| BPI-M2 Magic not HDMI interface. Not support RJ45 interface |
Allwinner R16 chip and A33 chip is PIN to PIN compatibility, so BPI-M2 Magic just replace R16 ,A33 chip onboard, easy to DIY new product.
Allwinner R16/A33 Quad Core ARM Cortex A7 CPU.
512MB DDR3 SDRAM.
WiFi (AP6212) & Bluetooth onboard.
8G eMMC flash
CSI camera interface
DSI display interface
| HardWare Specification of Banana Pi M2 Magic | |
CPU |
Allwinner R16 ARM Cortex-A7 Quad-Core |
GPU |
PowerVR SGX544MP1 Comply with OpenGL ES 2.0 OpenCL 1x, DX9_3 |
Memory |
512MB LPDDR3 (shared with GPU) |
Storage |
On Board 8GB eMMC Flash, Micro SD-Card slot |
Network |
Wi-Fi 802.11 b/g/n (AP6212) + Bluetooth BT4.0 |
Video Input(s) |
A CSI input connector allows for the connection of a designed camera module |
Video Output(s) |
MIPI Display Serial Interface (DSI) for raw LCD Panel |
Audio Input(s) |
On board microphone |
Audio Output(s) |
3.5mm jack |
USB ports |
USB 2.0 PORT (x1), USB OTG (x1) |
Remote |
Not IR Receiver |
GPIO |
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). Some of I/O Pin can be used for specific functions as UART, I2C, SPI or PWM |
Switches |
Reset, Power and U-boot |
LED |
Power Status and 8P8C |
Power Source |
5 volt @2A via DC Power and/or Micro USB (OTG) |
Size & Weight |
51x51mm, 48g |
OS |
Android and Linux |
| 40 PIN GPIO of Banana pi BPI-M2 Magic | ||
GPIO Pin Name |
Default Function |
Function2:GPIO |
CON1-P01 |
VCC-3V3 |
CON1-P02 |
DCIN |
CON1-P03 |
TWI1-SDA |
PH5 |
CON1-P04 |
DCIN |
CON1-P05 |
TWI1-SCK |
PH4 |
CON1-P06 |
GND |
CON1-P07 |
PWM1 |
PH1 |
CON1-P08 |
UART2-TX |
PB0 |
CON1-P09 |
GND |
CON1-P10 |
UART2-RX |
PB1 |
CON1-P11 |
UART3_TX |
PH6 |
CON1-P12 |
AP-PCM-CLK-CTS |
PG11 |
CON1-P13 |
UART3_RX |
PH7 |
CON1-P14 |
GND |
CON1-P15 |
LVDS_V1N |
PD21 |
CON1-P16 |
UART2-RTS |
PB2 |
CON1-P17 |
VCC-3V3 |
CON1-P18 |
UART2-CTS |
PB3 |
CON1-P19 |
SPI0_MOSI |
PC0 |
CON1-P20 |
GND |
CON1-P21 |
SPI0_MISO |
PC1 |
CON1-P22 |
LVDS_V1P |
PD20 |
CON1-P23 |
SPI0_CLK |
PC2 |
CON1-P24 |
SPI0_CS |
PC3 |
CON1-P25 |
GND |
CON1-P26 |
LVDS_VCN |
PD25 |
CON1-P27 |
LVDS_V0N |
PD19 |
CON1-P28 |
LVDS_VCP |
PD24 |
CON1-P29 |
LVDS_V0P |
PD18 |
CON1-P30 |
GND |
CON1-P31 |
LVDS_V2N |
PD23 |
CON1-P32 |
LVDS_V2P |
PD22 |
CON1-P33 |
LVDS_V3N |
PD27 |
CON1-P34 |
GND |
CON1-P35 |
AP-PCM-SYNC |
PG10 |
CON1-P36 |
LVDS_V3P |
PD26 |
CON1-P37 |
PL11-EINT11 |
PL11-EINT11 |
CON1-P38 |
AP_PCM_DIN |
