernet pin descriptions
184 |
PHY0_MDI0- |
GbE Transformer Data 0– |
Bidir |
MDI |
186 |
PHY0_MDI0+ |
GbE Transformer Data 0+ |
Bidir |
MDI |
190 |
PHY0_MDI1- |
GbE Transformer Data 1– |
Bidir |
MDI |
192 |
PHY0_MDI1+ |
GbE Transformer Data 1+ |
Bidir |
MDI |
196 |
PHY0_MDI2- |
GbE Transformer Data 2– |
Bidir |
MDI |
198 |
PHY0_MDI2+ |
GbE Transformer Data 2+ |
Bidir |
MDI |
202 |
PHY0_MDI3- |
GbE Transformer Data 3– |
Bidir |
MDI |
204 |
PHY0_MDI3+ |
GbE Transformer Data 3+ |
Bidir |
MDI |
188 |
PHY0_LED1/CFG_LDO0 |
Ethernet Link LED (Green) |
Output |
194 |
PHY0_LED2/CFG_LDO1 |
Ethernet Activity LED (Yellow) |
Output |
Embedded two USB 3.0 OTG interfaces which combo with DP TX (USB3OTG_0 and USB3OTG_1)
Embedded one USB 3.0 Host interface which combos with Combo PIPE PHY2 (USB3OTG_2)
USB 3.0 GEN1 pin descriptions
161 |
PCIE20_2_RXN/SATA30_2_RXN/USB30_2_SSRXN |
USB SS Receive- (USB 3.0 Ctrl #0) |
Input |
USB SS PHY |
163 |
PCIE20_2_RXP/SATA30_2_RXP/USB30_2_SSRXP |
USB SS Receive+ (USB 3.0 Ctrl #0) |
Input |
USB SS PHY |
166 |
PCIE20_2_TXN/SATA30_2_TXN/USB30_2_SSTXN |
USB SS Transmit- (USB 3.0 Ctrl #0) |
Output |
USB SS PHY |
168 |
PCIE20_2_TXP/SATA30_2_TXP/USB30_2_SSTXP |
USB SS Transmit+ (USB 3.0 Ctrl #0) |
Output |
USB SS PHY |
Compatible with USB 2.0 specification
Support two USB 2.0 Hosts
Supports high-speed (480 Mbps), full-speed (12 Mbps) and low-speed (1.5 Mbps) mode
Support Enhanced Host Controller Interface Specification (EHCI), Revision 1.0
Support Open Host Controller Interface Specification (OHCI), Revision 1.0a
USB 2.0 pin descriptions
109 |
TYPEC0_USB20_OTG_DM |
USB2.0 Port 0 Data– |
Bidir |
USB PHY |
111 |
TYPEC0_USB20_OTG_DP |
USB2.0 Port 0 Data+ |
Bidir |
USB PHY |
115 |
USB20_HOST0_DM |
USB 2.0 Port 1 Data– |
Bidir |
USB PHY |
117 |
USB20_HOST0_DP |
USB 2.0 Port 1 Data+ |
Bidir |
USB PHY |
121 |
USB20_HOST1_DM |
USB 2.0 Port 2 Data– |
Bidir |
USB PHY |
123 |
USB20_HOST1_DP |
USB 2.0 Port 2 Data+ |
Bidir |
USB PHY |
PCIe 2.1 interface
Compatible with PCI Express Base Specification Revision 2.1
Support one lane for each PCIe 2.1 interface
Support Root Complex (RC) only
Support 5 Gbps data rate
PCIe 2.1 pin descriptions
| Pin | Pinname | Signal description | Direction | Pin type |
167 |
PCIE20_0_RXN/SATA30_0_RXN |
PCIe #1 Receive 0– (PCIe Ctrl #2 Lane 0) |
Input |
PCIe PHY |
169 |
PCIE20_0_RXP/SATA30_0_RXP |
PCIe #1 Receive 0+ (PCIe Ctrl #2 Lane 0) |
Input |
PCIe PHY |
172 |
PCIE1_TX0_N |
PCIe #1 Transmit 0– (PCIe Ctrl #2 Lane 0) |
Output |
PCIe PHY |
174 |
PCIE1_TX0_P |
PCIe #1 Transmit 0+ (PCIe Ctrl #2 Lane 0) |
