More Infomation: Banana Pi BPI-M5 More Infomation: Banana Pi BPI-M2_Pro |
SoC – Amlogic S905X3 quad-core Cortex-A55 processor @ up to 2.0 GHz with Mali-G31 MP2 GPU @ 650Mhz
System Memory – 4GB LPDDR4
Storage – 16GB eMMC flash (option up to 64GB), MicroSD slot up to 2TB
Video Output – HDMI 2.1 up to 4Kp60 with HDR, CEC, EDID
Audio – 3.5mm audio jack, digital HDMI audio
Connectivity – Gigabit Ethernet
USB – 4x USB 3.0 ports via VL817 hub controller, 1x USB-C port (for power only?)
Expansion – 40-pin Raspberry Pi header with 28x GPIO, UART, I2C, SPI, PWM, and power signal (+5V, +3.3V, GND).
Debugging – 3-pin debug header
Misc – Reset, Power, and U-boot button; power and activity LED’s; IR receiver
Power Supply – 5V @3A via USB Type-C port
Dimensions – 92x60mm (Not the same as Raspberry Pi PCB size, but they probably included the connectors during measurement)
Weight – 48grams
Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug. M2pro is used Micro-usb port for android image download and ADB debug.
Prepare a SDcard at least 8GB for linux development, android only support emmc boot.
The SOC rom first boot media is emmc, so board can’t bootup from SDcard if the emmc is bootable with any image flashed, more info please refer to board boot sequence.
In Android SDcard is mmc0, emmc is mmc1, but in Linux SDcard is mmc1, emmc is mmc0.
Download and install the AML Usb Burning Tool for android image download via USB type-c on M5 and Micro-usb on M2pro, only support windows.
Download the latest android image, and confirm that the md5 checksum is correct.
M5 and M2pro are compatiable with same android image.
Open USB_Burning_Tool.exe, select menu File→Import image, choose the android image file aml_upgrade_package.img.
M5/M2pro board disconnect power, press and hold SW4 button beside 40pin header, plugin type-c usb cable(microUSB on m2pro) to PC
Click the Start button and wait for upgrade complete.
After Burning successfull, Unplug the usb and connect to power supply adaptor to startup.
Click the Stop button to cancel the upgrade process and close the USB Buring Tool.
Aml-flash-tool is a linux platform opensource image flash util for Amlogic android.
Get Android 9.0 source code
or you can get the source code tar archive from Baidu Pan(pincode: 8888) or Google Drive
Build the Android 9.0 Source code Please read the source code README.md
Bananapi M5/M2Pro DTBO idx value table, default idx value is 0 in release image.
| Bananapi M5/M2pro DTBO idx value table | ||
idx value |
device tree overlay |
description |
0 |
android_p_overlay |
default dtbo, no use |
1 |
wifi_bt_rtl8822cs |
enable bpi rtl8822cs wifi/bt module |
2 |
i2c2 |
enable i2c 2 |
3 |
i2c3 |
enable i2c 3 |
4 |
sdio |
enable sdio |
5 |
uart1 |
enable 2 pins uart 1 |
6 |
uart1_cts_rts |
enable 4 pins uart 1 |
7 |
uart2 |
enable 2 pins uart 2 |
8 |
hifi_pcm5122 |
enable i2s pcm5122 HiFi DAC |
How to apply a new dtbo
ADB command via sysfs
restarting adbd as root
remount succeeded
bananapi_m5:/ # reboot
Uart console command via sysfs
console:/ $
console:/ $ su
[ 115.702781@0] unifykey: name_store() 1302, name dtbo, 4
[ 115.702856@0] unifykey: name_store() 1311
console:/ #
[ 129.262659@0] unifykey: write_store() is a string
[ 129.262733@0] unifykey: dtbo, 1, 1
[ 129.265312@0] unifykey: amlkey_write 393
[ 129.292347@1] emmc_key_write:149, write ok
console:/ #
console:/ # reboot
Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Default build-in overlays are defined in device/amlogic/bananapi_m5/Kernel.mk, you can add a new overlay dtbo here.
