MT7615 module have support BPI-R2, BPI-R64, and We have tested the parametric performance of module 7615 in the laboratory.To achieve the optimal
BPI-R64+MT7615 test wifi function with openwrt
BPI-R64
BPI-MT7615 module
12V/2A adapter
USB serial port line(3.3V)
TF card
5.8GHz wifi antenna,1-4 pcs
Openwrt image: https://docs.banana-pi.org/en/BPI-R64/BananaPi_BPI-R64#_system_image
Use tooling(windows Win32DiskImager)burn BPI-R64 openwrt image to TF card,Then insert the TF card slot;MT7615 module insert to BPI-R64 mPCIe interface CN25,connect UART debug line and wifi antenna, then power on to boot.
When the boot is complete, type in the serial port : ifconfig rai0 up to boot MT7615 Then configure rai0 IP address,such as :ifconfig rai0 192.168.11.11
Use PC to connect MTK_AP2 SSID,Then configure the IP manually
Since there is only one antenna for wifi, the connection speed is only 433Mbps. During the test, there are no walls or other barriers between the notebook and MT7615, and MT7615 is in the channel with less interference.
Distance 0.5 m test: MT7615 distance 0.5 m from laptop 5.1.1.signal strength
Iperf speed test
Signal strength
Iperf speed test
Signal strength
Iperf speed test
The dc power supply is set to 12V output
When BPI-R64 power,330mA
When open MT7615 anc pc connect wifi,390mA
When iperf test speed,480mA
