| BPI-M7(Sige7) | BPI-M5 Pro(Sige5) | BPI-M4 Super(Sige3) | BPI-M1 Super(Sige1) | |
SoC Process |
8nm |
8nm |
22nm |
28nm |
CPU |
Rockchip RK3588 |
Rockchip RK3576 |
RK3568B2 |
RK3528 |
GPU |
ARM Mali-G610 MP4 |
ARM Mali G52 MC3 GPU |
Arm Mali‑G52‑2EE |
ARM Mali-450 GPU |
NPU |
6TOPS@INT8(3 NPU core) |
6TOPS@INT8(2 NPU core) |
1TOP@INT8 |
RAM |
4GB/8GB/16GB/32GB 64-bit LPDDR4x |
4/8/16GB 32-bit LPDDR4x |
2/4GB 32-bit LPDDR4x |
eMMC |
64GB/128GB eMMC |
32/128GB eMMC |
32GB eMMC |
8GB eMMC |
TF Card |
Molex Slot, Spec Version 2.x/3.x/4.x(SDSC/SDHC/SDXC) |
Yes |
Yes |
Yes |
Output |
1x HDMI 2.1, supports 8K@60fps,1x MIPI DSI up to 4K@60fps,1x DP 1.4 up to 8K@30fps |
1x HDMI 2.1, supports 4K@120fps,1x MIPI DSI, up to 2K@60fps,1x DP1.4, up to 4K@120fps |
1x MIPI DSI up to 2K@60fps 1x HDMI OUT2.0, supports 4K@60fps |
1x HDMI OUT2.0b, supports 4K@60fps |
Decoder |
8K@60fps H.265/VP9/AVS2 8K@30fps H.264 AVC/MVC 4K@60fps AV1,1080P@60fps MPEG-2/-1/VC-1/VP8 |
H.264, H.265, VP9, AV1 and AVS2 etc. up to 8K@30fps or4K@120fps |
4KP60 H.265/H.264/VP9 |
H.265, H.264, AVS2 4K@60fps |
Encoder |
8K@30fps H.265 / H.264 |
H.264 and H.265 up to 4K@60fps |
1080P60 H.264/H.265 |
H.264 and H.265 up to1080@60fps |
Wi-Fi |
AP6275P Wi-Fi 6 Module 802.11a/b/g/n/ac/ax, 2T2R MIMO with RSDB |
SYN43752 Wi-Fi 6 Module 802.11a/b/g/n/ac/ax, 2T2R MIMO with RSDB |
SYN43752 Wi-Fi 6 Module 802.11a/b/g/n/ac/ax, 2T2R MIMO with RSDBs |
PCIE |
PCIe 3.0 4-lanes M.2 Key M 2280 NVMe SSD Supported |
PCIe 3.0 1-lanes M.2 Key M 2280 NVMe SSD Supported |
PCIe 3.0 2-lanes M.2 Key M 2280 NVMe SSD Supported |
Ethernet |
2x 2.5G Ethernet |
2x Gigabit Ethernet |
Gigabit Ethernet & 2.5G Ethernet |
USB Host |
1x USB 3.0 & 1x USB 2.0 |
2x USB 2.0 |
USB-C |
1x USB-C Power jack & 1x USB Type-C 3.0(DP1.4/OTG) |
1x USB-C Power jack & 1x USB3.0 OTG |
1x USB-C Power jack & 1x USB2.0 OTG |
MIPI CSI/DSI |
2x 4-lane MIPI CSI 1x 4-lane MIPI DSI |
2x 4-lane MIPI CSI,1x 4-lane MIPI DSI |
1x 4-lane MIPI CSI,1x 4-lane MIPI DSI |
40-PIN Header |
yes |
yes |
yes |
yes |
LEDs |
2x LEDs |
2x LEDs |
2x LEDs |
2x LEDs |
Board Dimensions |
92mm × 62mm x 14.6mm |
