Allwinner A20 design: Banana Pi BPI-M1 SBC Allwinner A20 design: Banana Pi BPI-M1+ SBC Allwinner A20 design: Banana Pi BPI-R1 Router Allwinner R64 design: Banana Pi BPI-M64 SBC Allwinner A83T design: Banana Pi BPI-M3 SBC |
Allwinner A20 Dual-core 1.0GHz CPU
Mali-400 MP2 with Open GL ES 2.0/1.1.
1 GB DDR3 memory.
1x SATA interface.
4x Gigabit LAN 1x Gigabit WAN
| HardWare Specification of Banana Pi R1 | |
CPU |
A20 ARM Cortex -A7 Dual-Core |
GPU |
ARM Mali400MP2Complies with OpenGL ES 2.0/1.1 |
Memory |
1GB DDR3 |
Network |
10/100/1000 Ethernet 8P8C, Wi-Fi |
Video Input |
A CSI input connector allows for the connection of a designed camera module |
Video Outputs |
HDMI, CVBS, LVDS/RGB |
Audio Outputs |
3.5mm jack and HDMI |
Power Source |
5 volt via Micro USB (DC in only) and / or Micro USB OTG |
USB 2.0 ports |
2(direct from Allwinner A20 chip) |
GPIO |
GPIO, UART, I2C BUS, SPI BUS, WITH TWO CHIP SELECTS, CAN bus, ADC, PWM, +3.3V, +5V, GND |
LED |
Power Key & 8P8C |
Storage |
SATA 2.0 |
OS |
Android 4.4, Android 4.2, Raspbian, Lubuntu, Open Suse, Debian |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| BPI-R1 schematic diagram : https://drive.google.com/file/d/0B4PAo2nW2KfnNTBaVENGeHZfSzA/view?usp=sharing |
| Banana Pi BPI-R1 Gerber file : https://drive.google.com/file/d/1tFD8FuCtbD0dyUcc98lQOz3SGcRsF01d/view?usp=sharing |
| BPI-R1 3D & DXF file : https://drive.google.com/file/d/0B4PAo2nW2KfnOVhFMFp6MFFfa00/view?usp=sharing |
| BPI-R1 CE,FCC RoHS Certification : |
| linux-sunxi wiki: http://linux-sunxi.org/Lamobo_R1 |
| NetBSD/evbarm on Allwinner Technology SoCs : https://wiki.netbsd.org/ports/evbarm/allwinner/#index1h1 |
| Manual for HW setup and basic router functionalities: https://docs.google.com/document/d/1LVuukSuby7aCuAaQezFn-kM8ZQM-I0kuGiI_XnT0sDg/edit?usp=sharing |
| David Bentham / openwrt-bpi-r1-prebuilt |
Stable 1.2.1 release:
Kernel upgraded to 4.1.17
Added Parted package
Lots of package upgrades and bug fixes…
VM build system - OpenwrtBuild-BPI-R1-VM-V1.0.torrent if you wish to spin up your own version from scratch!
Github link: https://github.com/db260179/openwrt-bpi-r1
| Allwinner chip documents: http://dl.linux-sunxi.org/ |
The final solution of compulsive modification of HDMI output resolution.
As you may have discovered the common configuration method in raspberry pi (such as alteration of /boot/config.txt) does not work on BPI, neither does the modification of cmdline.txt and uEnv.txt especially for some display with converter(HDMI→VGA or HDMI →IDVI) or some old display devices.
