Banana Pi BPI-R4Pro Router board with MediaTek MT7988A(Filogic 880) Quad-core ARM Cortex-A73 design ,4GB/8GB DDR4 RAM,8GB eMMC,256MB SPI-NAND flash onboard.It supports 4 x 2.5G network ports and 2 x 10G SFP+/RJ45 ports, support 4G/5G expansion。it is a update version for BPI-R4.
MediaTek MT7988 (Filogic 880) design: Banana Pi BPI-R4 Pro Router development board MediaTek MT7988 (Filogic 880) design: Banana Pi BPI-R4 Router development board MediaTek MT7987 (Filogic 860) design: Banana Pi BPI-R4 Lite Router board MediaTek MT7987 (Filogic 860) design: Banana Pi BPI-R4 Mini Wifi7 Router board MediaTek MT7986(Filogic 830) design: Banana Pi BPI-R3 Mini Mini size Router development board MediaTek MT7986(Filogic 830) design: Banana Pi BPI-R3 Router development board MediaTek MT7981(Filogic 820) design: Banana Pi Openwrt One Router development board MediaTek MT7623N design: Banana Pi BPI-R2 Router development board |
The MediaTek Filogic 880 platform provides a 36 Gbps Wi-Fi 7 access point/router/gateway solution that delivers the fastest and most reliable connectivity experience.
The MediaTek MT7988A is a world-class network processor designed for high-performance and reliable networking in both wired and wireless applications. It offers a comprehensive set of connectivity interfaces, including four Gigabit Ethernet ports, two USXGMII interfaces, four PCIe interfaces, and two USB 3.2 Gen 1 ports.
The MT7988A further enables seamless tri-band Wi-Fi 7 connectivity across the 2.4 GHz, 5 GHz, and 6 GHz bands, with its Wi-Fi 7 companion chip featuring 320 MHz bandwidth, 4096-QAM, MLO, MRU and AFC
To meet the needs of rapidly evolving tunneling applications, the MT7988A comes equipped with the MediaTek Tunnel Offload Processor System (TOPS), which facilitates the processing of a wide range of tunneling protocols. The MT7988A optimizes networking performance with a finely tuned ISA of MediaTek TOPS, delivering premium-level offloading capabilities.
NOTE:Some functions require continuous software updates and improvements.
Internet service Router
Wifi7 Wireless Router
4G/5G Wireless Router
Wireless Repeater
Home security Gateway
Home Automation
Nas device
Network and communication applications
BPI-R4Pro(8X)
MediaTek MT7988A Quad-core Arm Cortex-A73,1.8GHz processor
8GB DDR4
8GB eMMC flash
256MB SPI-NAND Flash
1x 10G SFP+ WAN and 1x 10G RJ45 WAN(combo with 10G SFP+ WAN)
1x 10G SFP+ LAN and 1x 10G RJ45 LAN(combo with 10G SFP+ LAN)
4x 2.5G RJ45 LAN
1x 1G RJ45 LAN and 1x 1G LAN(FPC Connector)
2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi NIC
2x M.2 M-KEY slots with PCIe3.0 1lane interface for NVME SSD
3x M.2 B-KEY slots with USB3.2 for 4G/5G Cellular Module
1x USB3.2 slot and 1x USB2.0 slot
| The EXT LED Connector and the EXT SIMCard Connector are reserved functional interfaces. |
| The EXT LED Connector integrates LEDs, WPS Key, RST Key, and other functionalities into this interface. |
| The EXT SIMCard Connector centralizes the SIM card signals from minipcie and M.2 KEYB to this interface. |
BPI-R4Pro(8X)
BPI-R4Pro(4E)
| HardWare Specification Of Banana Pi R4 Pro(8x) | HardWare Specification Of Banana Pi R4 Pro(4e) | |
CPU |
MediaTek MT7988A Quad-core Arm Cortex-A73,1.8GHz processor |
SDRAM |
8GB DDR4 |
4GB DDR4 |
On board Storage |
MicroSD (TF) card Slot |
On board Ethernet |
1x 10G RJ45 WAN |
1x 2.5G RJ45 WAN |
SFP |
1x 10G SFP+ WAN (combo with 10G RJ45 WAN) |
1x 10G SFP+ WAN (combo with 2.5G RJ45 WAN) |
