Banana Pi Pico-RP2040 series is a low-power microcontroller development board designed for the Internet of Things.
BPI-Pico-RP2040 is a microcontroller development board launched by Banana Pi equipped with RP2040 chip. Its most notable feature is to add a Onboard WS2812 color LED; replace the 3-Pin DEBUG interface with a JST SH 1mm 4-Pin socket, which can be connected with Qwiic & STEMMA QT or any possible peripherals; replace the micro-USB socket with a USB Type-C socket , supports reversible insertion, and is compatible with the USB Type-C cable of most modern smartphones, no additional purchase is required.
ESP32-S3 design Banana Pi BPI-Centi-S3 IoT and Maker DIY design ESP32-S3 design Banana Pi BPI-Leaf-S3 IoT and Maker DIY design ESP32-S3 design Banana Pi BPI-Pico-S3 IoT and Maker DIY design Raspberry Pi RP2040 design Banana Pi BPI-Pico-RP2040 IoT and Maker DIY design |
Dual-core ARM Cortex M0+ CPU cores (up to 133 MHz)
264K SRAM
2MB Flash
26 available GPIO pins, 4 of which support ADC analog input
1 x LED
1 x Neopixel LED
1 × SH 1.0 4-Pin socket
1 × USB Type-C socket
| HardWare Specification of Banana Pi BPI-Pico-2040 | |
Main Chip |
RP2040,Dual-core ARM Cortex M0+ CPU cores |
Frequency |
133MHz MAX |
Operating temperature |
-20℃~+85℃ |
On-chip SRAM |
264 KB |
On-board FLASH |
2MB |
GPIO |
26 GPIO |
ADC |
4 analogue inputs |
GPIO |
I2C |
SPI,DSPI,QSPI |
UART |
SDIO (SD card) |
I2S |
8080 and 6800 parallel port |
USB input voltage |
5V |
3V3 output current |
2A MAX |
Neopixel LED |
1 |
LED |
1 |
USB Type-C socket |
1 |
SH 1.0 4-pin socket |
1 |
| BPI-PicO-RP2040 Size | |
Pin spacing |
2.54mm |
Mounting hole spacing |
17.6mm/ 11.4mm |
Mounting hole size |
Inner diameter 2.1mm/outer diameter 3.4mm |
Mainboard size |
11.4 × 55.8(mm) |
Thickness |
1.2mm |
The pin spacing is compatible with universal boards (hole boards, dot matrix boards) and breadboards, which is convenient for debugging applications.
| BIPAI Aliexress shop: https://www.aliexpress.com/item/1005005083258994.html |
| SINOVOIP Aliexpress shop : https://www.aliexpress.us/item/3256804896912828.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US |
| Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-24708246124.11.774a3ce5S1Yvbl&id=695456693140 |
| OEM&ODM,please contact: [email protected] |