PG13 |
CON1-P39 |
GND |
CON1-P40 |
AP-PCM-DOUT |
PG12 |
| CSI Camera pin define of Banana pi BPI-M2 Magic | ||
CSI GPIO Pin |
Pin Name |
GPIO |
CN3-P01 |
NC |
CN3-P02 |
GND |
CN3-P03 |
CSI0-SDA |
PE13 |
CN3-P04 |
CSI0-AVDD |
CN3-P05 |
CSI0-SCK |
PE12 |
CN3-P06 |
CSI0-Reset |
PE14 |
CN3-P07 |
CSI0-VSYNC |
PE3 |
CN3-P08 |
CSI0-PWDN |
PE15 |
CN3-P09 |
CSI0-HSYNC |
PE2 |
CN3-P10 |
CSI0-DVDD |
CN3-P11 |
CN3-P12 |
CSI0-D7 |
PE11 |
CN3-P13 |
CSI0-MCLK |
PE1 |
CN3-P14 |
CSI0-D6 |
PE10 |
CN3-P15 |
GND |
CN3-P16 |
CSI0-D5 |
PE9 |
CN3-P17 |
CSI0-PCLK |
PE0 |
CN3-P18 |
CSI0-D4 |
PE8 |
CN3-P19 |
CSI0-D0 |
PE4 |
CN3-P20 |
CSI0-D3 |
PE7 |
CN3-P21 |
CSI0-D1 |
PE5 |
CN3-P22 |
CSI0-D2 |
PE6 |
CN3-P23 |
GND |
CN3-P24 |
CSI0-AFVCC |
| MIPI DSI PIN define of Banana pi BPI-M2 Magic | ||
DSI GPIO Pin |
Pin Name |
GPIO |
CN2-P01 |
DSI-D0N |
CN2-P02 |
DSI-D0P |
CN2-P03 |
DSI-D1N |
CN2-P04 |
DSI-D1P |
CN2-P05 |
DSI-CKN |
CN2-P06 |
DSI-CKP |
CN2-P07 |
DSI-D2N |
CN2-P08 |
DSI-D2P |
CN2-P09 |
DSI-D3N |
CN2-P10 |
DSI-D3P |
CN2-P11 |
NC |
CN2-P12 |
NC |
CN2-P13 |
TP-SDA |
PH3 |
CN2-P14 |
TP-SCK |
PH2 |
CN2-P15 |
TP-INT |
PB5 |
CN2-P16 |
TP-RST |
PB6 |
CN2-P17 |
LCD-BL-EN |
PL4 |
CN2-P18 |
LCD-RST |
PL5 |
CN2-P19 |
LCD-PWR-EN |
PB7 |
CN2-P20 |
LCD-PWM |
PH0 |
CN2-P21 |
GND |
CN2-P22 |
GND |
CN2-P23 |
PS |
CN2-P24 |
PS |
CON3-P1 |
GND |
CON3-P2 |
UART0-RX |
CON3-P3 |
UART0-TX |
| BPI-M2 Magic Gerber/Boom/Assembly document: |
Baidu cloud: https://pan.baidu.com/s/1cpuZXDWfuW6twX_IYBRWaw?pwd=8888 (pincode: 8888)
| BPI-M2 Magic SCH : google driver |
| BPI-M2 Magic DXF file public : https://drive.google.com/file/d/0B4PAo2nW2KfnalhDRG5EclU1dHM/view?usp=sharing |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| Allwinner R16 chip Datasheet-V1.4 (1): https://drive.google.com/file/d/0B4PAo2nW2KfnVW9FSUpPX2FLcU0/view?usp=sharing |
| Allwinner_R16_User_Manual_V1.2: https://drive.google.com/file/d/0B4PAo2nW2KfnUjZUNVdyN1RkVlE/view?usp=sharing |
| AXP223 Datasheet V1.0_en : https://drive.google.com/file/d/0B4PAo2nW2KfnckxWZFBBMUNWSUk/view?usp=sharing |
| 2019-08-06 update ,BPI-M2 Magic Android 6 new image release ,This release is for banana pi M2m board with BPI 7" panel, and it is based on Android 6.0 Operation system with kernel 3.4. |
Baidu Drive : https://pan.baidu.com/s/1xO9jZQsNXoTAmdpDFBiwYg PIN code: alyr
MD5 : 90e2f11480b54ba6fa5b630770913a85
| BPI-M2M_Anodroid _V1 |
