Banana Pi BPI-R3 Router board with MediaTek MT7986(Filogic 830) Quad core ARM A53 + MT7531A chip design ,2G DDR RAM ,8G eMMC flash onboard. It is a very high performance open source router development board,support Wi-Fi 6 2.4G wifi use MT7975N and 5G wifi use MT7975P, support 2 SFP 2.5GbE port, and 5 GbE network port
MediaTek MT7988 (Filogic 880) design: Banana Pi BPI-R4 Pro Router development board MediaTek MT7988 (Filogic 880) design: Banana Pi BPI-R4 Router development board MediaTek MT7987 (Filogic 860) design: Banana Pi BPI-R4 Lite Router board MediaTek MT7987 (Filogic 860) design: Banana Pi BPI-R4 Mini Wifi7 Router board MediaTek MT7986(Filogic 830) design: Banana Pi BPI-R3 Mini Mini size Router development board MediaTek MT7986(Filogic 830) design: Banana Pi BPI-R3 Router development board MediaTek MT7981(Filogic 820) design: Banana Pi Openwrt One Router development board MediaTek MT7623N design: Banana Pi BPI-R2 Router development board |
YouTuBe Video: https://youtu.be/RO8J_sLEyBg
MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design
Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
2G DDR RAM
8G eMMC flash
128MB SPI Nand
2x SFP 2.5GbE
5x GbE network port
POE support (optional)
Mini PCIe via USB
M.2 KEY-M PCIe inerface
Mciro SD card interface
26 PIN GPIO
Maker DIY
Internet service Router
Wireless Router
Wireless Repeater
Home security Gateway
Home Automation
Nas device
Network and communication applications
Jumper Setting of Banana pi BPI-R3 |
Jumper Setting |
SW1 |
SW2 |
SW5 |
SW6 |
SPIM-NoR |
Low |
Low |
Low |
X |
SPIM-Nand |
High |
Low |
High |
X |
eMMC |
Low |
High |
High |
Low |
SD card |
High |
High |
X |
High |
| HardWare Specification of Banana Pi R3 | |
CPU |
MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design |
SDRAM |
2 GB DDR4 |
On board Storage |
MicroSD \(TF\) card,8GB eMMC onboard |
GPIO |
26 Pin GPIO,some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. |
On board Network |
5 Port 10/100/1000Mbps Ethernet |
SFP |
2 SFP 2.5GbE |
Wifi |
Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P) |
mini PCIE |
Mini PCIe via USB |
M.2 interface |
M.2 KEY-M PCIe inerface |
USB |
1 USB 3.0 host ,2 USB interface with slot. |
Buttons |
Reset button,WPS botton, boot switch |
Leds |
Power status Led and RJ45 Led |
DC Power |
12V/2A with DC in |
Sizes |
100.5x148mm same as Banana Pi BPI-R64 and Banana Pi BPI-R2 |
Weight |
200g |
BPI-R3 can use Quectel EC25E minipcie-slot
Notice:
The SFP serdes of R3 are fixed 2.5Gbase-X, so only SFP that support this protocol can be used.
And there is no debugging insertion detection function, so there will be no prompt when inserting any SFP module.
