Banana Pi R64 is a router based development board, which can run on a variety of open source operating systems including OpenWrt,Linux. It design with Mediatek MT7622 64 bit chip, has 4 Gigabit LAN ports, 1 Gigabit WAN, and AC wifi AP function. 1G DDR RAM and 8G eMMC onboard
Mediatek MT7622 chip design : Banana Pi BPI-R64 Router board Mediatek MT7622 chip design : Banana Pi BPI-MNF 5G + 4G LTE+Wifi AC+Gigabit Multiplex aggregate route |
| Note: this board doesn’t have HDMI interface |
MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53
1G DDR3 SDRAM
Mini PCIE interface support 4G module
built-in 4x4n 802.11n/Bluetooth 5.0 system-on-chip
MTK7622 2G WiFi(Onboard 2G WiFi) and MTK7615 4x4ac wifi (option 5G WiFi module)
support 1 SATA interface
MicroSD slot supports up to 256GB expansion
8G eMMC flash (option 16/32/64G)
128MB nand flash
5 port 10/100/1000 Mb Ethernet port
1 USB 3.0
Slow I/O:ADC, Audio Amplifier, GPIO, I2C, I2S, IR, PMIC I/F, PWM, RTC, SPI, UART
POE function support
the inner and outer diameter of the power plug adapter datasheet: https://drive.google.com/file/d/1k3AWmYOs2XE7lnRxCyytZu0Vpq_Bzcu_/view?usp=sharing
| HardWare Specification of Banana Pi R64 | |
CPU |
MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53 |
SDRAM |
1 GB DDR3 |
SATA |
support 1 SATA interface |
GPIO |
40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. |
On board Network |
5 10/100/1000Mbps Ethernet |
Wifi |
built-in 4x4n 802.11n (800Mbps) sysem-on-chip and MTK7615 4x4ac wifi Module (1733Mbps) (option) |
Bluetooth |
Bluetooth 5.0 system-on-chip |
On board Storage |
MicroSD \(TF\) card,8GB eMMC onboard |
Mini PCIE |
1 mini pcie interface for 4G |
USB |
1 USB 3.0 host |
Buttons |
Reset button |
Leds |
Power status Led and RJ45 Led |
IR |
PIN define with GPIO |
DC Power |
12V/2A with DC in |
POE |
support POE module interface,can add POE module |
Sizes |
148 mm × 100.5mm same as Banana Pi BPI-R3 and Banana Pi BPI-R2 |
Weight |
100g |
We design PoE function for BPI-R64 ,so easy to add PoE module to support PoE function,PoE modue can support IEEE 802.3bt PoE standard ,Max support 12V/3A to power BPI-R64
more PoE module spec
use pcie interface standard module ,and use SIM card slot onboard
use 4G extend module via USB port
USB 4G module : https://docs.banana-pi.org/en/BPI-4G_module/4G_module_via_USB
We have design a MT7615 802.11 ac wifi module ,can use on BPI-R64
| BPI-R64 Linux BSP(kernel 5.4): https://github.com/BPI-SINOVOIP/BPI-R64-bsp-5.4 |
| BPI-R64 Linux BSP(kernel 4.19): https://github.com/BPI-SINOVOIP/BPI-R64-bsp-4.19 |
| BPI-R64 Linux BSP(kernel 4.4) : https://github.com/BPI-SINOVOIP/BPI-R64-bsp |
| Frank github(kernel 5.4): https://github.com/frank-w/BPI-R2-4.14/tree/5.4-r64-dsa |
| Banana Pi BPI-R64 (MT7622) openwrt (Kernel 4.19) : https://github.com/BPI-SINOVOIP/BPI-R64-openwrt |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| BPI-R64 schematic diagram |
Baidu cloud: https://pan.baidu.com/s/1iKmucXGQ5BuvGqKl3f3qFA?pwd=8888 (pincode: 8888)
| BPi-R64-V12-ASSY |
Baidu cloud: https://pan.baidu.com/s/162WwU9r-ytf-qccLimETTg?pwd=8888 (pincode: 8888)
| BPI-R64 DXF file for case deign : https://drive.google.com/file/d/1_YNsdQ9Cv7FVOGrqd6GP0Tu5u2cjLwTA/view?usp=sharing |
| BPI-R64 DXF file and the parts used for the assembly datasheet: https://drive.google.com/file/d/1LK5HkP4AfE8xNLJMRHvc7JgexfkDBUAF/view?usp=sharing |
| 3D printed case for Banana PI R-64. Link https://www.thingiverse.com/thing:4261948 |
| BPI-R64 3D design file update with SolidWorks : http://forum.banana-pi.org/t/bpi-r64-3d-design-file-with-solidworks/10910 |
| MTK 7622 chip : https://www.mediatek.com/products/homeNetworking/mt7622 |
| MTK MT7622A_Datasheet_for_BananaPi_Only : https://drive.google.com/file/d/1DVEv3bovA8cPti3Ln7d9lDBjMCGFSE5m/view?usp=sharing |
| MT7622 Reference Manual for Develope Board(BPi) : https://drive.google.com/file/d/1cW8KQmmVpwDGmBd48KNQes9CRn7FEgBb/view?usp=sharing |
| MT7531 switch chip datasheet: https://drive.google.com/file/d/1aVdQz3rbKWjkvdga8-LQ-VFXjmHR8yf9/view?usp=sharing |
