Banana Pi BPI-M1 Plus upgrade is an open-source single-board computer that adds more connectivity to the classic board. It features the same high performance AllWinner A20 dual-core SoC at 1GHz, 1GB of DDR3 SDRAM, Gigabit Ethernet, SATA, USB, and HDMI connections found in classic BPI-M1+ ; but the Banana Pi M1+ features onboard WiFi g/b/n. The board supports all classic projects and even more because of the onboard WIFi chip. Like its sibling, it can run operating systems including Android, Lubuntu, Ubuntu, Debian, and Raspbian.
Allwinner A20 design: Banana Pi BPI-M1 SBC Allwinner A20 design: Banana Pi BPI-M1+ SBC Allwinner A20 design: Banana Pi BPI-R1 Router Allwinner R64 design: Banana Pi BPI-M64 SBC Allwinner A83T design: Banana Pi BPI-M3 SBC |
Banana Pi M1+ is our upgraded M1 board. We feel like the onboard WiFi adds a lot more features to the board and makes it more convient for users to set up their linx desktop or router projects. Banana Pi is an open platform device, it is for anyone who wants to play and build with developer technology instead of simply using consumer technology. Backed by our community, starting a project and building servers is fun and rewarding. With a Banana Pi, we want you to explore and experience the world of DIY projects and portable computing. We welcome all companies, DIYers, and tech loving people within our community! Together, we can make a difference, we can discover our passions, inspire others, and build a practical project.
Allwinner A20 Dual-core 1.0GHz CPU
Mali-400 MP2 with Open GL ES 2.0/1.1.
1 GB DDR3 memory.
Wifi support onboard
1x SATA interface.
1x Gigabit LAN
1x USB otg and 2x USB 2.0
1X MIC
AV out
HDMI out
IR
CSI camera interface
DSI display interface
40 PIN gpio
3.7V lithium battery interface
| HardWare Specification of Banana Pi M1+(Plus) | |
CPU |
A20 ARM Cortex -A7 Dual-Core |
GPU |
ARM Mali400MP2Complies with OpenGL ES 2.0/1.1 |
Memory |
1GB DDR3 |
Network |
10/100/1000 Ethernet |
wifi&BT |
Wifi support onboard |
Video Input |
A CSI input connector allows for the connection of a designed camera module |
Video Outputs |
HDMI, CVBS, LVDS/RGB |
Audio Outputs |
3.5mm jack and HDMI |
Power Source |
5V/2A via Micro USB (DC in only) and / or Micro USB OTG |
USB 2.0 ports |
2(direct from Allwinner A20 chip) |
GPIO |
GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND |
LED |
Power Key & 8P8C |
Storage |
SATA 2.0 |
OS |
Android 4.4, Android 4.2, Raspbian, Lubuntu, Open Suse, Debian |
Banana Pi BPI-M1+ has a 40-pin GPIO header . Following is the Banana Pi GPIO Pinout:
| 40 PIN GPIO of Banana pi BPI-M1+(Plus) | ||
GPIO Pin Name |
Default Function |
Function2:GPIO |
CON3-P01 |
VCC-3V3 |
CON3-P02 |
VCC-DC |
CON3-P03 |
