Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit
Mali 470 MP4 GPU OpenGL ES 1.1/2.0 H.264 H.265,2K4K
Onboard1 GB DDR4 (option 2 GB)
8G eMMC flash (max 64 GB)
10/100 Mbit/s Ethernet and RTL8821 module support Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2
USB 2.0 TYPE C
M.2 Key E slot PCIE 2.0 and USB 2.0
PoE function support
| HardWare Specification of Banana Pi M4 | |
CPU |
Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit |
GPU |
Mali 470 MP4 GPU OpenGL ES 1.1/2.0 |
Memory |
1 GB DDR4 (option 2 GB) |
Storage |
MicroSD slot with support for up to 256GB expansion and 8G eMMC flash with support for up to 64GB |
Network |
10/100 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2 |
Video Output(s) |
HDMI port and multi-channel audio output support 1080P H.264 H.265 2K/4K |
Audio Output(s) |
3.5mm jack and HDMI |
PCIE |
M.2 Key E slot PCIE 2.0 and USB 2.0 |
USB ports |
USB 2.0 PORT (x4), USB 2.0 TYPE C(x1) |
GPIO |
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM |
Switches |
Reset, Power and U-boot |
LED |
Power Status and Activity status |
Power Source |
5 volt @2A via Micro USB (TYPE C) or PoE support |
Size & Weight |
92x60mm, 48g |
OS |
Android and Linux |
40 PIN GPIO of Banana pi BPI-M4 |
GPIO Pin Name |
Default Function |
Function2:GPIO |
CON1-P01 |
VCC-3V3 |
CON1-P02 |
DCIN |
CON1-P03 |
I2C1_SDA |
GPIO-17 |
CON1-P04 |
DCIN |
CON1-P05 |
I2C1_SCL |
GPIO-16 |
CON1-P06 |
GND |
CON1-P07 |
PWM1 |
GPIO-21 |
CON1-P08 |
UR1_TX |
GPIO-9 |
CON1-P09 |
GND |
CON1-P10 |
UR1_RX |
GPIO-8 |
CON1-P11 |
SDIO-D0 |
GPIO-42 |
CON1-P12 |
AIO_BCK |
GPIO-3 |
CON1-P13 |
SDIO-D1 |
GPIO-43 |
CON1-P14 |
GND |
CON1-P15 |
SDIO-D2 |
GPIO-44 |
CON1-P16 |
UR1_RTS |
GPIO-11 |
CON1-P17 |
VCC-3V3 |
CON1-P18 |
UR1_CTS |
GPIO-10 |
CON1-P19 |
GSPI-MOSI |
GPIO-31 |
CON1-P20 |
GND |
CON1-P21 |
GSPI-MISO |
GPIO-18 |
CON1-P22 |
GPIO-47 |
GPIO-47 |
CON1-P23 |
GSPI-SCK |
GPIO-19 |
CON1-P24 |
GSPI-CS |
GPIO-20 |
CON1-P25 |
GND |
CON1-P26 |
PWM2 |
GPIO-22 |
CON1-P27 |
SDIO-D3 |
GPIO-45 |
CON1-P28 |
PWM3 |
GPIO-23 |
CON1-P29 |
SDIO-CLK |
GPIO-41 |
CON1-P30 |
GND |
CON1-P31 |
SDIO-CMD |
GPIO-40 |
CON1-P32 |
SPDIF |
GPIO-50 |
CON1-P33 |
AIO_CK |
GPIO-4 |
CON1-P34 |
GND |
CON1-P35 |
AIO_LRCK |
GPIO-2 |
CON1-P36 |
GPIO-53 |
GPIO-53 |
CON1-P37 |
GPIO-34 |
GPIO-34 |
CON1-P38 |
AI_SD |
GPIO-5 |
CON1-P39 |
GND |
CON1-P40 |
AO_SD |
GPIO-6 |
CON2-P1 |
GND |
CON2-P2 |
UART0-RX |
CON2-P3 |
UART0-TX |
Banana Pi BPI-M4: How to get I2C and SPI running (tutorial): https://forum.banana-pi.org/t/banana-pi-bpi-m4-how-to-get-i2c-and-spi-running-tutorial/12824/6
| Supports Banana Pi BPI-M4 (RTD1395) (Kernel 4.9.119) |
Source code on github: https://github.com/BPI-SINOVOIP/BPI-M4-bsp
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| BPI-M4 schematic diagram: |
Baidu cloud: https://pan.baidu.com/s/1mnn51dwBV5uxpNheBD4vJA PIN code: t6cd
| BPI-M4 ASSY file |
| Banana Pi BPI-M4 CE,FCC,RoHS Certification: http://forum.banana-pi.org/t/banana-pi-bpi-m4-ce-fcc-rohs-certification/9520 |
| Realtek RTD1395 chip datasheet : https://drive.google.com/file/d/1Jt8qUwEjLinMqURMftC3db0Xg9MIWIhu/view?usp=sharing |
| BPI-M4 DXF file download |
Baidu cloud : https://pan.baidu.com/s/1bSZFMJ2lD_zuQru6Lf27RQ PIN code: 6pb8
| Banana Pi BPI-M4 Android 8 1 1 demo ,power by raspberry Pi PoE module: https://www.youtube.com/watch?v=aEZ9tSJ-Oao&feature=youtu.be |
| Banana Pi BPI-M4 video play h264 4K under Linux with gst-launch-1.0;https://www.youtube.com/watch?v=PwdyGX3tqvo&feature=youtu.be&fbclid=IwAR3AHOgFo4I3bDRl3oLtQXFBj2NUCYBR9GJnEo3tZzpNPKhjE9eKms7JVsQ |