install compile sunxi-tools depended-upon packages
get sunxi-tools new code from github:
compile sunxi-tools
cd sunxi-tools
make
backup script.bin
copy script.bin to current dir
use bin2fex change bin to fex
edit script.fex file:
nano script.fex
see this below:
[disp_init]
disp_init_enable = 1
disp_mode = 0
screen0_output_type = 3
screen0_output_mode = 5
screen1_output_type = 2
screen1_output_mode = 11
fb0_framebuffer_num = 2
fb0_format = 10
fb0_pixel_sequence = 0
fb0_scaler_mode_enable = 1
fb1_framebuffer_num = 2
fb1_format = 10
fb1_pixel_sequence = 0
fb1_scaler_mode_enable = 0
lcd0_backlight = 197
lcd1_backlight = 197
lcd0_bright = 50
lcd0_contrast = 50
lcd0_saturation = 57
lcd0_hue = 50
lcd1_bright = 50
lcd1_contrast = 50
lcd1_saturation = 57
lcd1_hue = 50
0 480i
1 576i
2 480p
3 576p
4 720p 50Hz
5 720p 60Hz
6 1080i 50 Hz
7 1080i 60 Hz
8 1080p 24 Hz
9 1080p 50 Hz
10 1080p 60 Hz
11 PAL
12 PAL SVIDEO
14 NTSC
15 NTSC SVIDEO
17 PAL_M
18 PAL_M SVIDEO
20 PAL_NC
21 PAL_NC SVIDEO
23 1080p 24 Hz 3D
24 720p 50 Hz 3D
25 720p 60 Hz 3D
26 1360x768 60 Hz
27 1280x1024 60 Hz
use fex2bin change fex to bin
copy script.bin to /boot
reboot and make a try
sudo reboot
bootargs=enforcing=1 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootwait init=/init vmalloc=384M ion_
ma_list="120m,176m,512m" loglevel=8 bootmenutimeout=10 datadev=mmcblk0p2 disp.screen0_output_type=3 disp.screen0_o
utput_mode=10 disp.screen1_output_type=3 disp.screen1_output_mode=10
We test it with deepin2014(base on ubuntu14.04)
install depend package :
apt-get install subversion build-essential libncurses5-dev zlib1g-dev gawk
git ccache gettext libssl-dev xsltproc unzip subversion file
get openwrt source code
enter openwrt dir:
cd BPI-OpenWRT
update package and install
./scripts/feeds update -a
./scripts/feeds install -a
Enter the customization interface:
please choose your need:
example : i need web and add chinese support
LuCI—> 1. Collections ---> <*> luci add Luci support ,it mean web GUI support,it is defaultes
LuCI—>2. Modules ---> <*> luci-i18n-chinese add chinese also you can choose others.
Make ,you can add V=s to see more message ,also add -j4 to use quad core to work .
make
use USB Image Tool(http://www.alexpage.de/) burn image to sd,insert BPI and booting it.
running :
| 2018-07-28 update android 4.4 HDMI version image |
Features Map: http://newwiki.banana-pi.org/en/BPI-R1/R1_Image_Map
Baidu Drive: https://pan.baidu.com/s/1dorsPZAqCbL1oC6J4zQyvQ
Forum pthtread :http://forum.banana-pi.org/t/bananapi-m1-m1p-r1-new-image-release-20180728/6357
| Banana pi PBI-R1 android 4.4 image : https://drive.google.com/file/d/0BxpbZWFFuHmyUHRYeE9uenFTVmc/view |
| 2022-04-16 Banana Pi new image: Ubuntu 16.04 with Allwinner BSP, use MPV play 1080P video,Allwinner BSP kernel 3.4 , BPI-M2 Ultra/Berry use kernel 3.10 |
Discuss on forum: https://forum.banana-pi.org/t/banana-pi-new-image-ubuntu-16-04-with-allwinner-bsp-use-mpv-play-1080p-video/13272
| 2018-07-28 ubuntu-server-16.04 |
Baidu drive : https://pan.baidu.com/s/1dorsPZAqCbL1oC6J4zQyvQ
Forum thread: http://forum.banana-pi.org/t/bananapi-m1-m1p-r1-new-image-android-and-ubuntu-sever-release-2018-07-28/6357
| 2016-07-21 update ubuntu-mate-16.04-desktop support BPI-M2,BPI-M1+,BPI-R1 |
MD5: 155f072da499a7c523b7394f77dd9def
| 2016-07-19 update, need use >=16G SD card |
MD5: 37d6599eac4daced375fba8fa58dc1d5
Forum thread: http://forum.banana-pi.org/t/bpi-r1-new-image-edu-ubuntu-mate-1604-preview-bpi-m1-m1p-r1-img-2016-07-19/2043
