Banana Pi BPI-M64 is a 64-bit quad-core mini single board computer. It features 2GB of RAM and 8GB eMMC. It also has onboard WiFi and BT. On the ports side, the BPI-M64 has 2 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, and lastly a DC power port. The processor is pin-to-pin comptialbe with R18, so it comes with two versions:M64 and M64-R18.
| More Infomation: Banana Pi BPI-M64 |
A64
1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-A64
2GB DDR3 SDRAM
8G EMMC
10/100/1000Mbps Ethernet
WiFi (AP6212) & Bluetooth
R18
1.2 Ghz Quad-Core ARM Cortex A53 64-Bit Processor-R18
2GB DDR3 SDRAM
8G EMMC
Prepare a USB-Serial cable, a MicroUSB cable and PC with Linux or WIndows 7/10
The USB-Serial cable is used for console debug and MicroUSB cable is used for Image download and ADB debug.
M64 board is only suport DC power supply bootup.
If you want insert a SDcard for Android storage using, and your SDcard was download Linux Image or any other allwinner bootable SDcard image, please format the SDcard start from block 0.
Download and Install Allwinner Image Download Tools, PhoenixSuit is for window and LiveSuit is for Linux
Open PhoenixSuit, click the Firmware icon to switching to firmware download panel, then click Image button and choose the Android Image file.
M64 board disconnect DC power, press and hold the uboot-key button(new uart debug pin), plugin mirco-usb cable to PC, popup a warning dialog.
Press Yes to continue and popup another waring dialog, Press Yes to continue
Downloading
Download finish
According to the Readme.pdf in LiveSuit Install package, After install the LiveSuit successfully please run LiveSuit.sh with root permission, then the download process is almost the same as PhoenixSuit.
Get Android source code
Android 7.1
$ git clone https://github.com/BPI-SINOVOIP/BPI-A64-Android7
Android 6.1
Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
Using your USB-Serial Connect debug console on M64
Install bpi-tools on your Linux PC. If you can’t access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
$ apt-get install pv
Download BPI latest image
Login user/password: pi/bananapi or root/bananapi
Windows PC
Install Image with Balena Etcher.
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
Linux PC
There are two methods for you to choose from.
Install Image with dd command on Linux, umount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
$ sudo unzip -p xxx-bpi-m64-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
$ sudo bpi-copy xxx-bpi-m64-xxx.img.zip /dev/sdX
Prepare a SDcard with Linux image flashed and bootup board with this SDcard.
Unzip the image and copy it to a USB drive, plug the udisk to board and mount it.(If automatically mounted, ignore this step)
mount /dev/sdx /mnt
There are two ways to install the linux image to board.
Install with dd command.
sudo dd if=/mnt/xxx.bpi-p2_zero-xxx.img of=/dev/mmcblk0 bs=10M status=noxfer
Install the linux image in udisk with bpi-tools command
$ sudo bpi-copy xxx-bpi-p2_zero-xxx.img.zip /dev/mmcblk0
After download complete, power off safely and eject the SDcard.
The default release images are HDMI boot type, you can switch to LCD boot type for BPI 7" LCD support after first boot.
$ sudo bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m64/BPI-M64-LCD7-linux4.4-8k.img.gz
$ reboot
Load the Touchscreen driver if you want to using TP
$ sudo modprobe gt9xxnew_ts.ko
Get the bsp source code
$ git clone https://github.com/BPI-SINOVOIP/BPI-M64-bsp-4.4
Use iperf3 to test gmac
On PC Terminal:
Execute
iperf3 -s
On M2U console:
TCP test:
iperf3 -c serverIP
UDP test:
iperf3 -u -c serverIP
Use bluetoothctl tool to operate BT
Execute
bluetoothctl
If you don’t know how to use bluetoothctl, type "help", you will see more commands
Execute these commands:
Use commands to setup WiFi client
ip link set wlan0 up
iw dev wlan0 scan | grep SSID
vim /etc/wpasupplicant/wpa_supplicant.conf
network={
ssid="ssid"
psk="password"
priority=1
wpa_supplicant -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
dhclient wlan0
Use UI interface to setup WiFi Client
Install hostapd and create hostapd configuration file hostapd.conf:
interface=wlan0
driver=nl80211
ssid=test
hw_mode=g
channel=1
Execute command
hostapd -d /<path>/hostapd.conf
If you meet problem like this:
nmcli radio wifi off
rfkill unblock 1
rfkill unblock 2
ifconfig wlan0 up
hostapd -d hostapd.conf
git clone https://github.com/BPI-SINOVOIP/BPI-files/tree/master/SD/100MB
bpi-bootsel BPI-cleanboot-8k.img.gz /dev/sdX
To access a GPIO pin you first need to export it with
with XX being the number of the desired pin. To obtain the correct number you have to calculate it from the pin name (like PH18)
(position of letter in alphabet - 1) * 32 + pin number for PH18 this would be ( 8 - 1) * 32 + 18 = 224 + 18 = 242 (since 'h' is the 8th letter) |
echo "out/in" > /sys/class/gpio/gpio*NUMBER*/direction
echo "0/1" > /sys/class/gpio/gpio*NUMBER*/value
We use HDF5640 camara.
Use your UI interface to operate camara
Applications → Sound & Video → guvcview
We also have built-in command in "/usr/local/bin" to test camara
Test picture taking function
./test_ov5640_image_mode.sh
Test video recording function
./cameratest.sh
IR function
Execute
getevent
Use your IR device to send information to A64
git clone https://github.com/BPI-SINOVOIP/RPi.GPIO
cd RPi.GPIO
sudo apt-get update
sudo apt-get install python-dev python3-dev
Execute
sudo python setup.py install
or
sudo python3 setup.py install
cd /usr/local/bin
./bpi_test_g40.py
We also have built-in test command in
/usr/local/bin
How to Update WiringPi
bpi-update -c pkglist.conf
bpi-update -c bpi-pkg-bpi-wiringpi.conf
/usr/local/bin/bpi_test_lcd1602.sh
/usr/local/bin/bpi_test_52pi.sh
Firstly you need a GPIO Extend Board for 8x8 LED Martix
/usr/local/bin/bpi_test_gpio40.sh
