# fdtput -t s /media/pi/BPI-BOOT/bananapi/bpi-m4/linux/rtd-1395-bananapi-m4-2GB.dtb /spi@9801BD00 status okay
# fdtput -t s /media/pi/BPI-BOOT/bananapi/bpi-m4/linux/rtd-1395-bananapi-m4-1GB.dtb /spi@9801BD00 status okay
# reboot
| More Infomation: Banana Pi BPI-M4 |
Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit
Mali 470 MP4 GPU OpenGL ES 1.1/2.0 H.264 H.265,2K4K
Onboard1 GB DDR4 (option 2 GB)
8G eMMC flash (max 64 GB)
10/100 Mbit/s Ethernet and RTL8821 module support Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2
USB 2.0 TYPE C
M.2 Key E slot PCIE 2.0 and USB 2.0
PoE function support
BPI-M4 Android8 image only support 2GB ddr board.
BPI-M4 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
Make sure SW2 (board bottom near sd slot) switch to 1
Read document/bananapi_m4_usb_download_tool_guide.doc in usb flash tool package before flashing image.
Download BPI-M4 USB flash tool
xxx
xxx
xxx
xxx
Board SW2 (board bottom near sd slot) switch to 0
For the compatibility of new 2GB and 1GB board with one Linux image, the old batch (before May, 2020) 1GB board must update the spirom firmware, so it can run the new release image.
Login user/password: pi/bananapi or root/bananapi
xxx
xxx
xxx
xxx
xxx
xxx
xxx
xxx
Without device-tree overlay support, 40pin header SPI function is disabled default because pins multiplexing with uart2, it can be enabled according to this topic
https://forum.banana-pi.org/t/banana-pi-bpi-m4-how-to-get-i2c-and-spi-running-tutorial/12824 or by fdtput command without building kernel. Make sure boot partition mounted before doing this.
# reboot
sudo docker run --rm hello-world
Use iperf3 to test gmac
On PC Terminal.Execute
iperf3 -s
On M3 console:
TCP test
iperf3 -c serverIP
UDP test
iperf3 -u -c serverIP
You have two ways to setup BT
Use commands to setup BT
Use bluetoothctl tool to operate BT
Execute "bluetoothctl"
If you don’t know how to use bluetoothctl, type "help", you will see more commands
Execute these commands:
Use UI interface to setup BT
Use commands to setup WiFi client
ip link set wlan0 up
iw dev wlan0 scan | grep SSID
vim /etc/wpa_supplicant/wpa_supplicant.conf
network={
ssid="ssid"
psk="password"
priority=1
wpa_supplicant -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
dhclient wlan0
Use UI interface to setup WiFi Client