| Banana Pi BPI-M4 digital photo download: https://drive.google.com/file/d/1lD9vOhdZMqHFilTPPHY80My0biszvW8r/view?usp=sharing |
| BPI-M4 SBC bench test: http://forum.banana-pi.org/t/bpi-m4-sbc-bench-test/9469 |
| Banana pi BPI-M4: m.2 extension board with nvme ssd: http://forum.banana-pi.org/t/bpi-m4-m-2-extension-board-with-nvme-ssd/11999 |
| Banana Pi BPI-M4 Review: https://www.magazinmehatronika.com/en/banana-pi-m4-review/ |
| BPI-M4 USB host dying (uvcvideo and usb rtl8821cu) (solution): https://forum.banana-pi.org/t/bpi-m4-usb-host-dying-uvcvideo-and-usb-rtl8821cu-solution/13210 |
| Banana Pi BPI-M4: How to get I2C and SPI running (tutorial): https://forum.banana-pi.org/t/banana-pi-bpi-m4-how-to-get-i2c-and-spi-running-tutorial/12824 |
| 2020-10-20 update, Android 8.1 with kernel 4.9.119. |
| IMPORTANT: Note: BPI-M4 Android8 image is only support 2GB ddr board because 1GB ddr is not stable and smooth for Android8 |
| 2020-05-18 update,Ubuntu Mate 18.04, Ubuntu Server 16.04,kernel 4.9.119. |
Google Drive: https://drive.google.com/drive/folders/19xi4l9xX34r1EY3TGjs1guxnvt2qUIsr?usp=share_link
Download image: https://download.banana-pi.dev/d/3ebbfa04265d4dddb81b/?p=%2FImages%2FBPI-M4%2Flinux&mode=list
| 2019-6-18 update,Ubuntu Mate 18.04 ,Ubuntu Server 16.04 ,kernel 4.9.119. |
Release ntoes: http://forum.banana-pi.org/t/bpi-m4-demo-image-release-ubuntu-mate-18-04-ubuntu-server-16-04-2019-06-18/9362
Baidu Drive : https://pan.baidu.com/s/1tB_QZ6zgmKiYstcZwn51gg PIN code:edrc
MD5 : 7409b48a46e0bbc2d0ae2e70a49bfb36
Baidu Drive : https://pan.baidu.com/s/1lkG6gyzn-KPbvrEhf6Q85w PIN code:5jbo
MD5 : 328706256bec238df50f9bd6ab8dfd1b
| Issue: if HDMI doesn’t display, please try "ctrl + alt + F1" to change terminal then "ctrl + alt + F7" change to desktop display. |
| 2019-08-13 update,Debian 10 buster desktop(32bit),kernel 4.9. |
Release ntoes: http://forum.banana-pi.org/t/bpi-m4-bpi-w2-debian10-buster-desktop-new-demo-image-20190813/9712
Baidu Drive : https://pan.baidu.com/s/1WcrBkxm5OyBLedCBwaUz6Q PIN code:e6m3
MD5 : 300b37cdfa092d72dceddd4f33825b40
| Issue: if HDMI doesn’t display, please try “ctrl + alt + F1” to change terminal then “ctrl + alt + F7” change to desktop display. |
| SW2: switch to 0,if insert SD, SD start;if doesn’t insert SD,EMMC start. |
| 2019-08-06 update,Debian 10 Buster Lite Demo Image,kernel 4.9. |
Baidu Drive : https://pan.baidu.com/s/1CGxGUi8rt06tHwfk134Seg PIN code :7rcz
MD5 : 5a8b1eb36b782fdd742ba746c645593d
Debian 10 buster (32bit)
Baidu Drive : https://pan.baidu.com/s/1lTtcMTWqE0jG_1PWGtWSqw PIN code: gny6
MD5 : a59f2e6a298237a08bb523b53372d937
| 2019-6-19 update,AArch64 Linux Mate ,AArch linux liteOperation,kernel 4.9.119. |
Baidu Drive : https://pan.baidu.com/s/1GvGsfs7t018EoRIv-au1GA PIN code:o496
MD5 : d284b2326a36d2d9039fb8d7e20e2600
| AArch64 Linux Lite |
Baidu Drive : https://pan.baidu.com/s/1WivDWZHu_GnWOxhVOjoqIQ PIN code:uhcg
MD5 : 53bb6f8d00f8708dab96bc865eaddc5e
| 2020-05-18 update, Raspbian Stretch,Kernel 4.9.119 |
| 2019-6-19 update,Raspbian 9.8 stretch & AArch64 Linux Mate & AArch Linux Lite Operation system with kernel 4.9.119. |
Baidu Drive : https://pan.baidu.com/s/1gwD5ok9XLLQa0InU_-b7EA PIN code:uuqn
MD5 : a397a9c4d078c2841f0c243c573dc9a8
Easy to buy sample on aliexpress shop : https://pt.aliexpress.com/store/product/Banana-Pi-BPI-M4-Realtek-RTD1395-ARM-64-bit-Board/302756_33036948250.html?spm=2114.12010611.8148356.1.fcef30d9EoKVYY
| OEM&ODM, please contact: [email protected] |
