| More Infomation: Banana Pi BPI-R64 |
MediaTek MT7622,1.35GHZ 64 bit dual-core ARM Cortex-A53
1G DDR3 SDRAM
Mini PCIE interface support 4G module
Built-in 4x4n 802.11n/Bluetooth 5.0 system-on-chip
MTK7615 4x4ac wifi on board
Support 1 SATA interface
MicroSD slot supports up to 256GB expansion
8G eMMC flash (option 16/32/64G)
5 port 10/100/1000 Mb Ethernet port
1 Port USB 3.0
Slow I/O:ADC, Audio Amplifier, GPIO, I2C, I2S, IR, PMIC I/F, PWM, RTC, SPI, UART
POE function support
Prepare 8G/above TF card, USB-Serial interface
Using your USB-Serial(3.3V,Baud: 115200) Connect debug console on R64
Default IP address for LAN port: 192.168.1.1
User name/password: pi/bananapi ,root/bananapi.
WIFI: Operwrt
Windows PC
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
bpi-copy
Install bpi-tools. If you can’t access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
apt-get install pv
curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
After you download the image, insert your TF card into your Ubuntu.Execute
bpi-copy xxx.img /dev/sdx
install image on your TF card
dd
Mount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
Before burning image to eMMC, please prepare a SD card with flashed bootable image and a USB disk. Let’s take OpenWrt image (mtk-bpi-r64-preloader-emmc.bin,2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img) for example.
| Note: You can download the ".bin" file from github: https://github.com/BPI-SINOVOIP/BPI-R64-openwrt/tree/master/staging_dir/target-aarch64_cortex-a53_musl/image |
Insert the flashed SD card and power on to start the board.(the image on the SD card can be OpenWrt or other linux OS like ubuntu…)
Copy eMMC bootable OpenWrt image(mtk-bpi-r64-preloader-emmc.bin,2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img) to USB disk, if the image is compressed please uncompress it before copying to USB disk.
Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically)
mount -t vfat /dev/sda1 /mnt
cd /mnt
Execute following command to enable and copy image to eMMC:
echo 0 > /sys/block/mmcblk0boot0/force_ro
dd if=2020-04-09-OpenWRT-mtk-bpi-r64-EMMC.img of=/dev/mmcblk0
dd if=mtk-bpi-r64-preloader-emmc.bin of=/dev/mmcblk0boot0
mmc bootpart enable 1 1 /dev/mmcblk0
Shutdown, remove SD card and USB disk, and restart the board from eMMC.
Network-Configuration : http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:network:start
40 Pins Definition
echo xxx > /sys/class/gpio/export
echo in/out > /sys/class/gpio/gpioxxx/direction
echo 0/1 > /sys/class/gpio/gpioxxx/value
echo 431(22+409) > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio431/direction
echo 1 > /sys/class/gpio/gpio431/value
echo x >/sys/class/pwm/pwmchip0/export
echo 200000 >/sys/class/pwm/pwmchip0/pwmx/period
echo 100000 >/sys/class/pwm/pwmchip0/pwmx/duty_cycle
echo 1 >/sys/class/pwm/pwmchip0/pwmx/enable
SPI Panel module:
SPI Panel <–> BPIR64
T_DO, T_DIN, T_CLK <–> SPIC_0: MOSI / MISO / CLK
T_CS <–> SPI-CE0
T_IRQ <–> IO-37
SDO, SCK, SDI <–> SPIC_1: MOSI / MISO / CLK
LED <–> PIN-31
DC <–> PIN-11
RESET <–> PIN-13
CS <–> SPI-CE1
GND <–> GND-9
VCC <–> 3.3V-1
DTS Modification:
backlight: backlight {
compatible = "gpio-backlight";
gpios = <&pio 82 GPIO_ACTIVE_HIGH>; //PIN31 IO-31 : GPIO82
default-on;
&pio {
spic0_pins: spic0-pins {
mux {
function = "spi";
groups = "spic0_0";
spic1_pins: spic1-pins {
mux {
function = "spi";
groups = "spic1_0";
&spi0 {
pinctrl-names = "default";
pinctrl-0 = <&spic0_pins>;
status = "okay";
touch@0 {
reg = <0>; //CE0
compatible = "ti,ads7843";