Output |
PCIe PHY |
183 |
PCIE1_RST* |
PCIe #1 Reset (PCIe Ctrl #2). 4.7kΩ pull-up to 3.3V on the module. |
Output |
Open Drain – 3.3V |
182 |
PCIE20X1_2_CLKREQN_M0* |
PCIe #1 Clock Request (PCIe Ctrl #2). 47kΩ pull-up to 3.3V on the module. |
Bidir |
Open Drain – 3.3V |
173 |
PCIE20_0_REFCLKN |
PCIe #1 Reference Clock– (PCIe Ctrl #2) |
Output |
PCIe PHY |
175 |
PCIE20_0_REFCLKP |
PCIe #1 Reference Clock+ (PCIe Ctrl #2) |
Output |
PCIe PHY |
179 |
PCIE30X4_WAKEn_M0 |
PCIe Wake. 47kΩ pull-up to 3.3V on themodule. |
Input |
Open Drain – 3.3V |
PCIe 3.0 interface
Compatible with PCI Express Base Specification Revision 3.0
Support dual operation modes: Root Complex (RC) and End Point (EP)
Support data rates: 2.5 Gbps (PCIe 1.1), 5 Gbps (PCIe 2.1), 8 Gbps (PCIe 3.0)
Support aggregation and bifurcation with 1x 4 lanes, 2x 2 lanes, 4x 1 lanes and 1x 2 lanes + 2x 1 lanes
131 |
PCIE30_PORT0_RX0N |
PCIe #0 Receive 0– (PCIe Ctrl #0 Lane 0) |
Input |
PCIe PHY |
133 |
PCIE30_PORT0_RX0P |
PCIe #0 Receive 0+ (PCIe Ctrl #0 Lane 0) |
Input |
PCIe PHY |
137 |
PCIE30_PORT0_RX1N |
PCIe #0 Receive 1– (PCIe Ctrl #0 Lane 1) |
Input |
PCIe PHY |
139 |
PCIE30_PORT0_RX1P |
PCIe #0 Receive 1+ (PCIe Ctrl #0 Lane 1) |
Input |
PCIe PHY |
134 |
PCIE30_PORT0_TX0N |
PCIe #0 Transmit 0– (PCIe Ctrl #0 Lane 0) |
Output |
PCIe PHY |
136 |
PCIE30_PORT0_TX0P |
PCIe #0 Transmit 0+ (PCIe Ctrl #0 Lane 0) |
Output |
PCIe PHY |
140 |
PCIE30_PORT0_TX1N |
PCIe #0 Transmit 1– PCIe Ctrl #0 Lane 1) |
Output |
PCIe PHY |
142 |
PCIE30_PORT0_TX1P |
PCIe #0 Transmit 1+ (PCIe Ctrl #0 Lane 1) |
Output |
PCIe PHY |
181 |
PCIE30X4_PERSTn_M0 |
PCIe #0 Reset (PCIe Ctrl #0). 4.7kΩ pull-up to3.3V on the module. |
Bidir |
Open Drain – 3.3V |
180 |
PCIE30X4_CLKREQn_M0 |
PCIe #0 Clock Request (PCIe Ctrl #0). 47kΩpull-up to 3.3V on the module. |
Bidir |
Open Drain – 3.3V |
179 |
PCIE30X4_WAKEn_M0 |
Input Open |
Drain – 3.3V |
160 |
PCIE30_CLK_N |
PCIe #0 Reference Clock– |
Output |
PCIe PHY |
162 |
PCIE30_CLK_P |
PCIe #0 Reference Clock+ |
Output |
PCIe PHY |
Support 5 SPI Controllers (SPI0-SPI4)
Support two chip-select output
Support serial-master and serial-slave mode, software-configurable
SPI pin descriptions
91 |
SPI0_SCK |
SPI 0 Clock |
Bidir |
CMOS – 1.8 |
89 |
SPI0_MOSI |
SPI 0 Master Out / Slave In |
Bidir |
CMOS – 1.8 |
93 |
SPI0_MISO |
SPI 0 Master In / Slave Out |
Bidir |
CMOS – 1.8 |
95 |
SPI0_CS0* |
SPI 0 Chip Select 0 |
Bidir |
CMOS – 1.8 |
97 |
SPI0_CS1* |
SPI 0 Chip Select 1 |
Bidir |
CMOS – 1.8 |
106 |
SPI1_SCK |
SPI 1 Clock |
Bidir |
CMOS – 1.8 |
