| More Infomation: Banana Pi BPI-R1 |
Dual-core 1.0GHz CPU
1 GB DDR3 memory
Mali-400 MP2 with Open GL ES 2.0/1.1
4x Gigabit LAN 1x Gigabit WAN
Prepare 16G/above TF card, USB-Serial interface, Ubuntu System
Using your USB-Serial Connect debug console on R1
You could download latest image from our forum
Install bpi-tools on your Ubuntu. If you can’t access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
apt-get install pv
curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
After you download the image, insert your TF card into your Ubuntu,Execute
bpi-copy xxx.img /dev/sdx
After step 3, then you can insert your TF card into R1, and press power button setup R1