| Banana Pi BPI-R64 debian Linux boot demo and bootlog: http://forum.banana-pi.org/t/banana-pi-bpi-r64-debian-linux-boot-demo-and-bootlog/8155 |
| Banana Pi BPI-R64 passed AWS Greengrass : https://devices.amazonaws.com/detail/a3G0h000000OvObEAK/Banana-Pi-R64 |
| Bpi-R64 quick start (boot from eMMC): http://forum.banana-pi.org/t/bpi-r64-quick-start-boot-from-emmc/9809 |
| Banana Pi BPI-R64 CE,FCC,RoHS Certification : http://forum.banana-pi.org/t/banana-pi-bpi-r64-open-source-router-board-ce-fcc-rohs-certification/10094 |
| Patchwork/Mailinglist there was a DSA-driver for mt7531 released : https://patchwork.kernel.org/project/linux-mediatek/list/?submitter=189635 |
| MTK chip mailline Linux effort : https://mtk.bcnfs.org/doku.php?id=linux_mainline_effort |
| BPI-R64 current u-boot support : http://forum.banana-pi.org/t/bpi-r64-current-u-boot-support/10077 |
| New netfilter flow table based HNAT: http://forum.banana-pi.org/t/new-netfilter-flow-table-based-hnat/12049 |
| [Tutorial] Build, customize and use MediaTek open-source U-Boot and ATF : https://forum.banana-pi.org/t/tutorial-build-customize-and-use-mediatek-open-source-u-boot-and-atf/13785 |
| [BPI-R2/R64/R3] OpenWrt built on devices : https://openwrt.org/docs/guide-developer/toolchain/building_openwrt_on_openwrt |
| Banana Pi BPI-R64 passed Amazon AWS Greengrass: https://devices.amazonaws.com/detail/a3G0h000000OvObEAK/Banana-Pi-BPI-R64 |
| Download and setup separate ATF image for booting directly into kernel or u-boot |
| Banana Pi BPI-R64 19.07.7 OpenWRT Router image 2021-05-01 |
Baidu link : https://pan.baidu.com/s/1RxtvekBOxP0UtNSzx5mpEg Pincode: fthx
Source code on github: https://github.com/BPI-SINOVOIP/BPI-R64-openwrt.git
Discuss on forum : http://forum.banana-pi.org/t/banana-pi-bpi-r64-19-07-7-openwrt-router-image-2021-05-01/12209
Custom OpenWrt build for Banana Pi R64: http://forum.banana-pi.org/t/bpi-r64-custom-openwrt-build-for-banana-pi-r64/10973
| BPI-R64 new image : LEDE17 (OpenWRT) image Kernel:4.4.177 2020-04-09 |
Baidu cloud : https://pan.baidu.com/s/1UR-Uli2chQ5tO9VCl5Yz6A Pincode:j00s
Discuss on forum: http://forum.banana-pi.org/t/bpi-r64-new-image-lede17-openwrt-image-kernel-4-4-177-2020-04-09/10924
| Mainline OpenWRT image |
Discuss on forum : http://forum.banana-pi.org/t/r64-mainline-openwrt-image/11415
| 2021-6-16 update BPI-R64 Ubuntu Server 21.04 image |
Baidu link: https://pan.baidu.com/s/1nEfneNrFND1dfDLBAekdsg Pincode: dfvv
| 2019-08-23 update,Ubuntu Server 16.04,This release is for banana pi R64 board, and it is based on kernel 4.19. |
MD5 : 79fc190def54140dd9bf12b73e263bd0
Username : root/pi ; password : bananapi
Forum Pthread: http://forum.banana-pi.org/t/bpi-r64-ubuntu-16-04-aarch64-linux-lite-debian-10-buster-lite-demo-images-release-2019-08-23/9759
| 2020-12-22 Ubuntu 18.04 with kernel 5.4.0 |
Discuss on forum : http://forum.banana-pi.org/t/bpi-r64-new-image-debian10-and-ubuntu18-04-linux-kernel-5-4-0-2020-05-08/11106
Supports 4G Module(EC20)
| [BPI-R64] debian buster with new bootchain and linux 5.10,frank share this image |
| 2020-05-08 updae ,Debian10 with kernel 5.4.0 |
Download link : https://download.banana-pi.dev/d/3ebbfa04265d4dddb81b/?p=%2FImages%2FBPI-R64%2FDebian10&mode=list
| 2019-08-23 update,Debian 10 buster lite,This release is for banana pi R64 board, and it is based on Debian 10 Buster Lite Operation system with kernel 4.19. |
Baidu Drive : https://pan.baidu.com/s/1hVQj-1_rYc74QQ1Z4WoaiQ (PinCode:g1j5)
MD5 : fa3f6a7f7a4bcf2c5a8072301cf8c268
| 2018-12-11 update This release is for banana pi R64 board which is based on Mtk 7622, Debian 8 AARCH64 is based on kernel 4.4.92 |
Baidu Drive : https://pan.baidu.com/s/1AdCM9lTuWP9oXiOE2qGsDw
Md5sum : 4b43980375c3f9692c1f0585ca6b541a
Easy to buy sample: BPI official Aliexpress shop
The debug-uart TTL is tolerant to 3.3V.
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-r64.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-R64-MTK7622/1100417230_40000003430450.html |
| Bipai Aliexpress Shop: https://www.aliexpress.com/store/group/BPI-R64-MTK7622/1101951077_40000002157510.html |
| OEM&ODM, please contact: [email protected] |
