It is the first open source hardware launched by the banana pie team, and also a classic product with the largest cumulative sales of banana pie.There are still a lot of business clients that apply to various projects.A20 chip
Allwinner A20 design: Banana Pi BPI-M1 SBC Allwinner A20 design: Banana Pi BPI-M1+ SBC Allwinner A20 design: Banana Pi BPI-R1 Router Allwinner R64 design: Banana Pi BPI-M64 SBC Allwinner A83T design: Banana Pi BPI-W3 SBC |
Allwinner A20 Dual-core 1.0GHz CPU
Mali-400 MP2 with Open GL ES 2.0/1.1.
1 GB DDR3 memory.
1x SATA interface.
1x Gigabit LAN
1x USB otg and 2x USB 2.0
1X MIC
AV vide out
HDMI out
IR
CSI camera interface
DSI display interface
26 PIN gpio
| HardWare Specification of Banana Pi M1 | |
CPU |
A20 ARM Cortex -A7 Dual-Core |
GPU |
ARM Mali 400 MP2; Complies with OpenGL ES 2.0/1.1 |
Memory |
1GB DDR3 |
Flash |
None |
Network |
10/100/1000 Ethernet 8P8C (1000BASE-T) |
WIFI&BT |
None |
Video Input |
A CSI input connector allows for the connection of a designed camera module |
Video Outputs |
HDMI, CVBS, LVDS/RGB |
Audio Outputs |
3.5mm jack and HDMI |
Power |
5 volts DC via Micro USB or GPIO |
USB 2.0 ports |
2 (direct from Allwinner A20 chip) |
GPIO |
GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND |
LED |
Power Key & 8P8C |
Storage |
SATA 2.0, |
Banana Pi BPI-M1 has a 26-pin GPIO header . Following is the Banana Pi GPIO Pinout:
| Note: 5V1,5V2 only support output,not support input |
| 40 PIN GPIO of Banana pi BPI-M1 | ||
CSI GPIO Pin |
Pin Name |
GPIO |
CON1 P01 |
LINEINL |
CON1 P02 |
LINEINR |
CON1 P03 |
VCC-CSI |
CON1 P04 |
ADC\_X1 |
CON1 P05 |
GND |
CON1 P06 |
ADC\_X2 |
CON1 P07 |
FMINL |
CON1 P08 |
ADC\_Y1 |
CON1 P09 |
FMINR |
CON1 P10 |
ADC\_Y2 |
CON1 P11 |
GND |
CON1 P12 |
CSI-FLASH |
PH17 |
CON1 P13 |
LRADC0 |
CON1 P14 |
TWI1-SDA |
PB19 |
CON1 P15 |
LRADC1 |
CON1 P16 |
TWI1-SCK |
PB18 |
CON1 P17 |
CSI-D0 |
PE4 |
CON1 P18 |
CSI0-STBY-EN |
PH19 |
CON1 P19 |
CSI0-D1 |
PE5 |
CON1 P20 |
CSI-PCLK |
PE0 |
CON1 P21 |
CSI-D2 |
PE6 |
CON1 P22 |
CSI0-PWR-EN |
PH16 |
CON1 P23 |
CSI-D3 |
PE7 |
CON1 P24 |
CSI0-MCLK |
PE1 |
CON1 P25 |
CSI-D4 |
PE8 |
CON1 P26 |
CSI0-RESET\# |
PH14 |
CON1 P27 |
CSI-D5 |
PE9 |
CON1 P28 |
CSI-VSYNC |
PE3 |
CON1 P29 |
CSI-D6 |
PE10 |
CON1 P30 |
CSI-HSYNC |
PE2 |
CON1 P31 |
CSI-D7 |
PE11 |
CON1 P32 |
CSI1-STBY-EN |
PH18 |
CON1 P33 |
RESET\# |
CON1 P34 |
CSI1-RESET\# |
PH13 |
CON1 P35 |
CSI-IO0 |
PH11 |
CON1 P36 |
HPR |
CON1 P37 |
HPL |
CON1 P38 |
IPSOUT |
CON1 P39 |
GND |
CON1 P40 |
IPSOUT |
| LVDS GPIO of Banana Pi BPI-M1 | |||
LVDS Pin |
Pin Name |
Function1 |
Function2(GPIO) |
CON2 P01 |
IPSOUT\(5V output\) |
CON2 P02 |
TWI3-SDA |
PI1 |
CON2 P03 |
CON2 P04 |
TWI3-SCK |
PI0 |
CON2 P05 |
GND |
CON2 P06 |
LCD0-IO0 |
PH7 |
CON2 P07 |
LCDIO-03 |
PH12 |
CON2 P08 |
LCD0-IO1 |
PH8 |
CON2 P09 |
LCD0-D0 |
LVDS0-VP0 |
PD0 |
CON2 P10 |
PWM0 |
PB2 |
CON2 P11 |
LCD0-D1 |
LVDS0-VN0 |
PD1 |
CON2 P12 |
LCD0-IO2 |
PH9 |
CON2 P13 |
LCD0-D2 |
LVDS0-VP1 |
PD2 |
CON2 P14 |
LCD0-DE |
PD25 |
CON2 P15 |
LCD0-D3 |
LVDS0-VN1 |
PD3 |
CON2 P16 |
LCD0-VSYNC |
CON2 P17 |
LCD0-D4 |
LVDS0-VP2 |
PD4 |
CON2 P18 |
LCD0-HSYNC |
CON2 P19 |
LCD0-D5 |
LVDS0-VN2 |
PD5 |
CON2 P20 |
LCD0-CS |