interrupt-parent = <&pio>;
interrupts = <86 0>; //PIN37: IO-37 == GPIO86
pendown-gpio = <&pio 86 0>;
spi-max-frequency = <1000000>;
vcc-supply = <®_3p3v>;
wakeup-source;
&spi1 {
pinctrl-0 = <&spic1_pins>;
status = "okay";
display@0{
compatible = "ilitek,ili9341";
reg = <0>; //CE0
spi-max-frequency = <32000000>;
dc-gpios = <&pio 51 GPIO_ACTIVE_HIGH>; //PIN11 UART1-TXD : GPIO51
reset-gpios = <&pio 52 GPIO_ACTIVE_HIGH>; //PIN13 UART1-RXD : GPIO52
backlight = <&backlight>;
Kernel config:
+CONFIG_FB_TFT_ILI9341
+CONFIG_FB_TFT
+CONFIG_FB
+CONFIG_BACKLIGHT_LCD_SUPPORT
+CONFIG_BACKLIGHT_CLASS_DEVICE
+CONFIG_BACKLIGHT_GPIO
+CONFIG_INPUT
+CONFIG_INPUT_TOUCHSCREEN
+CONFIG_TOUCHSCREEN_ADS7846
Application:
| Package | + Description | Source |
fbv |
framebuffer image viewer |
input-event-daemon |
input-event-daemon with touchTEST event |
input-event-daemon config that show image by touch area: (I don’t know why are the coordinates so strange, but the result of my actual touch and print out that it is like this)
[Global]
listen = /dev/input/event0
listen = /dev/input/event1
[TouchTEST]
340,400,3440,1860 = cat /dev/zero > /dev/fb0; fbv -f /root/bpi_608x429.jpg -s 1
340,2260,3440,1860 = cat /dev/zero > /dev/fb0; fbv -f /root/openwrt_449x449.png -s 1
Banana Pi BPI-R64 SPI touch panel test: https://www.youtube.com/watch?v=ikag-D_TI0g&feature=youtu.be
If you want to use Sata interface on R64, you need to give GPIO90 low level
echo 499 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio499/direction
echo 0 > /sys/class/gpio/gpio499/value
Test a TOSHIBA HDD DISK, the Read/Write performance are below:
Read from disk: 50MB/s command:
dd if=/dev/sda of=/dev/null bs=1M count=1024
Write to disk: 38MB/s command:
dd if=/dev/zero of=/dev/sda bs=1M count=1024
Test a SAMSUNG SSD DISK, the Read/Write performance are below:
Read from disk: 360MB/s command:
Write to disk: 200MB/s command:
If you want to use PCIe interface on R64, you need to give GPIO90 high level
echo 1 > /sys/class/gpio/gpio499/value
PCIe supports EC-25 4G module.
Use iperf3 to test gmac
On PC Terminal.Execute
iperf3 -s
On R64 console:
TCP test:
iperf3 -c serverIP
UDP test:
iperf3 -u -c serverIP
R64 BT Architectural
BLE on R64
Input Command "btmw-test", you will enter to "btmw_test_cli" command line
Here are some example commands:
MW_GAP name 7622_BT /*rename bt device*/
MW_GAP info /*check local BT device info*/
MW_GATTC scan /* start ble scan*/
MW_GATTC stop_scan /* stop ble scan*/
LAN eth interface is eth2
ifconfig eth2 up
Config the ip, "ifconfig eth2 192.168.1.1".
Config your dhcp server
vim /etc/dhcp/dhcpd.conf
add these configurations.
Start dhcp server, "dhcpd eth2".
Then config iptables and set package forward.
Add "net.ipv4.ip_forward=1" to "/etc/sysctl.conf"
"/sbin/sysctl -p" to make forward work
"iptables -t nat -A POSTROUTING -s 192.168.1.1/24 -o eth3 -j MASQUERADE"
Find "mt_wifi.ko" and insmod it.
insmod ./lib/modules/4.4.92-BPI-R64-Kernel/extra/mt_wifi.ko
Then you will see ra0 and rai0.
ra0 is MT7622 2.4G wifi
rai0 is MT7615 5G wifi
Use "ifconfig ra0 up" to enable it.
Config the ip, "ifconfig ra0 192.168.1.1".
Config your dhcp server, "vim /etc/dhcp/dhcpd.conf", add these configurations.
Start dhcp server, "dhcpd ra0". Then config iptables and set package forward.
Use "ifconfig rai0 up" to enable it.
Config the ip, "ifconfig rai0 192.168.1.1".
Start dhcp server, "dhcpd rai0".Then config iptables and set package forward.
MT7622 Reference Manual for Develope Board(BPi)
BaiDu Drive: https://pan.baidu.com/s/1KduFT2MUvMs2FhOF4A8kQQ