Default apply DTBO idx is defined in device/amlogic/bananapi_m5/BoardConfig.mk, you can change the idx value to set which overlay dtbo will be applied default.
DTS files are in common/arch/arm/boot/dts/amlogic/overlay/bananapi_m5/ More info about android device tree overlays, please refer to google android offical site
Download install package from OpenGapps, Android release image is arm/android 9.0 variant.
Download device_id.apk.
Copy the OpenGapp package to a udisk or sdcard root directory.
Create a txt file named factory_update_param.aml in udisk or sdcard root directory with the following android recovery parameter content, and replace the file name with the actual downloaded package.
udisk:
--wipe_cache
sdcard:
--wipe_cache
Plugin the udisk or sdcard to the board and poweron.
OpenGapps install and certify.
YouTube Video: https://youtu.be/fXOKmWfpqF8
Watch this video on bilibili
Linux kernel input key event.
Android keycode.
Linux keycode map to android keycode.
Android Adb function work on your PC
Pull the remote files from device
Modify remote.cfg to enable remote debug message
Push remote.cfg back
# adb root
# adb remount
# adb shell
work_mode = 1
repeat_enable = 0
debug_enable = 1
max_frame_time = 1000
Get the remote keycode
custom_code = 0xfe01
Modify remote.tab to map the scancode to android keycode
# adb root
# adb remount
# adb shell
work_mode = 1
repeat_enable = 0
debug_enable = 1
custom_name = nec-test
fn_key_scancode = 0xffff
cursor_left_scancode = 0xffff
cursor_up_scancode = 0xffff
cursor_down_scancode = 0xffff
cursor_ok_scancode = 0xffff
release_delay = 80
map_size = 13
key[0] = 0x74
key[1] = 0x1008b
key[2] = 0x90066
key[3] = 0x20069
key[4] = 0xa006a
key[5] = 0x50067
key[6] = 0x4006c
key[7] = 0x6001c
key[8] = 0x30072
key[9] = 0xb0073
key[10] = 0x40009e
key[11] = 0x4800a4
key[12] = 0x440071
Reboot the board
Linux image support SDcard or EMMC bootup, but you should read the boot sequence at first.
It’s recommended to use A1 rated cards, 8GB at least.
M5 and M2pro are compatiable with same Linux image.
Make sure bootable EMMC is formatted if you want bootup from SDcard
Make sure SDcard is formatted without Linux image flashed if you want bootup from EMMC and use Sdcard as storage.
Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can’t access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
$ apt-get install pv
Download latest Linux Image, and confirm that the md5 checksum is correct.
Default login: pi/bananapi or root/bananapi
The wiki guide is only for bananapi 4.9 bsp ubuntu/debian images.
Install Image with Balena Etcher on Windows, Linux and MacOS.
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
Install Image with Balena Cli on Windows, Linux and MacOS.
$ sudo balena local flash path/to/xxx-bpi-m5-xxx.img.zip
$ sudo balena local flash path/to/xxx-bpi-m5-xxx.img.zip --drive /dev/disk2
$ sudo balena local flash path/to/xxx-bpi-m5-xxx.img.zip --drive /dev/disk2 --yes
Install Image with dd command on Linux
Mount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
Install image with bpi-tools on Linux
Plug SDcard to Linux PC and run
Prepare a SDcard with Linux image flashed and bootup board with this SDcard.
Copy Linux image to udisk, plug the udisk to board and mount it.
There are two ways to install the linux image to board.
Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command.
Install the linux image in udisk with bpi-tools command
After download complete, power off safely and eject the SDcard.
Get the Linux bsp source code
Build the bsp source code
If you want build uboot and kernel separately, please download the u-boot the kernel only, get the toolchains, boot script and other configuration files from BPI-M5-bsp
DTB overlay is used for 40pin gpios multi-function configuration and install in vfat boot partition, you can check the mount point with mount command.
custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo
ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo
hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo
hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo
i2c0.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo
i2c1.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo
pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
Update the overlays env in vfat /boot/boot.ini to enable what you want. Default i2c0, spi0 and uart1 enabled.