mini PCIE Slot |
2x miniPCIe slots with PCIe3.0 2lane interface for Wi-Fi NIC |
M.2 Slot |
2x M.2 M-KEY slots with PCIe3.0 1lane interface for NVME SSD |
USB |
1x USB3.2 TypeA Connector |
Debug |
1x USB TypeC on board USB-UART Debug Console |
GPIO |
2x13 PIN Header for expanding application |
FAN |
2x Headers with PWM-controlled for fan |
RTC |
1x CR1220 connector for RTC Battery |
Buttons |
Reset button,WPS botton, bootstrap switch |
Leds |
Power status Led and RJ45 Led |
DC Power |
DC5521 12V/5.2A or 19V 3.2A |
Sizes |
132mm x 194mm |
132mm x 194mm |
Weight |
about 220g |
about 210g |
free discuss on forum: https://forum.banana-pi.org/t/bpi-r4-pro-case-design/23597
BANANAPI Official Shop: https://www.bpi-shop.com/products/bpi-r4-pro-metal-case.html
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=995526954605
BIPAI Aliexpress shop: https://ko.aliexpress.com/item/1005010407277956.html?gatewayAdapt=glo2kor
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/1005010407173030.html
BANANAPI Official Shop: https://www.bpi-shop.com/products/4010hmforbpi-r4pro.html
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=1002605653849
SINOVOIP Aliexpress shop: https://ko.aliexpress.com/item/1005010545381814.html?gatewayAdapt=glo2kor
BIPAI Aliexpress shop: https://ko.aliexpress.com/item/1005010545616434.html?gatewayAdapt=glo2kor
BANANAPI Official Shop: https://www.bpi-shop.com/products/5020haforbpi-r4pro.html
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=1001802418462
SINOVOIP Aliexpress shop: https://ko.aliexpress.com/item/1005010545676402.html?gatewayAdapt=glo2kor
BIPAI Aliexpress shop: https://ko.aliexpress.com/item/1005010545605871.html?gatewayAdapt=glo2kor
BIPAI Aliexpress shop: https://www.aliexpress.com/item/3256806271951703.html?gatewayAdapt=4itemAdapt
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/3256806271841150.html?gatewayAdapt=4itemAdapt
Taobao shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.13.7d282ac1cYaQ03&id=761569524881
BIPAI Aliexpress shop: https://www.aliexpress.com/item/3256806271761161.html?gatewayAdapt=4itemAdapt
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/3256806271623117.html?gatewayAdapt=4itemAdapt
Taobao shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.15.7d282ac1cYaQ03&id=761853438478
| We have tested the RM500U-CNV,RM520N-GL and EM05-E, and they are functioning properly. |
DC12V5A Power supply
BANANAPI Official Shop: https://www.bpi-shop.com/products/12v-5a-dc-power-supply.html
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=997917397351
BANANAPI Official Shop: https://www.bpi-shop.com/products/heatsinkforbpi-r4-be14wifi7module.html
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=1001800602243
SINOVOIP Aliexpress shop: https://ko.aliexpress.com/item/1005010546232366.html?gatewayAdapt=glo2kor
BIPAI Aliexpress shop: https://ko.aliexpress.com/item/1005010546392135.html?gatewayAdapt=glo2kor
BANANAPI Official Shop: https://www.bpi-shop.com/products/heatsinkforbpi-r4-be14wifi7module-1.html
Taobao shop: https://item.taobao.com/item.htm?ft=t&id=1007793450932
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/1005010661287648.html
BIPAI Aliexpress shop: https://pl.aliexpress.com/item/1005010661345515.html?gatewayAdapt=glo2pol
ASIA.RF AW7916-NPD: WiFi6E 3000 802.11ax G-band 2T2R and A-band 3T3R 2ss Dual Bands Dual Concurrents mPCIe Card AW7916-NPD
SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/3256807036993487.html?
