The BPI-M2C is a high-performance ARM single-board computer (SBC) from Banana Pi, powered by the UNISOC UIS7885 SoC. It is designed for applications such as 5G communications, edge computing, artificial intelligence, machine vision, smart terminals, and embedded human-machine interfaces (HMI).
Built on a 6nm process, the UIS7885 features an octa-core architecture—comprising four high-performance Arm Cortex-A76 cores and four energy-efficient Arm Cortex-A55 cores—with a shared 3MB L3 cache. It supports Arm Neon SIMD/VFP instructions and integrates a Mali-G57 GPU, an IMG AX3596 NPU, a VDSP, an ISP, and hardware-based video encoding/decoding units. The BPI-M2C comes equipped with 4 GiB of LPDDR4X RAM and 128 GB of eMMC storage. Its interface suite includes support for MicroSD, PCIe Gigabit Ethernet, Wi-Fi, Bluetooth, GNSS, HDMI, MIPI-DSI, MIPI-CSI, USB, and a 40-pin expansion header.
Compared to typical entry-level development boards, the BPI-M2C places a greater emphasis on high-performance computing, 5G platform capabilities, on-device AI, camera ISP, and multimedia processing. It is well-suited for development projects that require an integrated solution for computing, connectivity, display, and vision-based tasks.
1 × Arm Cortex-A76 (up to 2.7 GHz) + 3 × Arm Cortex-A76 (up to 2.3 GHz) + 4 × Arm Cortex-A55 (up to 2.1 GHz)
Arm Mali-G57 GPU (up to 850 MHz)
IMG AX3596 NPU (up to 988 MHz)
VDSP (Vision/Signal Processing Unit) (up to 1014 MHz)
4 GiB LPDDR4X RAM
128 GB eMMC, with support for MicroSD
Gigabit Ethernet
Wi-Fi 5 (dual-band: 2.4 GHz, 5 GHz) / Bluetooth 5
Software/driver support for GNSS and FM
Integrated 2G/3G/4G/5G modem within the SoC
HDMI output
MIPI-DSI
MIPI-CSI
5G edge computing gateways
Machine vision and AI-enabled cameras
Smart retail, self-service terminals, and digital signage
Facial recognition and smart access control
Industrial HMI and all-in-one touch terminals
Video conferencing, remote monitoring, and video transmission
Robot main control and vision processing
GNSS-based mobile data collection terminals
Educational platforms for ARM/Linux, AI, and telecommunications (for universities/colleges)
| HardWare Specification of Banana Pi M2C | |
SoC |
Unisoc T820 (UIS7885), 6 nm |
CPU |
1 × Cortex-A76 @ 2.7 GHz + 3 × Cortex-A76 @ 2.3 GHz + 4 × Cortex-A55 @ 2.1 GHz, 64-bit |
GPU |
Arm Mali-G57, up to 850 MHz |
NPU |
IMG AX3596, up to 988 MHz |
VDSP |
VQ7, up to 1014 MHz |
Memory |
4 GiB LPDDR4X |
Storage |
128 GB eMMC; supports MicroSD; SoC supports eMMC 5.1 HS400/UFS 3.1 |
Wired Network |
1 × Gigabit Ethernet; supports PoE (Power over Ethernet) via an external PoE module |
Wireless |
Wi-Fi 5, dual-band (2.4 GHz, 5 GHz) |
Bluetooth |
Bluetooth 5 |
Cellular Network |
SoC supports 2G/3G/4G/5G |
Positioning |
GNSS (supported via drivers and software) |
HDMI |
HDMI output, 1920 × 1080 |
MIPI DSI |
800 × 1280 |
Camera |
MIPI-CSI, hardware ISP |
USB |
4 × USB 2.0 |
Audio |
3.5mm headphone jack, speaker |
GPIO |
40-pin header; supports GPIO, I²C, SPI, UART, PWM, and PCM/I²S |
Buttons |
Power button, flash (bootloader) button |
Power Supply |
Supports 5V power input via Type-C |
Dimensions |
85 × 56 mm |
Weight |
60g |
| Linux BSP source code |
| SINOVOIP Aliexpress Shop: |
| Bipai Aliexpress Shop: |
| Taobao Shop: |
| OEM&ODM, please contact: [email protected] |