104 |
SPI1_MOSI |
SPI 1 Master Out / Slave In |
Bidir |
CMOS – 1.8 |
108 |
SPI1_MISO |
SPI 1 Master In / Slave Out |
Bidir |
CMOS – 1.8 |
110 |
SPI1_CS0* |
SPI 1 Chip Select 0 |
Bidir |
CMOS – 1.8 |
I2C pin descriptions
185 |
I2C2_SCL_M0 |
General I2C 0 Clock. 2.2kΩ pull-up to3.3V on module. |
Bidir |
Open Drain – 3.3V |
187 |
I2C2_SDA_M0 |
General I2C 0 Data. 2.2kΩ pull-up to 3.3V on the module. |
Bidir |
Open Drain – 3.3V |
189 |
I2C4_SCL_M2 |
General I2C 1 Clock. 2.2kΩ pull-up to 3.3V on the module. |
Bidir |
Open Drain – 3.3V |
191 |
I2C4_SDA_M2 |
General I2C 1 Data. 2.2kΩ pull-up to 3.3V on the module. |
Bidir |
Open Drain – 3.3V |
232 |
I2C6_SCL_M1 |
General I2C 2 Clock. 2.2kΩ pull-up to1.8V on the module. |
Bidir |
Open Drain – 1.8V |
234 |
I2C6_SDA_M1 |
General I2C 2 Data. 2.2kΩ pull-up to 1.8V on the module. |
Bidir |
Open Drain – 1.8V |
213 |
I2C3_SCL_M0 |
Camera I2C Clock. 2.2kΩ pull-up to 3.3V on the module. |
Bidir |
Open Drain – 3.3V |
215 |
I2C3_SDA_M0 |
Camera I2C Data. 2.2kΩ pull-up to 3.3V on the module. |
Bidir |
Open Drain – 3.3V |
Support 10 UART interfaces (UART0-UART9)
Embedded two 64-byte FIFO for TX and RX operation respectively
Support transmitting or receiving 5-bit, 6-bit, 7-bit, and 8-bit serial data
Standard asynchronous communication bits such as start, stop and parity
Support different input clocks for UART operation to get up to 4 Mbps baud rate
Support auto flow control mode for all UART interfaces
UART pin descriptions
| Pin | Pin name Signal | description | Direction | Pin type |
99 |
UART7_TX_M1 |
UART #0 Transmit |
Output |
CMOS – 1.8V |
101 |
UART7_RX_M1 |
UART #0 Receive |
Input |
CMOS – 1.8V |
103 |
UART7_RTSN_M1 |
UART #0 Request to Send |
Output |
CMOS – 1.8V |
105 |
UART7_CTSN_M1 |
UART #0 Clear to Send |
Input |
CMOS – 1.8V |
203 |
UART1_TX_M1 |
UART #1 Transmit |
Output |
CMOS – 1.8V |
205 |
UART1_RX_M1 |
UART #1 Receive |
Input |
CMOS – 1.8V |
207 |
UART1_RTSn_M1 |
UART #1 Request to Send |
Output |
CMOS – 1.8V |
209 |
UART1_CTSn_M1 |
UART #1 Clear to Send |
Input |
CMOS – 1.8V |
236 |
UART2_TX_M0_DEBUG |
UART #2 Transmit |
Output |
CMOS – 1.8V |
238 |
UART2_RX_M0_DEBUG |
UART #2 Receive |
Input |
CMOS – 1.8V |
Support transmitting or receiving CAN standard frame
Support transmitting or receiving CAN extended frame
Support transmitting or receiving data frame, remote frame, overload frame, error frame, and frame interval
CAN pin descriptions
145 |
CAN_TX CAN |
PHY |
Output |
CMOS – 3.3V |
143 |
CAN_RX CAN |
PHY |
Input |
CMOS – 3.3V [options="header",cols="1,2,2,1,2",width="90%"] |