# Overlays to load
# Example combinations:
# spi0 i2c0 i2c1 uart0
# hktft32
# hktft35
Must be restart the board for overlay dtb loaded.
| Note: This WiringPi only support set 40pin gpio to output, input or software pwm, for io functions as i2c, spi, pwm…, you must enable dtb overlay in boot.ini |
Build and install wiringPi, for debian, you must install sudo before build
$ sudo apt-get update
$ cd amlogic-wiringPi
$ chmod a+x build
$ sudo ./build
Run gpio readall to show all 40pins status.
BPI GPIO Extend board and examples in amlogic-wiringPi/examples
$ cd RPi.GPIO-Amlogic
Create and install wheel package
Install from git source directly without development
If the package is already installed, it should be uninstalled before installing the new one, or installing the new one with --force-reinstall option.
$ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git
$ cd WiringPi2-Python-Amlogic
Luma.examples use GPIO.BCM gpio mode default, so you should map 40pin header pins to bcm gpio number and connect the hardware correctly.
Build and install RPi.GPIO
You can change the bcmledpin variable in test/led.py to your hardware backlight gpio and run it to check RPi.GPIO works well.
$ sudo python3 test/led.py
Hardware backlight will repeat on and off
Luma.examples libs install
If group does not exist, the following command will create it:
$ sudo groupadd --system xxx
$ cd luma.examples
Install luma.core, luma.emulator, luma.lcd, luma.le-matrix, luma.oled pip libs, make sure this step without error or downloading interrupted, try again if get errors
$ sudo -H pip install -e .
or
$ sudo -H pip3 install -e .
For debian buster(python 3.7) which does not include /usr/bin/pip in package python3-pip, and will get the following errors when install luma packages with pip3
Using UNIX configuration...
Install sdl2 related packages to fix this issue, then install luma libs again with pip3
check installed luma pip libs
$ pip3 list | grep luma
luma.core 2.4.0
luma.emulator 1.4.0
luma.lcd 2.10.0
luma.led-matrix 1.7.0
luma.oled 3.11.0
examples test Enable i2c or spi overlays before running test examples
$ cd examples
| Bananapi M5/M2pro Tested HDMI LCD | |
panel |
/boot/boot.ini |
setenv display_autodetect "false" |
Backlight control : https://github.com/Dangku/Waveshare-USB-Brightness
S905x3 is not support usb boot in soc rom, so the only way for booting linux from usb drive is create a bootable sdcard or emmc with bootloader flashed, then load boot and rootfs from usb drive. After bootup, everything will run from usb drive.
The simple way is flash the M5/M2Pro Linux image to sdcard or emmc for bootable and also flash it to the usb drive for loading boot and rootfs.
Bootup the M5/M2pro board with sdcard or emmc, copy /boot/boot.ini to /boot/boot.ini.org so that bootloader load boot.ini fail and then try to load it from usb drive boot partition.
Reboot the system, bootscript and rootfs will load from usb drive.