The SFPs we have tested that work are as follows:
2.5G Copper: SFP-2.5G-T-R-RM
2.5G Optical Fiber: SFP-2.5G-BX0-U/SFP-2.5G-BX0-D
TP-LINK 2.5G Copper: TL-SM410U
TP-LINK 2.5G Optical Fiber: TL-SM411LSA-500m/TL-SM411LSA-500m
Easy to buy:
SFP Copper Module:
SINOVOIP Aliexpress Shop: https://www.aliexpress.com/item/3256805015251590.html?gatewayAdapt=4itemAdapt
Bipai Aliexpress Shop: https://www.aliexpress.com/item/3256805015329676.html?gatewayAdapt=4itemAdapt
Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.19.12722367QBRXCJ&id=702147676760
SFP Fibre Module:
SINOVOIP Aliexpress Shop: https://www.aliexpress.com/item/3256805416517044.html?gatewayAdapt=4itemAdapt
Bipai Aliexpress Shop: https://www.aliexpress.com/item/3256805416773989.html?gatewayAdapt=4itemAdapt
Taobao Shop: https://item.taobao.com/item.htm?id=719557580139&spm=a1z10.5-c-s.w4002-25059194413.21.12722367QBRXCJ
ASIA.RF AW7916-NPD:
Module: WiFi6E 3000 802.11ax G-band 2T2R and A-band 3T3R 2ss Dual Bands Dual Concurrents mPCIe Card AW7916-NPD(With BPI-M.2 to mPCIe Adapter)
BPI-M.2 to mPCIe Adapter:
Test Items:
As Client:
Easy to buy:
SINOVOIP Aliexpress Shop: https://www.aliexpress.com/item/3256806501559230.html?gatewayAdapt=4itemAdapt
Bipai Aliexpress Shop: https://www.aliexpress.com/item/3256806501611160.html?gatewayAdapt=4itemAdapt
Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.25.12722367QBRXCJ&id=773626754788
Easy to buy:
SINOVOIP Aliexpress Shop: https://www.aliexpress.com/item/3256805581533519.html?gatewayAdapt=4itemAdapt
Bipai Aliexpress Shop: https://www.aliexpress.com/item/3256805581539217.html?gatewayAdapt=4itemAdapt
Taobao Shop: https://item.taobao.com/item.htm?ft=t&id=726562119098
We have reserved a POE interface in BPI-R3, which can be customized if you have needs.
Add a network management chip, solder the POE module, and replace the 2.5G SFP WAN interface with RJ45 (power is provided through this network port)
| Official BPI-R3 kernel v5.15 + firmware repo: https://github.com/BPI-SINOVOIP/BPI-R3-bsp-5.15 |
| Official OpenWrt 21.02 for BPI-R3 repo: https://github.com/BPI-SINOVOIP/BPI-R3-OPENWRT-V21.02.3 |
Baidu link: https://pan.baidu.com/s/1JSQ7wJTCeK4JqWR_XB-LLQ?pwd=6vdb (Pincode: 6vdb)
| Frank’s U-Boot repo: https://github.com/frank-w/u-boot/tree/2023-04-bpi |
| Frank’s BPI-R3 kernel v6.1 repo https://github.com/frank-w/BPI-Router-Linux/tree/6.1-main |
| Unofficial wiki (English): https://wiki.fw-web.de/doku.php?id=en:bpi-r3:start |
| BPI-R3 DXF file : Baidu cloud: https://pan.baidu.com/s/10L6rXjdDa1Sz0cQVDYnp8Q?pwd=8888 (pincode:8888) |
| BPI-R3 schematic diagram |
Baidu Cloud: https://pan.baidu.com/s/1-GJNHAqNy7-JFTx22uoSfQ?pwd=8888 (pincode:8888)
| MT7986A_Datasheet_1.15 : https://drive.google.com/file/d/1t_nuPTeoAcFb1dmEe4kJVlLWdHcAA6OB/view?usp=sharing |
| MT7986A_Reference_Manual_for_BPI-R3 : https://drive.google.com/file/d/1biSJmxnIpNzQroYDg9mtPtSTAv4i0DFf/view?usp=sharing |
| [Tutorial] Build, customize and use MediaTek open-source U-Boot and ATF : https://forum.banana-pi.org/t/tutorial-build-customize-and-use-mediatek-open-source-u-boot-and-atf/13785 |
| BPI-R3 OpenSource Routerboard how to burn and test image: https://www.youtube.com/watch?v=Xaf_SC7fPDM |
| BPI-R3 CE,FCC,RoHS certificate : https://banana-pi.org/en/bpi-honor/ |
| Banana Pi BPI-R3 Review: Details, Pricing, & Features : https://androidpimp.com/embedded/banana-pi-bpi-r3-router-board/?fbclid=IwAR1G4cEco5iULwKG-C-n8MIiWOWZMhPborqmCzS2d3KIHx-eNQS-54lZnps |