CON2 P21 |
LCD0-D6 |
LVDS0-VPC |
PD6 |
CON2 P22 |
LCD0-CLK |
PD24 |
CON2 P23 |
LCD0-D7 |
LVDS0-VNC |
PD7 |
CON2 P24 |
GND |
CON2 P25 |
LCD0-D8 |
LVDS0-VP3 |
PD8 |
CON2 P26 |
LCD0-D23 |
PD23 |
CON2 P27 |
LCD0-D9 |
LVDS0-VN3 |
PD9 |
CON2 P28 |
LCD0-D22 |
PD22 |
CON2 P29 |
LCD0-D10 |
PD10 |
CON2 P30 |
LCD0-D21 |
PD21 |
CON2 P31 |
LCD0-D11 |
PD11 |
CON2 P32 |
LCD0-D20 |
PD20 |
CON2 P33 |
LCD0-D12 |
PD12 |
CON2 P34 |
LCD0-D19 |
PD19 |
CON2 P35 |
LCD0-D13 |
PD13 |
CON2 P36 |
LCD0-D18 |
PD18 |
CON2 P37 |
LCD0-D14 |
PD14 |
CON2 P38 |
LCD0-D17 |
PD17 |
CON2 P39 |
LCD0-D15 |
PD15 |
CON2 P40 |
LCD0-D16 |
PD16 |
| Jumper J11 of Banana Pi BPI-M1 | |||
J11 Pin |
Pin Name |
Function1 |
Function2(GPIO) |
J11 Pin1 |
TXD |
UART0-TX |
PB22 |
J11 Pin2 |
RXD |
UART0-RX |
PB23 |
| Jumper J12 of Banana Pi BPI-M1 | |||
J12 Pin |
Pin Name |
Function1 |
Function2(GPIO) |
J12 Pin1 |
5V |
J12 Pin2 |
3V3 |
J12 Pin3 |
NC |
IO-7 |
PH5 |
J12 Pin4 |
RXD |
UART7_RX |
PI21 |
J12 Pin5 |
NC |
IO-8 |
PH3 |
J12 Pin6 |
TXD |
UART7_TX |
PI20 |
J12 Pin7 |
GND |
J12 Pin8 |
GND |
| Linux kernel 3.4 Source code : https://github.com/BPI-SINOVOIP/BPI-M1-bsp |
| Android 4.4 source code. LCD7 type: https://github.com/BPI-SINOVOIP/BPI-A20-Android-4.4 |
| Android 4.2.2 source code. HDMI type: https://github.com/BPI-SINOVOIP/BPI-A20-Android |
| BPI-M1 Gerber/Boom/Assembly document: |
Baidu cloud: https://pan.baidu.com/s/1bM8NR12Wp_dtp-m52nuKrA?pwd=8888 (pincode:8888)
| Schematic diagram: https://drive.google.com/drive/folders/0B4PAo2nW2KfnflVqbjJGTFlFTTd1b1o1OUxDNk5ackVDM0RNUjBpZ0FQU19SbDk1MngzZWM?resourcekey=0-ZRCiv304nGzvq-w7lwnpjg&usp=sharing |
| BPI-M1 DXF file download link: google drive |
| BPI-M1 3D design file download link: google drive |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| CE FCC RoHS : BPI-M1 CE,FCC,RoHS |
| Arch linux wiki for BPI-M1: https://wiki.archlinux.org/index.php/Banana_Pi |
| Nas for BPI-M1/BPI-M1+ : https://www.hackster.io/jeffbaocai/bananapi-pro-nas-0815dc?ref=platform&ref_id=8064_popular___&offset=3 |
| NetBSD/evbarm on Allwinner SoCs : https://wiki.netbsd.org/ports/evbarm/allwinner/#index1h1 |
| Gentoo for banana pi : https://wiki.gentoo.org/wiki/Banana_Pi_the_Gentoo_Way |
| OpenSUSE for banana pi : https://en.opensuse.org/HCL:BananaPi |
| How to booting from SSD using Lubuntu / Raspbian https://bananapi.gitbooks.io/bpi-m1/content/en/howtobootingfromssdusinglubunturaspbian.html |
| Building the cluster on BPI https://www.hackster.io/Penguinfly/banana-pi-cluster-47d566 |
| Allwinner documents. allwinner chip online datasheet and documents: http://dl.linux-sunxi.org/ |
| 2018-07-28 update android 4.4 LCD version image |
Features Map: https://docs.banana-pi.org/en/M1_Image_Map
Baidu Drive: https://pan.baidu.com/s/1DfSIiMvW_I-kFjTZMtcVsA
| Release Date: 2018-07-26 |
Baidu Drive: https://pan.baidu.com/s/1HErsANQ4PsnwQJ-tH0AdTg
| 2022-09-07 Armbian_22.11.0-trunk_Bananapi_jammy_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1fM-in68EK_ABvSJ7XiY0Ag?pwd=yft7 PIN code: yft7
| Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 , BPI-M2 Ultra/Berry use kernel 3.10 |
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-new-image-ubuntu-16-04-with-allwinner-bsp-use-mpv-play-1080p-video/13272