All GPIOs can be used to generate interrupt
Support level trigger and edge trigger interrupt
Support configurable polarity of level trigger interrupt
Support configurable rising edge, falling edge and both edge trigger interrupt
Support configurable pull direction (a weak pull-up and a weak pull-down)
Support configurable drive strength
GPIO pin descriptions
87 |
GPIO1_C5 |
GPIO #0 or USB 0 VBUS Enable #0 |
Bidir |
CMOS – 1.8V |
118 |
GPIO3_A7/MIPI_CAM2_CLKOUT |
GPIO #1 or Generic Clocks |
Bidir |
CMOS – 1.8V |
124 |
GPIO #2 |
Bidir |
CMOS – 1.8V |
126 |
GPIO #3 |
Bidir |
CMOS – 1.8V |
127 |
GPIO4_A4/PCIE30X1_0_WAKEN_M1 |
GPIO #4 |
Bidir |
CMOS – 1.8V |
128 |
GPIO #5 |
Bidir |
CMOS – 1.8V |
130 |
GPIO4_A7/PCIE30X2_WAKEN_M1 |
GPIO #6 |
Bidir |
CMOS – 1.8V |
206 |
GPIO3_A0/PWM10 |
GPIO #7 or Pulse Width Modulator |
Bidir |
CMOS – 1.8V |
208 |
GPIO1_C6/PWM15_IR |
GPIO #8 or Fan Tach |
Bidir |
CMOS – 1.8V |
211 |
GPIO4_A0/I2S1_MCLK_M0/PCIE30X1_1_CLKREQN_M1 |
GPIO #9 or Audio Codec Master Clock |
Bidir |
CMOS – 1.8V |
212 |
GPIO4_A3/PCIE30X1_0_CLKREQN_M1 |
GPIO #10 |
Bidir |
CMOS – 1.8V |
216 |
GPIO #11 or Generic Clocks |
Bidir |
CMOS – 1.8V |
218 |
GPIO3_B4/I2S2_MCLK_M1/MIPI_CAM3_PDN |
GPIO #12 or Pulse Width Modulator |
Bidir |
CMOS – 1.8V |
228 |
GPIO3_B1/PWM2/MIPI_CAM4_CLKOUT |
GPIO #13 or Pulse Width Modulator |
Bidir |
CMOS – 1.8V |
230 |
GPIO3_A1/PWM11_IR/MIPI_CAM4_PDN |
GPIO #14 or Pulse Width Modulator |
Bidir |
CMOS – 1.8V |
i2s pin descriptions
199 |
I2S1_SCLK_M0/PCIE30X1_1_WAKEN_M1 |
I2S Audio Port 0 Clock |
Bidir |
CMOS – 1.8V |
197 |
I2S1_LRCK_M0/PCIE30X1_1_PERSTN_M1 |
I2S Audio Port 0 Left/Right Clock |
Bidir |
CMOS – 1.8V |
193 |
I2S1_SDO0_M0 |
I2S Audio Port 0 Data Out |
Output |
CMOS – 1.8V |
195 |
I2S1_SDI0_M0/PCIE30X1_0_PERSTN_M1 |
I2S Audio Port 0 Data In |
Input |
CMOS – 1.8V |
226 |
I2S2_SCLK_M1 |
I2S Audio Port 1 Clock |
Bidir |
CMOS – 1.8V |
224 |
I2S2_LRCK_M1 |
I2S Audio Port 1 Left/Right Clock |
Bidir |
CMOS – 1.8V |
220 |
I2S2_SDO_M1 |
I2S Audio Port 1 Data Out |
Output |
CMOS – 1.8V |
222 |
I2S2_SDI_M1 |
I2S Audio Port 1 Data In |
Input |
CMOS – 1.8V |
USB ports: 4x USB 3.0 Type-A
Display: 1x DisplayPort, 1x HDMI-out
Networking: Gigabit Ethernet
GPIO: 40-pin expansion header
Power connectors: DC Barrel jack for 5V power input, 5 V via Power over Ethernet
Expansion: M.2 (E-key, PCIe/USB/SDIO/UART), microSD
MIPI DSI: 1x 4 lanes MIPI DSI up to 4K@60 fps (x4)
MIPI CSI0/1: 2x 2 lanes MIPI CSI,Maximum 2.5Gbps per lane.
MIPI CSI2/3: 1x 4 lanes MIPI CSI,Maximum 2.5Gbps per lane.
