Banana Pi BPI-R3 Mini Router board with MediaTek MT7986(Filogic 830) quad core ARM A53 chip design ,2G DDR RAM ,8G eMMC flash onboard,It is a very high performance open source router development board,support Wi-Fi6 2.4G wifi use MT7975N and 5G wifi use MT7975P, support 2 2.5GbE network port.
| More Infomation: Banana Pi BPI-R3 |
MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53
Wifi 6 2.4G/5G(MT7976C)
2G DDR RAM
8G eMMC flash
128MB Nand flash
2x 2.5GbE network port
1x M.2 Key B USB inerface
1x M.2 KEY M PCIe inerface
1x USB2.0 interface
Prepare 8G/above TF card, USB-Serial interface.
Using your USB-Serial Connect debug console on BPI-R3.
Debug Uart 3.3v TTL,Baud: 115200.
Default IP address for LAN port:192.168.1.1
User name/password: pi/bananapi ,root/bananapi.
WIFI: Operwrt
R3 bootstrap and device select Jumper Setting
SW1-A and SW1-B is for boot strap selecting; SW1-C is that SPI-Nand or SPI-Nor Device is connected to CPU’s SPI bus; SW1-D is that SD Card or EMMC device is connected tp CPU’s EMMC bus. |
| Please low level format the SD and clear all data of SD. It’s very important. Otherwise, you will encounter a "jffs2" error during the startup process. |
Windows PC
Install Image with Balena Etcher.
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
Linux PC
Install bpi-tools. If you can’t access this URL or any other problems, please go to bpi-tools repo and install this tools manually.
apt-get install pv
curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
After you download the image, insert your TF card into your Ubuntu.
Execute
bpi-copy xxx.img /dev/sdx
to install image on your TF card.
Insert the TF card into R3, switch to the correct boot, and power on to start up R3.
| Change Boot Jumper to boot from SD, Enable SD Card Device. |
Let’s take OpenWrt image (mtk-bpi-r3-SD-WAN1-SFP1-20220619-single-image.img, mtk-bpi-r3-NAND-WAN1-SFP1-20220619-single-image.bin) for example, the steps are below:
Insert the flashed SD card and power on to start the board.(the image "mtk-bpi-r3-SD-WAN1-SFP1-20220619-single-image.img" on the SD card can be OpenWrt or other linux OS like ubuntu…)
Copy Nand bootable OpenWrt image(mtk-bpi-r3-NAND-WAN1-SFP1-20220619-single-image.bin) to USB disk, if the image is compressed please uncompress it before copying to USB disk.
Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically)
mount -t vfat /dev/sda1 /mnt
change your directory to the mounting point, here is :
cd /mnt
Execute following command to enable and copy image to nand flash:
mtd erase /dev/mtd0
dd if=mtk-bpi-r3-NAND-WAN1-SFP1-20220619-single-image.bin of=/dev/mtdblock0
Remove SD card, change the switch to boot from nand flash, reboot the board from Nand Flash.
| Enable device, boot strap is from nand |
| Note: SD card and EMMC device share one SOC interface |
| Switch the button to NAND and then start BPI-R3 |
Insert the USB drive with bl2_emmc.img and mtk-bpi-r3-EMMC-xxx.img into BPI-R3.
Mount the USB drive to/mnt, and then execute the following command to burn the image to EMMC:
cd /mnt
echo 0 > /sys/block/mmcblk0boot0/force_ro
dd if=bl2_emmc.img of=/dev/mmcblk0boot0
dd if=mtk-bpi-r3-EMMC-WAN1-SFP1-20220619-single-image.img of=/dev/mmcblk0
mmc bootpart enable 1 1 /dev/mmcblk0
power off R3 board, remove u-disk driver, change bootstrap to boot from emmc device.
| Enable EMMC device, boot strap is from EMMC. |
| To boot from SD card, pull the C jumper to enable SPI-NOR. |
Copy NOR bootable OpenWrt image(mtk-bpi-r3-NOR-WAN1-SFP1-20220619-single-image.bin) to USB disk, if the image is compressed please uncompress it before copying to USB disk.
cd /mnt
mtd erase /dev/mtd0
dd if=mtk-bpi-r3-NOR-WAN1-SFP1-20220619-single-image.bin of=/dev/mtdblock0
Remove the SD card and change the jumper to NOR boot.
Network-Configuration refer to: http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:network:start
Network Interface: eth1, lan0 is for WAN; lan4, rax0, lan2, lan5, ra0, lan3, lan1 is for LAN, ra0 is for 2.4G wireless, rax0 is for 5G wireless.
root@OpenWrt:/# ifconfig
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:2418 (2.3 KiB)
RX bytes:0 (0.0 B) TX bytes:8538 (8.3 KiB)
RX bytes:0 (0.0 B) TX bytes:4408 (4.3 KiB)
Interrupt:124
RX bytes:0 (0.0 B) TX bytes:8674 (8.4 KiB)
Interrupt:124
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
Interrupt:6
26 Pins Definition
echo xxx > /sys/class/gpio/export
echo in/out > /sys/class/gpio/gpioxxx/direction
echo 0/1 > /sys/class/gpio/gpioxxx/value
echo 433(22+411) > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio433/direction
echo 1 > /sys/class/gpio/gpio433/value
R317 for 5V FAN and R318 for 12V FAN.
CN23 supports PWM control while CN22 does not support.
echo 0 > /sys/class/pwm/pwmchip0/export
echo 10000 > /sys/class/pwm/pwmchip0/pwm0/period
echo 5000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
echo normal > /sys/class/pwm/pwmchip0/pwm0/polarity
echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
Currently, miniPCIe slot only support one USB 4G module, example: EC25 when you insert one EC25 module, you may check it.
After high and low temperature test, the following modules are suppoted by BPI-R3:
BPI-R3 supports 4G LTE EC25.
If you want to use 5G on BPI-R3:
Insert 5G dongle into USB3.0.
Connect RG200U-CN to mini PCIe, connect SoC through USB2.0(speed limited).
Make an RG200U-CN LGA adapter board and insert it into M.2 KEY M.
| Note: The availability of 4G/5G depends on the local carrier frequency band. |
ra0 is MT7986a 2.4G wifi
rax0 is MT7986a 5G wifi
If the chip type of serial cable is pl2303, the driver fails to load the firmware apparently and thus the wifi can’t work.
Other types including cp2102,ch340 and FDTI are all available, serial cable vlotage must be 3.3v LVTTL standard.
UART_TX0 is the Boot Strapping PIN and must be kept low during power-on.
MT7986a Reference Manual for Develope Board(BPi) Google Drive: https://drive.google.com/file/d/1biSJmxnIpNzQroYDg9mtPtSTAv4i0DFf/view?usp=sharing
TTL Voltage
The debug-uart TTL is tolerant to 3.3V.