| 2018-7-28 update :Ubuntu Server16.04 HDMI Version Image Link |
Baidu Drive: https://pan.baidu.com/s/1GYH8oDK3T_WcUFn-0t9YmQ
Baidu Drive: https://pan.baidu.com/s/1Tw_99XBZVOmKyavNxCXv3w
| 2022-09-07 Armbian_22.11.0-trunk_Bananapi_BPI-M1_bullseye_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1Vclux6Wb-ToJGOaGQxV6Hg?pwd=m4a3 PIN code: m4a3
| 2019-9-18 update. Debian 10 buster mate desktop with grub support (boot-2019.07 + kernel 5.1.1) |
| 2023-07 Armbian_23.02.0_Banana Pi BPI-M1 |
Baidu Cloud: https://pan.baidu.com/s/1pPh0vomR3MZozm2iLqBAmA?pwd=8888 PIN code: 8888
| 2023-07 Armbian_23.08.0_Banana Pi BPI-M1 |
Baidu Cloud: https://pan.baidu.com/s/1L3ZTQt_JOWRrAcA7bZakmA?pwd=8888 PIN code: 8888
| Armbian_23.02.0-trunk_Bananapi_jammy_current_5.15.93.img.xz and Armbian_23.02.0-trunk_Bananapi_jammy_edge_6.1.11.img.xz |
Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-bpi-m1-new-armbian-image/15157
| 2022-12-06 Armbian_22.11.0-trunk_Bananapi BPI-M1_bullseye_edge_6.0.9.img.xz |
Baidu Cloud: https://pan.baidu.com/s/12R8mIf7_45HDtruqEvktBw?pwd=8888 PIN code: 8888
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m1-new-image-release-armbian-bullseye/14446/2
| Armbian Xenial and Armbian Jessie |
Image lownload link: https://www.armbian.com/bananapi/
| BPI-M1/BPI-M1+/BPI-R1 use A20 chip,so easy to run openwrt |
Openwrt support for allwinner: https://oldwiki.archive.openwrt.org/toh/lemaker/bananapi
Image download: https://downloads.openwrt.org/chaos_calmer/15.05/sunxi/generic/uboot-sunxi-Lamobo_R1/
Opwrt for Allwinner Soc: https://oldwiki.archive.openwrt.org/toh/lemaker/bananapi
| How to build OpenWRT image from github : https://bananapi.gitbooks.io/bpi-m1/content/en/howtobuildopenwrtimagefromgithub.html |
Allwinner A20 (sun7i), a dual-core Cortex-A7 BPI-M1/BPI-M1+/BPI-R1
Allwinner A31 and A31s (sun6i), a quad-core Cortex-A7 BPI-M2
Allwinner A64 (sun50i), a quad-core Cortex-A53 BPI-M64
Allwinner A83T (sun8i), an octa-core Cortex-A7 BPI-M3
Allwinner H3 (sun8i), a quad-core Cortex-A7 BPI-M2+/BPI-M2+ EDU/
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/opensuse.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/openmediavault.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/arch_linux.html |
Gentoo Linux have officeal support banana pi BPI-M1, so you also can use on BPI-M1+,and BPI-R1, all is base on allwinner A20 chip.
| Gentoo linux wiki : https://wiki.gentoo.org/wiki/Banana_Pi_the_Gentoo_Way |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/raspbsdonbpi-m1.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/centos7linuxforbpi.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/dietpi.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/freebsdnetbsd.html |
Banana Pi M2+ with H3 chip
Banana Pi M3 with A83T chip
BPI-M1 and BPI-M1+ use A20 chip
| Simplenas image : https://simplenas.com/download/other/banana-pi-m1 |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M1/1100417230_40000003426518.html |
| Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M1/1101951077_40000003418620.html |
| OEM&ODM, please contact: [email protected] |