Baidu Drive: https://pan.baidu.com/s/1qY8zAmo
| 2021-03-24 release, Ubuntu Mate Desktop 16.04 with kernel 3.4.39 |
MD5: 393407f3433acf69eabc19e8730f63f0
| 2021-03-24 release, Ubuntu Server 16.04 with kernel 3.4.39 |
MD5: 80f6bef4628eef0da8c5800819cc1cfd
| 2019-05-11 update This release is for banana pi M2 Magic board which is based on R16, and it is based on Ubuntu 16.04 Operation system with kernel 3.4. |
BPI-M2M Ubuntu Server 16.04 Features Map : http://docs.banana-pi.org/en/BPI-M2_Magic/M2M_Image_Map
LCD7 SD & Emmc version images:
Baidu Drive : https://pan.baidu.com/s/1QIXnZHg7MS9pR7pRXvZu1w PIN code: n20l
MD5 : 9dcd344f0a6433bc649301930599d45b
CD7 Emmc version image:
| Notes : Because sd pins and uart0 pins are the same, so we have to use uart2 as debug console before, and I release this image is just in order to release uart2 to use and set uart0 as debug console. |
How to burn image:you just need to use m2m boot from a sd image, then use sd image to install this emmc image on emmc.
Baidu Drive : https://pan.baidu.com/s/1xE5tpw0DqNAV2mqKg_TbpQ PIN code: awpy
MD5 : 9f576cfaeb0329648b14b541ff2f5dd4
Forum pthread: http://forum.banana-pi.org/t/bpi-m2m-r16-new-image-release-ubuntu-server-16-04-2019-05-09/9205
| Unbutu 16.04 2018-08-25 Image Link: This release is for banana pi M2 Magic board which is based on R16, and it is based on Ubuntu 16.04 Operation system with kernel 3.4. |
BPI-M2M Ubuntu 16.04 Features Map: http://docs.banana-pi.org/en/BPI-M2_Magic/M2M_Image_Map
LCD 7’-Version Google Drive : https://drive.google.com/open?id=14LH4NGAyfeCXhnKlzc75-K6p2gmO5RrM
LCD 7’-Version Baidu Drive : https://pan.baidu.com/s/17jiGC4fCSTfVKPWUgh-VXA
Forum pthread: http://forum.banana-pi.org/t/bpi-m2m-r16-new-image-release-ubuntu-16-04-2018-08-25/6596
| Unbutu 16.04 2018-01-04 Image Link |
Baidu Drive: https://pan.baidu.com/s/1kVKjxOF
MD5: df72548c26cd42b8138f334f5b383f31
| Unbutu 16.04 2017-10-23 Image Link |
Baidu Drive: http://pan.baidu.com/s/1hsGhxWS
MD5: 23cd3f0891d8ad274984eea3f4981eab
| 2017-11-15 update : tina astar m2magic |
More about Tina Linux link: https://docs.banana-pi.org/en/Tina_Linux
Google downlad : https://drive.google.com/open?id=13iVMJJVY6i8GJjMjoAyk62IDW83MagDX
| OEM&ODM, please contact: [email protected] |
| BIPAI Aliexpress shop: https://es.aliexpress.com/item/1005008034851506.html |
| SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/32836172813.html |