Test performance You can verify the performance of your usb drive on Pi Benchmarks using the following command:
Test results for sd, emmc and usb drive
Category |
Test |
Sdcard Test Result |
Emmc Test Result |
Usb Drive Test Result |
HDParm |
Disk Read |
67.91 MB/s |
156.64 MB/s |
253.40 MB/s |
HDParm |
Cached Disk Read |
57.39 MB/s |
126.53 MB/s |
253.52 MB/s |
DD |
Disk Write |
13.0 MB/s |
48.8 MB/s |
149 MB/s |
FIO |
4k random read |
2456 IOPS (9826 KB/s) |
9701 IOPS (38806 KB/s) |
5474 IOPS (21897 KB/s) |
FIO |
4k random write |
938 IOPS (3753 KB/s) |
12888 IOPS (51554 KB/s) |
6980 IOPS (27920 KB/s) |
IOZone |
4k read |
10615 KB/s |
29568 KB/s |
23770 KB/s |
IOZone |
4k write |
4276 KB/s |
33585 KB/s |
18598 KB/s |
IOZone |
4k random read |
8661 KB/s |
29637 KB/s |
19982 KB/s |
IOZone |
4k random write |
4795 KB/s |
38177 KB/s |
22134 KB/s |
Score: 1300 |
Score: 7811 |
Score: 5879 |
Compress the bmp file to boot-logo.bmp.gz
copy the target file to BPI-BOOT partition of linux image
Download m5_android_bootlogo_tool.zip
Extract this tool
$ cp -a logo_img_files logo //logo_img_files is the origin bootlogo resource in android source and copy from <android-source-dir>/devices/amlogic/bananapi_m5/log_img_files
$ ls -l logo/
Copy the boot-logo.bmp.gz
Create target logo.img with img pack tool, the binary and related libs of m5_android_bootlogo_tool are copy from <android-source-dir>/out/host/linux-x86
Flash boot logo with fastboot
$ adb root
$ adb remount
$ adb reboot fastboot
$ fastboot device
1234567890 fastboot
$ fastboot reboot
Rom load bootloader from SDcard (Linux log example)
BL2 Built : 15:21:42, Mar 26 2020. g12a g486bc38 - gongwei.chen@droid11-sz
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
Use GP1_pll as DSU clk.
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 1
fw parse done
PIEI prepare done
fastboot data verify
result: 255
DDR4 probe
Rom load bootloader from EMMC(Android Log example)
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 1
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
ddr saved addr:00016000
00000000
Bootable EMMC with Android image flashed
Using usb burning tool, unplug the download usb cable while the download process at 7% formatting
Using Android Fastboot tool, make sure the adb/fastboot tools is work on your PC before doing this.
remount succeeded
1234567890 fastboot
OKAY [ 0.044s]
finished. total time: 0.044s
OKAY [ 0.047s]
finished. total time: 0.047s
erasing 'bootloader'...
OKAY [ 0.059s]
finished. total time: 0.059s
erasing 'bootloader-boot0'...
OKAY [ 0.036s]
finished. total time: 0.036s
erasing 'bootloader-boot1'...
OKAY [ 0.035s]
finished. total time: 0.035s
Using uboot command, connect a debug console cable and press ESC while power on to enter uboot command line
bananapi_m5_v1#amlmmc erase 1
start = 0,end = 57343
start = 221184,end = 30535679
start = 0,end = 8191
bananapi_m5_v1#reset
resetting ...
These two ways actually erase the bootloader part of EMMC android, After bootup from SDcard Linux, You’d better format the whole EMMC by dd command.
The simplest way is insert the SDcard with Linux image flashed before power on, the Android bootloader will check boot.ini file whether exist in SDcard vfat partition, so that the SDcard Linux will bootup. After bootup, you can format the whole EMMC by dd command and then flash the Linux image to EMMC.
BPI: try boot from sdcard
reading boot.ini
reading Image.gz
reading uInitrd
reading overlays/i2c0.dtbo
reading overlays/spi0.dtbo
reading overlays/uart1.dtbo
Bootable EMMC with Linux image flashed
bananapi_m5# mmc erase 0 1000
Linux u-boot also check boot.ini file whether exist in SDcard vfat partition so that the SDcard Linux will bootup. After bootup, you can format the whole EMMC by dd command or flash the Linux image directly to EMMC.
A extreme situation is bootloader or uboot corrupted, Rom load it from EMMC but hangup in u-boot or BL2, for example the boot process will hangup in BL2 of EMMC if dram init failed, The only way is format the EMMC with usb burning tool, or download the Android image completely and then try other ways to erase EMMC or flash Linux image to EMMC.
Rom will try to load bootloader from SDcard directly if EMMC is empty.
