The Banana Pi M1+ features onboard WiFi g/b/n. The board supports all classic projects and even more because of the onboard WIFi chip. Like its sibling, it can run operating systems including Android, Lubuntu, Ubuntu, Debian, and Raspbian.
The Banana Pi M1+ is our upgraded M1 board. We feel like the onboard WiFi adds a lot more features to the board and makes it more convient for users to set up their linx desktop or router projects.
| More Infomation: Banana Pi BPI-M1_Plus |
Dual-core 1.0GHz CPU
1 GB DDR3 memeory
Mali-400 MP2 with Open GL ES 2.0/1.1
WiFi onbaord
| The Android images of BPI-M1 and BPI-M1 Plus are universal. |
Download the M1 Plus image.
Put your TF card into a TF-USB adapter, and then plug adapter in your Windows PC usb interface.
Prepare your image, and download image burning tools PhoenixCard.exe.
Use "PhoenixCard.exe" to burn android image to TF card.
Select the image in the image path option
Select set as card startup, then click on burn image
Burning ended.
Prepare 8G/above TF card, USB-Serial interface, PC with windows System
Using your USB-Serial Connect debug console on M1 Plus
Windows
Install Image with Balena Etcher.
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
Mount SATA on M1P
After insert sata interface, execute
fdisk -l
Then
mount /dev/sdx /mnt/xxx
If you meet some errors when you mount SATA, try these following commands:
Create new partition
fdisk /dev/sdx
set your partition numbers and size, after created partitions, input "wq" to save and quit.
Format the SATA
mkfs.ext2 /dev/sdx
Execute
After you success to insert SATA, we could input following commands to test SATA interface:
Test read speed
time dd if=/dev/xxx of=/dev/null bs=1M count=1000
Test write speed
time dd if=/dev/zero of=/dev/sdx bs=1M count=1000
Use iperf3 to test gmac
On PC Terminal:
Execute
iperf3 -s
On M1P console:
TCP test
iperf3 -c serverIP
UDP test:
iperf3 -u -c serverIP
Use commands to setup WiFi client
ip link set wlan0 up
iw dev wlan0 scan | grep SSID
nano /etc/wpasupplicant/wpa_supplicant.conf
network={
ssid="ssid"
psk="password"
priority=1
wpa_supplicant -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
dhclient wlan0
Use UI interface to setup WiFi Client
git clone https://github.com/BPI-SINOVOIP/BPI-files/tree/master/SD/100MB
bpi-bootsel BPI-cleanboot-8k.img.gz /dev/sdX
git clone https://github.com/BPI-SINOVOIP/RPi.GPIO
cd RPi.GPIO
sudo apt-get update
sudo apt-get install python-dev python3-dev
Install module, execute
sudo python setup.py install
or
sudo python3 setup.py install
cd /usr/local/bin
./bpi_test_g40.py
We also have built-in test command in
/usr/local/bin
/usr/local/bin/bpi_test_lcd1602.sh
Firstly you need a GPIO Extend Board for 8x8 LED Martix
Execute
/usr/local/bin/bpi_test_gpio40.sh
sudo apt-get install build-essential
sudo apt-get install libgl1-mesa-dev
sudo apt-get install libglu1-mesa-dev
sudo apt-get install freeglut3-dev
sudo apt-get install cmake
sudo apt-get install qt5-default qtcreator
In order to port can4linux to the BananaPi, the CAN module description is needed from the A20 hardware manual. can4linux is a character-driver-based Linux driver used already on desktop PCs and embedded platforms like Freescale FlexCAN (the i.MX series of micro controllers) or Xiliny Zynq.
There is a more detailed document about CAN on the A20 at: https://dl.linux-sunxi.org/A20/CAN%20Bus1.pdf
This is a tutorial for using CAN BUS on bananapi with bananian 15-01
Thank selqcir share this example:
Download and install "bananian-1501.img" into 8 GB SDCard.
Expand the root file system using "bananian-config"
Install missing package:
apt-get install git
apt-get update
apt-get upgrade
reboot
Get last bananian available, and continu to install missing package:
git clone https://github.com/Bananian/linux-bananapi
apt-get install build-essential u-boot-tools uboot-mkimage
apt-get install libusb-1.0-0 libusb-1.0-0-dev git wget fakeroot kernel-package zlib1g-dev libncurses5-dev
apt-get install subversion
Build kernel:
cd linux-bananapi
make menuconfig
Exit without saving when menu appears
zcat /proc/config.gz > /root/linux-bananapi/.config
make uImage modules
make INSTALL_MOD_PATH=output modules_install
At this step, kernel should be compiled and "Module.symvers" should be available
Then rename modules and firmware provide by Bananian, and replace by the new one.
mv /lib/modules /lib/modules.old
mv /lib/firmware /lib/firmware.old
mv /root/linux-bananapi/output/lib/modules /lib/modules
mv /root/linux-bananapi/output/lib/firmware /lib/firmware
Same for uImage:
mount /dev/mmcblk0p1 /mnt
cd /mnt
mv uImage uImage.old
mv /root/linux-bananapi/arch/arm/boot/uImage /mnt
reboot
Create link for further build:
cd /lib/modules/3.4.104/
ln -s /root/linux-bananapi build
cd ~
Get Can4Linux and build it:
svn checkout https://svn.code.sf.net/p/can4linux/code/trunk can4linux-code
cd /root/can4linux-code/can4linux/
make TARGET=BANANAPI
Install module for each startup of the board:
insmod can4linux.ko
cp can4linux.ko /lib/modules/3.4.104/kernel/net/can/
depmod -A -v
modprobe -v can4linux
echo "" >> /etc/modules ; echo "can4linux" >> /etc/modules
reboot
Build CAN example
apt-get install swig
cd can4linux-code/can4linux-examples/
Update CAN speed and device in file "pyCan-example.py"
# setting the device number
device = 0
defaultBaudrate = '250'
Connect CAN transceiver and CAN bus, and check with for example:
python pyCan-example.py
That’s all
With this method, kernel version is "Linux bananapi 3.4.104" instead of "Linux bananapi 3.4.104+", because i was unable to find same sources than Bananian 15-01 , but CAN bus work!