| Update OpenWrt to 22.03.3 SNAPSHOT: https://forum.banana-pi.org/t/bananapi-bpi-r3-update-openwrt-to-22-03-3-snapshot/14984 |
| 3D printed cases: https://forum.banana-pi.org/t/banana-bpi-r3-3d-printed-case/14246/43 |
| Cooling solutions topic: https://forum.banana-pi.org/t/bpi-r3-running-hot/14750 |
| Bananapi R3 review with WiFi / CPU benchmarks and power consumption numbers: https://wiki.junicast.de/en/junicast/review/bananapi-BPI-R3 |
| [BPI-R2/R64/R3] OpenWrt built on devices : https://openwrt.org/docs/guide-developer/toolchain/building_openwrt_on_openwrt |
| [Tutorial] Reworking BPI-R3 nand Flash: https://forum.banana-pi.org/t/tutorial-reworking-bpi-r3-nand-flash/15492 |
| BananaPi BPI-R3, now with ROOTer support!: https://wirelessjoint.com/viewtopic.php?t=3852 |
| OpenWRT official for Sinovoip BananaPi BPi R3: https://openwrt.org/toh/sinovoip/bananapi_bpi-r3 |
| Setting up the Banana-R3 with OpenWRT: https://uglyscale.press/2023/09/13/setup-the-banana-r3-with-openwrt/ |
| OpenWRT official support : https://openwrt.org/toh/sinovoip/bananapi_bpi-r3 |
| Latest official OpenWRT snapshot image: |
https://firmware-selector.openwrt.org/?version=SNAPSHOT&target=mediatek%2Ffilogic&id=bananapi_bpi-r3
Discuss on OpenWRT forum: https://forum.openwrt.org/t/openwrt-support-for-banana-pi-bpi-r3/154294
| 2022-07-20 udptae BPI-R3 OpenWRT 21.02 linux kernel 5.4, wifi 6 2.4G and 5G mac80211 opensource wifi driver working fine support nand flash ,SD card ,eMMC flash boot. for BPI-R3 production version hardware |
Baidu Cloud: https://pan.baidu.com/s/1-5tqHEacMw1wlTSEK1ey9A?pwd=8888 (pincode: 8888)
| 2022-06-01udptae BPI-R3 OpenWRT 21.02 linux kernel 5.4, wifi 6 2.4G and 5G working fine support nand flash ,SD card ,eMMC flash boot. for BPI-R3 production version hardware |
Baidu link: https://pan.baidu.com/s/1idqU1-bB4XD1LTGDAJxRGA?pwd=chez Pincode: chez
Discuss on forum : https://forum.banana-pi.org/t/banana-pi-bpi-r3-openwrt-image/13236
2022-09-28 udptae BPI-R3 OpenWRT 21.02 linux kernel 5.4, wifi 6 2.4G and 5G working fine support nand flash ,SD card ,eMMC flash boot, support EC25 LTE 4G Modules for BPI-R3 production version hardware |
Baidu link: https://pan.baidu.com/s/1v4sKfAuax3AfHNtp_2RP_g?pwd=mebq (Pincode: mebq)
| 2022-12-18-ubuntu-22.04-server-bpi-r3-aarch64-sd-emmc.img |
Baidu Cloud: https://pan.baidu.com/s/1PajBEeFkgzgBdmJa5KpHpA?pwd=8888 (pincode: 8888)
User/Password:bpi/bananapi,root/bananapi
| [BPI-R3] Debian Bullseye Image, this image is share by Frank: |
| 2022-12-18-debian-11-bullseye-lite-bpi-r3-5.15-sd-emmc.img, Kernel 5.15.77 |
Baidu Cloud: https://pan.baidu.com/s/195HeMXjK-rmCEZTnYBCndA?pwd=8888 (pincode: 8888)
| 2022-12-18-debian-10-buster-lite-bpi-r3-5.15-sd-emmc.img, Kernel 5.15.77 |
Baidu Cloud: https://pan.baidu.com/s/1_OGb8ZMF4pWIbaKJ0z2JsA?pwd=8888 (pincode: 8888)
| Frank’s Debian Bullseye image: https://forum.banana-pi.org/t/bpi-r3-debian-bullseye-image/14541 |
| Frank’s Ubuntu 22.04 image: https://forum.banana-pi.org/t/bpi-r3-ubuntu-22-04-image/14956 |
| Image: https://os.oray.com/ |
Failed to save the configuration
Enter "mtd erase /dev/mtd10"
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-r3-router-board-with-mediatek-mt7986-chip-design-2g-ddr-ram-8g-emmc-flash-onboard.html |
| SINOVOIP Aliexpress Shop: https://www.aliexpress.us/item/3256804530142161.html |
| Bipai Aliexpress Shop: https://www.aliexpress.us/item/3256804530395673.html |
| OEM&ODM, please contact: [email protected] |