TWI2-SDA |
PB21 |
CON3-P04 |
VCC-DC |
CON3-P05 |
TWI2-SCK |
PB20 |
CON3-P06 |
GND |
CON3-P07 |
PWM1 |
PI3 |
CON3-P08 |
UART3\_TX |
PH0 |
CON3-P09 |
GND |
CON3-P10 |
UART3\_RX |
PH1 |
CON3-P11 |
UART2\_RX |
PI19 |
CON3-P12 |
PH2 |
PH2 |
CON3-P13 |
UART2\_TX |
PI18 |
CON3-P14 |
GND |
CON3-P15 |
UART2\_CTS |
PI17 |
CON3-P16 |
CAN\_TX |
PH20 |
CON3-P17 |
VCC-3V3 |
CON3-P18 |
CAN\_RX |
PH21 |
CON3-P19 |
SPI0\_MOSI |
PI12 |
CON3-P20 |
GND |
CON3-P21 |
SPI0\_MISO |
PI13 |
CON3-P22 |
UART2\_RTS |
PI16 |
CON3-P23 |
SPI0\_CLK |
PI11 |
CON3-P24 |
SPI0\_CS0 |
PI10 |
CON3-P25 |
GND |
CON3-P26 |
SPI0\_CS1 |
PI14 |
CON3-P27 |
TWI3-SDA |
PI1 |
CON3-P28 |
TWI3-SCK |
PI0 |
CON3-P29 |
I2S\_MCLK |
PB5 |
CON3-P30 |
GND |
CON3-P31 |
I2S\_BCLK |
PB6 |
CON3-P32 |
I2S\_DI |
PB12 |
CON3-P33 |
I2S\_LRCK |
PB7 |
CON3-P34 |
GND |
CON3-P35 |
I2S\_DO0 |
PB8 |
CON3-P36 |
UART7\_RX |
PI21 |
CON3-P37 |
IR0\_TX |
PB3 |
CON3-P38 |
UART7\_TX |
PI20 |
CON3-P39 |
GND |
CON3-P40 |
SPDIF\_DO |
PB13 |
| CSI PIN of Banana pi BPI-M1 Plus | ||
CSI Pin Name |
Default Function Pin name |
Function2:GPIO |
CON1 P01 |
LINEINL |
CON1 P02 |
LINEINR |
CON1 P03 |
VCC-CSI |
CON1 P04 |
ADC\_X1 |
CON1 P05 |
GND |
CON1 P06 |
ADC\_X2 |
CON1 P07 |
FMINL |
CON1 P08 |
ADC\_Y1 |
CON1 P09 |
FMINR |
CON1 P10 |
ADC\_Y2 |
CON1 P11 |
GND |
CON1 P12 |
CSI-FLASH |
PH17 |
CON1 P13 |
LRADC0 |
CON1 P14 |
TWI1-SDA |
PB19 |
CON1 P15 |
LRADC1 |
CON1 P16 |
TWI1-SCK |
PB18 |
CON1 P17 |
CSI-D0 |
PE4 |
CON1 P18 |
CSI0-STBY-EN |
PH19 |
CON1 P19 |
CSI0-D1 |
PE5 |
CON1 P20 |
CSI-PCLK |
PE0 |
CON1 P21 |
CSI-D2 |
PE6 |
CON1 P22 |
CSI0-PWR-EN |
PH16 |
CON1 P23 |
CSI-D3 |
PE7 |
CON1 P24 |
CSI0-MCLK |
PE1 |
CON1 P25 |
CSI-D4 |
PE8 |
CON1 P26 |
CSI0-RESET\# |
PH14 |
CON1 P27 |
CSI-D5 |
PE9 |
CON1 P28 |
CSI-VSYNC |
PE3 |
CON1 P29 |
CSI-D6 |
PE10 |
CON1 P30 |
CSI-HSYNC |
PE2 |
CON1 P31 |
CSI-D7 |
PE11 |
CON1 P32 |
CSI1-STBY-EN |
PH18 |
CON1 P33 |
AP-RESET\# |
CON1 P34 |
CSI1-RESET\# |
PH13 |
CON1 P35 |
CSI-IO0 |
PH11 |
CON1 P36 |
HPR |
CON1 P37 |
HPL |
CON1 P38 |
IPSOUT |
CON1 P39 |
GND |
CON1 P40 |
IPSOUT |
| LVDS PIN of Banana pi BPI-M1 Plus | |||
LVDS Pin |
Default Function |
Function2 |
Function3:GPIO |
CON2 P01 |
IPSOUT\(5V output\) |
CON2 P02 |
TWI3-SDA |
PI1 |
CON2 P03 |
CON2 P04 |
TWI3-SCK |
PI0 |
CON2 P05 |
GND |
CON2 P06 |
LCD0-IO0 |
PH7 |
CON2 P07 |
LCDIO-03 |
PH12 |
CON2 P08 |
LCD0-IO1 |
PH8 |
CON2 P09 |
LCD0-D0 |
LVDS0-VP0 |
PD0 |
CON2 P10 |
PWM0 |
PB2 |
CON2 P11 |
LCD0-D1 |
LVDS0-VN0 |
PD1 |
CON2 P12 |
LCD0-IO2 |
CON2 P13 |
LCD0-D2 |
LVDS0-VP1 |
PD2 |
CON2 P14 |
LCD0-DE |
PD25 |
CON2 P15 |
LCD0-D3 |
LVDS0-VN1 |
PD3 |
CON2 P16 |
LCD0-VSYNC |
PD27 |
CON2 P17 |
LCD0-D4 |
LVDS0-VP2 |
PD4 |
CON2 P18 |
LCD0-HSYNC |
PD26 |
CON2 P19 |
LCD0-D5 |