Bipai Aliexpress shop: https://www.aliexpress.com/item/3256807036822902.html?spm=a2g0s.12269583.0.0.48df6c94TX2ucP
Taobao Shop: https://item.taobao.com/item.htm?spm=a1z09.8149145.0.0.30842c5aZcYzQx&id=808224556483&_u=cak7ln9381e
| BPI-Pro(8x) source code on github: https://github.com/BPI-SINOVOIP/BPI-R4PRO-8X-OPENWRT-V24.10.0-Master-Devel |
| BPI-Pro(4E) source code on github: https://github.com/BPI-SINOVOIP/BPI-R4PRO-4E-OPENWRT-V24.10.0-Master-Devel |
| BPI-R4Pro-V1p0_Assembly |
Baidu Cloud: https://pan.baidu.com/s/1ix8wILBORD-GJtnKWFVm-Q (PIN Code: 8888)
| BPI-R4 PRO Schematic |
Baidu Cloud: https://pan.baidu.com/s/1IrZcV_2Vtx3LO_AKpMOtCA (PIN Code: 8888)
| BPI-R4 PRO DXF file: |
Baidu Cloud: https://pan.baidu.com/s/1H-1wZXx1EKgN6mTe221YyQ (PIN Code: 8888)
| BPI-R4 PRO 3D File |
Baidu Cloud: https://pan.baidu.com/s/1dsTm5ya5JMWvzOjhj0B5Qg (PIN Code: 8888)
| MT7988A Wi-Fi7 Datasheet&Manual |
Baidu Cloud: https://pan.baidu.com/s/1-eSVD4DhyPAkfgrE9BtLmA?pwd=8888 PIN code:8888
| Kernel [PATCH net-next 8/8] net: ethernet: mtk_eth_soc: add basic support for MT7988 SoC: https://www.spinics.net/lists/kernel/msg4821673.html |
| [PATCH 15/15] dt-bindings: net: dsa: mediatek,mt7530: add mediatek,mt7988-switch: https://lore.kernel.org/lkml/80a853f182eac24735338f3c1f505e5f580053ca.1680180959.git.daniel@makrotopia.org/ |
| Discuss on forum : https://forum.banana-pi.org/t/banana-pi-bpi-r4-wifi-7-router-board-with-mediatek-mt7988a-filogic-880-4g-ram-and-8g-emmc/15757 |
| MediaTek Filogic 880 platform : https://www.mediatek.com/products/broadband-wifi/mediatek-filogic-880 |
| Key advantages of Wi-Fi 7 : https://mediatek-marketing.files.svdcdn.com/production/documents/Key-Advantages-of-Wi-Fi-7_MediaTek-White-Paper-WF70222.pdf |
| How MLO Smart Link Dispatching drives Wi-Fi 7: https://mediatek-marketing.files.svdcdn.com/production/documents/MLO-Infographic-How-Smart-Link-Dispatching-drives-Wi-Fi-7-White-Paper-Infographic-0223.pdf |
| MLO in Wi-Fi 7: https://mediatek-marketing.files.svdcdn.com/production/documents/Wi-Fi-7-MLO-White-Paper-WF7MLOWP0622.pdf |
| Banana Pi BPI-R4-NIC-BE14: https://wikidevi.wi-cat.ru/Banana_Pi_BPI-R4-NIC-BE14 |
| Some network ports on the 8X and 4E models have a combo relationship; only one port in a combo can be used at a time. When one port is in use, the other will become unusable. On the 4E model, the combo ports need to be switched in U-Boot, while on the 8X model, the combo ports will switch automatically depending on the connected network port.For instructions on switching the 4E combo network port, please refer to this. |
| BPI-R4Pro-8X-BE14-MT76-OpenWRT24.10-DSA-251229 |
1. Added support for 4G/5G cellular modules (Quectel RM500U,RM520N-GL and EM05) 2. Added MLD configuration (configuration is not available via the web,it can only be done via SSH) 3. Added support for 1000BASE-T and 2.5GBASE-T for 10G RJ45 WAN/LAN |
Baidu : https://pan.baidu.com/s/15oDSZpSMqhSY1x5hPW9oUw?pwd=8888 (pincode: 8888)
| BPI-R4Pro-8X-BE14-MT76-OpenWRT24.10-DSA-251125 |
| This image does not support 5G Cellular modules and 10G RJ45 WAN/LAN only supports 10GBASE-T. |
Baidu Could: https://pan.baidu.com/s/1_h0JLKi-Bms7pLfGfLX1EA?pwd=8888 (pincode: 8888)
| This image uses the RJ45 WAN port by default. If you need to switch the network port, please see gettingstart. |
| BPI-R4Pro-4E-BE14-MT76-OpenWRT24.10-260325 |
baidu: https://pan.baidu.com/s/1ua5rsYfvhIsRWIck5JAq-w?pwd=8888 (pincode: 8888)
| mxl862xxc_1030_1085_1085_0069_signed_xfi_upgrade_fca |
Baidu: https://pan.baidu.com/s/1dgXbMNBZUGYdJ9GgM0ZB4g?pwd=8888 code: 8888
| BANANAPI BPI-R4 PRO Router |
BANANAPI Official Shop: https://www.bpi-shop.com/products/bpi-r4-pro-complete-assembly-package.html
SINOVOIP Aliexpress Shop: https://ko.aliexpress.com/item/1005012389250920.html?gatewayAdapt=glo2kor
BIPAI Aliexpress Shop: https://www.aliexpress.com/item/1005012390280978.html
Taobao Shop: https://item.taobao.com/item.htm?ft=t&id=1055796676944
| BANANAPI BPI-R4 PRO PCBA |
BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-r4pro-router-board-mediatek-mt7988a.html
SINOVOIP Aliexpress shop: https://ko.aliexpress.com/item/1005010368570175.html?gatewayAdapt=glo2kor
Bipai Aliexpress shop: https://es.aliexpress.com/item/1005010368718643.html?gatewayAdapt=glo2esp
Taobao Shop: https://item.taobao.com/item.htm?ft=t&id=994935368405