| 2016-07-10 update Ubuntu-16.04-xenial-minimal support BPI-M2,BPI-M1+,BPI-R1 |
MD5: b900b9ba3b0f664a2cfae1fa1146b2fa
Forum thread: http://forum.banana-pi.org/t/bpi-r1-new-image-ubuntu-16-04-xenial-minimal-preview-bpi-m1-m1p-r1-img-2016-07-10/1991
| 2016-06-04 update Ubuntu-16.04-xenial support BPI-M2,BPI-M1+,BPI-R1 |
Baidu cloud: http://pan.baidu.com/s/1jHDZCsY
| Update 2022-04-04, Banana Pi BPI-R1 (lamobo-r1) new Images,Ubuntu Jammy ,Ubuntu Impish, Ubuntu Focal |
| 2019-9-18 update. Debian 10 buster mate desktop with grub support (boot-2019.07 + kernel 5.1.1) |
Forum pthread: http://forum.banana-pi.org/t/bpi-m1-m1-r1-new-image-debian-10-buster-mate-desktop-with-grub-support-boot-2019-07-kernel-5-1-1/9916
| 2016-08-04-Armbian_5.17_Lamobo-r1_Debian_jessie_4.6.5_desktop-build-by-bpi-r1.img.zip |
Google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjV3I5RlpwdmZHYWs/view?usp=sharing
MD5: f6952fc265ba26c953eb929d23d1ac95
Forum thread: http://forum.banana-pi.org/t/bpi-r1-new-image-armbian-5-17-bpi-r1-debian-jessie-4-6-5-desktop-build-by-bpi-r1-img/2095
| 2015-07-21 update Debian8_docker uboot : 2015-7 linux kernel: 4.2.4 |
Google drive download : https://drive.google.com/file/d/0B3EGHv0FSPOGSXVIaUVaRDBldE0/view
Baidu cloud : http://pan.baidu.com/s/1kTnKNrx
MD5: 0e3349ea78e790382461a538264b569d
Openwrt support for allwinner : https://wiki.openwrt.org/doc/hardware/soc/soc.allwinner.sunxi?s=banana&s[]=pi
Baidu cloud: http://pan.baidu.com/s/1mg8Gjna
MD5: CB597EE79A6E27630AD7F903D23C4A7B
| 2016-07-13 update raspbian jessie |
Google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjdTh5ZnVZam1rb0E/view?usp=sharing
MD5: 156b09907586ea9e86481bda73f4254f
Forum thread: http://forum.banana-pi.org/t/bpi-r1-new-image-raspbian-jessie-bpi-m1-m1p-r1-img-2016-07-13/2011
| 2016-07-12 update raspbian lite |
Google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjRXRuWHJ5V3BJTmc/view?usp=sharing
MD5: 302063f7417079390da79334258dd538
| Update 2022-04-04, Banana Pi BPI-R1 (lamobo-r1) new Images,Armbian Sid,Armbian Bullseye, Armbian Buster |
| Armbian Xenial and Armbian Jessie |
Image lownload link : https://www.armbian.com/lamobo-r1/
| Banana pi BPI-R1 mainline linux kernel for fedora |
| 2016-07-12 update KANO OS Beta 3.3.0 (support rpi3 rpi2 rpi1) |
Google drive download : https://drive.google.com/file/d/0B_YnvHgh2rwjaXQtVGUtbFplTUU/view?usp=sharing
MD5: 1951f3abc0a54675d9bbbac387760e4e
| Archlinux 28-12-2017 4.6.5 sunxi mainline kernel |
Kernel borrowed from armbian: BPI-R1 new image: Armbian_5.17_bpi-r1_Debian_jessie_4.6.5_desktop-build-by-bpi-r1.img
Archlinux upgraded from official bpi image.
The kernel issues related to kernel / userspace mismatch seem to be gone (such as systemd-sysctl input / output error etc).
Image download link: http://mkaczanowski.com/files/archlinux-bpi-r1-2017-28-2017-4.6.5-sunxi-mainline.img
| Banana pi as the official partner of Allwinner , must banana pi product use Allwinner chip design . such as A20/A31S/H3/H2+/A64/A83T , and FreeBSD have support many Allwinner . so easy to use on banana pi board. |
Allwinner A20 (sun7i), a dual-core Cortex-A7 : BPI-M1/BPI-M1+/BPI-R1
Allwinner A31 and A31s (sun6i), a quad-core Cortex-A7 : BPI-M2
Allwinner A64 sun50i), a quad-core Cortex-A53 :BPI-M64
Allwinner A83T (sun8i), an octa-core Cortex-A7 : BPI-M3
Allwinner H3 (sun8i), a quad-core Cortex-A7 : BPI-M2+/BPI-M2+ EDU/
| You can fine others image at forum : http://forum.banana-pi.org/c/bpi-r1 |
| OEM&ODM, please contact: [email protected] |