LVDS0-VN2 |
PD5 |
CON2 P20 |
LCD0-CS |
CON2 P21 |
LCD0-D6 |
LVDS0-VPC |
PD6 |
CON2 P22 |
LCD0-CLK |
PD24 |
CON2 P23 |
LCD0-D7 |
LVDS0-VNC |
PD7 |
CON2 P24 |
GND |
CON2 P25 |
LCD0-D8 |
LVDS0-VP3 |
PD8 |
CON2 P26 |
LCD0-D23 |
PD23 |
CON2 P27 |
LCD0-D9 |
LVDS0-VN3 |
PD9 |
CON2 P28 |
LCD0-D22 |
PD22 |
CON2 P29 |
LCD0-D10 |
PD10 |
CON2 P30 |
LCD0-D21 |
PD21 |
CON2 P31 |
LCD0-D11 |
PD11 |
CON2 P32 |
LCD0-D20 |
PD20 |
CON2 P33 |
LCD0-D12 |
PD12 |
CON2 P34 |
LCD0-D19 |
PD19 |
CON2 P35 |
LCD0-D13 |
PD13 |
CON2 P36 |
LCD0-D18 |
PD18 |
CON2 P37 |
LCD0-D14 |
PD14 |
CON2 P38 |
LCD0-D17 |
PD17 |
CON2 P39 |
LCD0-D15 |
PD15 |
CON2 P40 |
LCD0-D16 |
PD16 |
| Pin Name | Default Function | GPIO |
CON4-P03 |
UART0-TXD |
PB22 |
CON4-P02 |
UART0-RXD |
PB23 |
CON4-P01 |
GND |
| Linux kernel 3.4 Source code : https://github.com/BPI-SINOVOIP/BPI-M1-bsp |
| Android 4.4 source code LCD7 type: https://github.com/BPI-SINOVOIP/BPI-A20-Android-4.4 |
| Android 4.2.2 source code HDMI type: https://github.com/BPI-SINOVOIP/BPI-A20-Android |
| BPI-M1+ Gerber/Boom/Assembly document: |
Baidu cloud: https://pan.baidu.com/s/1Vc6b81eysfECBgsY7IZ-sQ?pwd=8888 (pincode: 8888)
| Schematic diagram: google drive |
| BPI-M1+ DXF file download link : google drive |
| BPI-M1+ 3D design file download link : google drive |
Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files
All banana pi docement(SCH file,DXF file,and doc)
CE FCC RoHS :BPI-M1 CE,FCC,RoHS
Arch linux wiki for BPI-M1: https://wiki.archlinux.org/index.php/Banana_Pi
Nas for BPI-M1/BPI-M1+ : https://www.hackster.io/jeffbaocai/bananapi-pro-nas-0815dc?ref=platform&ref_id=8064_popular___&offset=3
NetBSD/evbarm on Allwinner SoCs : https://wiki.netbsd.org/ports/evbarm/allwinner/#index1h1
Gentoo for banana pi : https://wiki.gentoo.org/wiki/Banana_Pi_the_Gentoo_Way
OpenSUSE for banana pi : https://en.opensuse.org/HCL:BananaPi
How to booting from SSD using Lubuntu / Raspbian: https://bananapi.gitbooks.io/bpi-m1/content/en/howtobootingfromssdusinglubunturaspbian.html
Building the cluster on BPI: https://www.hackster.io/Penguinfly/banana-pi-cluster-47d566
Allwinner chip online datasheet and documents: http://dl.linux-sunxi.org/
| 2018-07-28 update android 4.4 LCD version image |
Features Map: https://docs.banana-pi.org/en/M1_Image_Map
Baidu Drive: https://pan.baidu.com/s/1DfSIiMvW_I-kFjTZMtcVsA
| 2022-09-07 Armbian_22.11.0-trunk_Bananapim1plus_jammy_edge_5.19.6_xfce_desktop.img |
Baidu Cloud: https://pan.baidu.com/s/1SOeRKjVmTqTb6rMD71SfAw?pwd=wbnt PIN code: wbnt
| Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 |
| 2022-09-07 Armbian_22.11.0-trunk_Bananapim1plus_bullseye_edge_5.19.6_xfce_desktop |
Baidu Cloud: https://pan.baidu.com/s/1JtqdKE4AsAwCc6i_Wys_VA?pwd=6kgc PIN code: 6kgc