$ sync
Android test and support.
rtl8723bu wifi/bt(usb)
rtl8188eu wifi(usb)
rtl8821cu wifi/bt(usb)
rtl8822cs wifi/bt(sdio/uart)
How to enable Android Wifi/BT
| Note: Android is not support that ethernet and wifi are both connected at the same time, Ethernet have a higher prioprity than wifi, it means wifi can’t connect network if ethernet already connected, and wifi will drop connection if ethernet cable plugin. |
Linux test and support.
rtl8188eu wifi(usb)
rtl8192eu wifi(usb)
rtl8811au wifi(usb)
rtl8812au wifi(usb)
rtl8812bu wifi(usb)
How to enable Linux Wifi
Wifi module drivers are already prebuild in the release images. USB type: Plug-in the usb dongle to usb host port and driver will be loaded automatically.
SDIO/UART type:
Connect the hardware module to 40pin header correctly.
Configure the dtb overlay(path:/boot/boot.ini)
# Overlays to load
# hktft32
# hktft35
Add the wifi module name to /etc/modules for loaded automatically next boot.
88x2cs
How to enable Linux Bluetooth
Please download rtk-linux-bt-driver source code, build and install usb or uart rtk linux bluetooth drivers/firmwares to your image.
For USB type, plug-in the usb dongle to usb host port and driver will be loaded automatically.
For UART type, Configure the dtb overlay as the same as wifi before install the bluetooth drivers/firmwares. hci_uart driver will be loaded when rtk-hciuart.service start.
Linux Wifi STA mode
network:
version: 2
renderer: networkd
wifis:
wlan0:
dhcp4: true
access-points:
"bananapi":
password: "123456789"
Linux Wifi AP mode
Prepare the setup the wifi adater correctly.
Get the wifi adapter Band, Frequencies, Channel, HT Capability, VHT Capability or other properties
$ iw list
Manage wifi access point mode with Netplan and Network-Manager. Install NetworkManager because ap is only supported with NetworkManager renderer
network:
version: 2
renderer: NetworkManager
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 2.4GHz
channel: 6
auth:
key-management: psk
network:
version: 2
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 5GHz
channel: 36
auth:
key-management: psk
Manage wifi access point mode with Netplan and Hostapd.
Create a netplan configuration file, 01-wlan0-ap-hostapd.yaml
network:
version: 2
renderer: networkd
ethernets:
wlan0:
dhcp4: no
addresses:
- 192.168.11.1/24
Install hostapd
$ sudo apt install hostapd
interface=wlan0
ssid=bananapi
driver=nl80211
auth_algs=1
wpa=2
wpa_passphrase=123456789
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
#bridge=br0
beacon_int=500
#SSID not hidden
ignore_broadcast_ssid=0
hw_mode=a
channel=36
max_num_sta=8
### IEEE 802.11n
ieee80211n=1
#require_vht=0
### IEEE 802.11ac
ieee80211ac=1
#require_vht=0
#vht_oper_chwidth=1
### WMM
wmm_enabled=1
To support 80MHz channel width you need load driver with rtw_vht_enable=2 option, Or you can create /etc/modprobe.d/8822cs.conf with content
Install and configure dhcp server service, use isc-dhcp-server for example
# Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACESv4="wlan0"
option routers 192.168.11.1;
Start Service
Routing configuration.
sysctl net.ipv4.ip_forward=1
disable or remove cloud-init
or
$ sudo apt purge cloud-init
disable or remove snap
$ sudo apt purge snapd
[Unit]
After=network.target
[Service]
Type=forking
ExecStart=/etc/rc.local start
TimeoutSec=0
RemainAfterExit=yes
GuessMainPID=no
[Install]
WantedBy=multi-user.target
Alias=rc-local.service
Create /etc/rc.local file.
sudo nano /etc/rc.local
#!/bin/sh
# rc.local
# value on error.
# bits.
exit 0
$ sudo chmod +x /etc/rc.local
$ sudo reboot
$ su root
Password:(enter bananapi)
# apt-get update
# apt-get install sudo
# adduser pi sudo
Then please do logout and login again.
Set up the repository Update the apt package index and install packages to allow apt to use a repository over HTTPS:
Set up the stable repository
$ echo \
Verify the Docker Engine is installed correctly by running the hello-world image.
$ sudo docker run hello-world