Firmware: Flashing and device mode via USB Type-C
Dimensions: 100 x 80 x 29 mm (3.94 x 3.15 x 1.14 in)
| GPIO number | 功能 | Pin | Pin | 功能 | GPIO number |
+3.3V |
1 |
2 |
+5.0V |
139 |
I2S1_SDO2_M0 / I2C7_SDA_M3 / UART8_CTSN_M0 / PWM15_IR_M1 / CAN1_TX_M1 / GPIO4_B3 / |
3 |
4 |
+5.0V |
138 |
I2S1_SDO1_M0 / I2C7_SCL_M3 / UART8_RTSN_M0 / PWM14_M1 / CAN1_RX_M1 / GPIO4_B2 |
5 |
6 |
GND |
115 |
SPI1_CS1_M1 / I2C8_SDA_M4 / UART7_CTSN_M1 / PWM15_IR_M0 / GPIO3_C3 |
7 |
8 |
GPIO0_B5 /UART2_TX_M0/ I2C1_SCL_M0 / I2S1_MCLK_M1 / JTAG_TCK_M2 |
13 |
GND |
9 |
10 |
GPIO0_B6 /UART2_RX_M0/ I2C1_SDA_M0 / I2S1_SCLK_M1 / JTAG_TMS_M2 |
14 |
113 |
SPI1_CLK_M1 / UART7_RX_M1 / GPIO3_C1 |
11 |
12 |
GPIO3_B5 / CAN1_RX_M0 / PWM12_M0 /UART3_TX_M1 / I2S2_SCLK_M1 |
109 |
111 |
SPI1_MOSI_M1 / I2C3_SCL_M1 / GPIO3_B7 |
13 |
14 |
GND |
112 |
SPI1_MISO_M1 / I2C3_SDA_M1 / UART7_TX_M1 / GPIO3_C0 |
15 |
16 |
GPIO3_A4 / SPI4_CS1_M1 / I2S3_SDI / UART8_RTSN_M1 |
100 |
+3.3V |
17 |
18 |
GPIO4_C4 / PWM5_M2 / SPI3_MISO_M0 |
148 |
42 |
SPI0_MOSI_M2 / UART4_RX_M2 / GPIO1_B2 |
19 |
20 |
GND |
41 |
SPI0_MISO_M2 / GPIO1_B1 |
21 |
22 |
SARADC_IN4 |
43 |
SPI0_CLK_M2 / UART4_TX_M2 / GPIO1_B3 |
23 |
24 |
GPIO1_B4 / UART7_RX_M2 / SPI0_CS0_M2 |
44 |
GND |
25 |
26 |
GPIO1_B5 / UART7_TX_M2 / SPI0_CS1_M2 |
45 |
150 |
SPI3_CLK_M0 / I2C0_SDA_M1 / PWM7_IR_M3 / GPIO4_C6 |
27 |
28 |
GPIO4_C5 / PWM6_M2 / I2C0_SCL_M1 / |
63 |
UART1_CTSN_M1 / PWM15_IR_M3 / GPIO1_D7 |
29 |
30 |
GND |
47 |
SPDIF_TX_M0 / UART1_RX_M1 / PWM13_M2 / GPIO1_B7 |
31 |
32 |
GPIO3_C2 / PWM14_M0 / UART7_RTSN_M1 / I2C8_SCL_M4 / SPI1_CS0_M1 |
114 |
103 |
PWM8_M0 / GPIO3_A7 |
33 |
34 |
GND |
110 |
I2S2_LRCK_M1 / UART3_RX_M1 / PWM13_M0 / CAN1_TX_M0 / GPIO3_B6 |
35 |
36 |
GPIO3_B1 / PWM2_M1 / UART2_TX_M2 |
105 |
0 |
REFCLK_OUT / GPIO0_A0 |
37 |
38 |
GPIO3_B2 /PWM3_IR_M1 / UART2_RX_M2 / I2S2_SDI_M1 |
106 |
GND |
39 |
40 |
GPIO3_B3 / UART2_RTSN / I2S2_SDO_M1 |
107 |
| BPI-AIM7 BSP code : https://github.com/ArmSoM/manifests |
| BPI-AIM7 kernel code: https://github.com/ArmSoM/rockchip-kernel |
| BPI-AIM7 uboot code : https://github.com/ArmSoM/u-boot |
| RKNN-LLM Code repository: https://docs.armsom.org/advanced-manual/rknn-llm |
| Armbian Linux build framework: https://github.com/armbian/build |
| Rockchip RK3588 datasheet |
Baidu cloud: https://pan.baidu.com/s/1GeskKfLFwjgmz0pgt7sICg?pwd=8888 (pincode:8888)
| BPI-AIM7 and BPI-AIM7IO sch、2D、assy |
Viewing via Google links online may have issues; please download and extract the file before viewing. Core board and I/O baseboard information is contained in hardware.zip.
| BPI-AIM7 AI computer module boot with NVIDIA Jetson Nano base board https://www.youtube.com/watch?v=jAYCIUlWb34 |
| How to use RKLLM AI function: Banana Pi BPI-M7 RKLLM Development |
Debian for BPI-AIM7: https://drive.google.com/drive/folders/1Qx76r_cDufivFqfNwLmpsgJSmDdxMB9y
Armbian for BPI-AIM7 : https://github.com/armbian/community/releases
ubuntu-rockchip for BPI-AIM7: https://github.com/Joshua-Riek/ubuntu-rockchip/releases
CE / FCC / RoHS
The BPI-AIM7 will be produced at least until August 2034.
| BANANAPI Official Shop: https://www.bpi-shop.com/products/bpi-aim7-rockchip-rk3588.html |
| Bipai Aliexpress shop: https://www.aliexpress.com/item/1005013331847429.html |
| OEM&ODM, please contact: [email protected] |
