apt-get -y install git
git clone https://github.com/armbian/build
cd build
./compile.sh
The Banana Pi M1 is our first product in our goal of creating an open source devlopment board community. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
| More Infomation: Banana Pi BPI-M1 |
Allwinner A20 Dual-core 1.0GHz CPU
Mali-400 MP2 with Open GL ES 2.0/1.1.
1 GB DDR3 memory.
1x SATA interface.
1x Gigabit LAN
1x USB otg and 2x USB 2.0
1X MIC
AV vide out
HDMI out
IR
CSI camera interface
DSI display interface
26 PIN GPIO
x86_64 or aarch64 machine with at least 2GB of memory and ~35GB of disk space for a virtual machine, container or bare metal installation Ubuntu Jammy 22.04.x amd64 or aarch64 for native building or any Docker capable amd64 / aarch64 Linux for containerised
cd build
./compile.sh
Download PhoenixCard: Download Link
Download the M1 image.
Put your TF card into a TF-USB adapter, and then plug adapter in your Windows PC usb interface.
Prepare your image, and download image burning tools PhoenixCard.exe.
Use "PhoenixCard.exe" to burn android image to TF card.
Select the image in the image path option
Select set as card startup, then click on burn image
Burning ended.
Prepare a PC which runs ubuntu
Install Docker-ce on your PC,https://docs.docker.com/install/linux/docker-ce/ubuntu/#install-docker-ce
After install Docker, execute "docker pull sinovoip/bpi-build-android:a20_01", to pull image
Then you pulled image, execute "docker run --privileged -d -p 2223:22 -v /media:/media sinovoip/bpi-build-android:a20_01"
"ssh -p 2223 [email protected] #default passwd is root"
Execute "git clone https://github.com/BPI-SINOVOIP/BPI-M1-bsp.git" on your ubuntu terminal
Execute "./build.sh" to build M1 bsp code
After built, open a new terminal, execute "docker cp xxxxx(your container id):xxxxx(your project path) xxxxx(your pc path)"
Download the latest image from the forum.
Put the TF card into a card reader and plug it to your PC USB interface.
Download the flashing tools "BalenaEtcher" and start it.
Click "Flash from file" to select your image file.(.img or .zip)
Click "Select target" to choose your USB device.
Start to flash and wait for a moment.
Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
Using your USB-Serial Connect debug console on M1
You could download latest image from our forum
Install bpi-tools on your system. If you can’t access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
apt-get install pv
curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
After you download the image, insert your TF card into your Ubuntu
Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card.
After step 3, then you can insert your TF card into M1, and press power button setup M1
Update your bpi tools
bpi-tools
Download new driver to update your image
bpi-update -c bpi-m1.conf
Check download files’ type is compressed data
file *.tgz
Execute
bpi-bootsel
you will see the bootloader path, “/usr/lib/u-boot/bananapi/u-boot-2018.01/u-boot-2018.01-bpi-m1-8k.img.gz”
Update your bootloader
bpi-bootsel /usr/lib/u-boot/bananapi/u-boot-2018.01/u-boot-2018.01-bpi-m1-8k.img.gz
Reboot