| 2019-9-18 update. Debian 10 buster mate desktop with grub support (boot-2019.07 + kernel 5.1.1) |
| BPI-M1/BPI-M1+/BPI-R1 use A20 chip,so easy to run openwrt wiki : https://wiki.openwrt.org/toh/lamobo/r1 |
| Openwrt support for allwinner : https://wiki.openwrt.org/doc/hardware/soc/soc.allwinner.sunxi?s |
| Image download : https://downloads.openwrt.org/chaos_calmer/15.05/sunxi/generic/uboot-sunxi-Lamobo_R1/ |
| Opwrt for Allwinner Soc : https://wiki.openwrt.org/doc/hardware/soc/soc.allwinner.sunxi?s |
| How to build OpenWRT image from github : https://bananapi.gitbooks.io/bpi-m1/content/en/howtobuildopenwrtimagefromgithub.html |
| Armbian_23.02.0-trunk_Bananapim1plus_jammy_edge_6.1.11_xfce_desktop.img.xz |
Google Drive: https://drive.google.com/drive/folders/1VpvVkYMqgmSnmfKXQSrEY2B6wRa-cggL?usp=share_link
Discuss on forum : https://forum.banana-pi.org/t/banana-pi-bpi-m1-plus-new-armbian-image/15158
| 2022-12-06 Armbian_22.11.0-trunk_Bananapi BPI-M1+ bullseye_edge_6.0.9.img.xz |
Baidu Cloud: https://pan.baidu.com/s/1ePzBiwN0wEd8j3muk1HOlA?pwd=8888 PIN code: 8888
Discuss on forum: https://forum.banana-pi.org/t/bananapi-bpi-m1-new-image-release-armbian-bullseye/14447/2
| Armbian Xenial and Armbian Jessie |
Image lownload link: https://www.armbian.com/banana-pi-plus/
| FreeBSD on Allwinner (sunxi) systems for banana pi |
Allwinner A20 (sun7i), a dual-core Cortex-A7 BPI-M1/BPI-M1+/BPI-R1
Allwinner A31 and A31s (sun6i), a quad-core Cortex-A7 BPI-M2
Allwinner A64 (sun50i), a quad-core Cortex-A53 BPI-M64
Allwinner A83T (sun8i), an octa-core Cortex-A7 BPI-M3
Allwinner H3 (sun8i), a quad-core Cortex-A7 BPI-M2+/BPI-M2+ EDU/
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/opensuse.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/openmediavault.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/arch_linux.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/gentoolinux.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/raspbsdonbpi-m1.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/centos7linuxforbpi.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/dietpi.html |
| Image and how to : https://bananapi.gitbooks.io/bpi-m1/content/en/freebsdnetbsd.html |
Banana Pi M2+ with H3 chip
Banana Pi M3 with A83T chip
BPI-M1 and BPI-M1+ use A20 chip
More about this : https://bananapi.gitbooks.io/bpi-m3/content/en/lakkatv.html
| Simplenas image : https://simplenas.com/download/other/banana-pi-m1 |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M1-Plus/1100417230_40000003434385.html |
| Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-M1-Plus/1101951077_40000003414810.html |
| OEM&ODM, please contact: [email protected] |
