| More Infomation: Banana Pi BPI-R3_Mini |
MediaTek MT7986A(Filogic 830) Quad core ARM Cortex A53
Wifi 6 2.4G/5G(MT7976C)
2G DDR RAM
8G eMMC flash
128MB Nand flash
2x 2.5GbE Ethernet port
1x M.2 Key B USB inerface
1x M.2 KEY M PCIe inerface
1x USB2.0 interface
Prepare USB-Serial interface
Using your USB-Serial Connect debug console on BPI-R3 MINI
Debug Uart 3.3v TTL,Baud: 115200.
Default IP address for LAN port: 192.168.1.1
User name/password: pi/bananapi ,root/bananapi.
WIFI: Operwrt
R3mini boot switch Jumper Setting
| Note: EMMC Boot or Nand boot Support. |
| Note: Because BPI-R3 MINI can’t support that it boot from SD, So the factory will flash one default image into Nand and EMMC Device. Anytime please confirm that one EMMC or Nand device include one bootable image, it’s very important!! |
If you want to update EMMC device, please boot from Nand
Otherwise you update Nand device when it boot from EMMC.
| Note: when you want to Update EMMC device, Firstly Change boot switch to boot from Nand device, then after boot up,you need flash one emmc image into EMMC device. Finally you change bootstrap to boot from EMMC. |
Before burning image to eMMC, please prepare a USB disk. Let’s take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc-r3mini.img) for example, the steps are below:
Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk.
Change boot switch Jumper, the board boot from Nand device, then power up the board.
Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically)
mount -t vfat /dev/sda1 /mnt
change your directory to the mounting point, here is :
cd /mnt
Execute following command to enable and copy image to EMMC device:
echo 0 > /sys/block/mmcblk0boot0/force_ro
dd if=bl2_emmc-r3mini.img of=/dev/mmcblk0boot0
dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0
mmc bootpart enable 1 1 /dev/mmcblk0
Power off R3MINI board, unplug the USB drive, and change the boot program to boot from the emmc device.
| Note: Enable EMMC device, boot strap is from EMMC. |
| Note: when you want to Update Nand device, Firstly Change boot switch to boot from EMMC device, then after boot up,you need flash one nand image into nand device. Finally you change bootstrap to boot from Nand device. |
Before burning image into Nand, please prepare a USB disk. Let’s take OpenWrt image (mtk-bpi-r3mini-NAND-20230719-single-image.bin) for example, the steps are below:
Copy Nand boot OpenWrt image(mtk-bpi-r3mini-NAND-20230719-single-image.bin) to USB disk.
Change boot switch Jumper, the board boot from EMMC device, then power up the board.
cd /mnt
Execute following command to erase the whole Nand flash and copy image to nand device:
mtd erase /dev/mtd0
dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
Power off BPI-R3 MINI board, remove u-disk driver, change bootstrap to boot from Nand device.
| Note: Enable Nand device, boot strap is from Nand. |
After you finish burning emmc, switch to emmc boot, but the serial port keeps outputting jffs2 errors. You can use the following method to solve it.
First, switch back to NAND boot. Execute the following command to write zero to emmc.
dd if=/dev/zero of=/dev/mmcblk0
Then re-burn the emmc according to the document.
Network-Configuration refer to: http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:network:start
Network Interface: eth1 is for WAN; eth0, rax0, ra0 is for LAN, ra0 is for 2.4G wireless, rax0 is for 5G wireless.
root@OpenWrt:/# ifconfig
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:2418 (2.3 KiB)
RX bytes:0 (0.0 B) TX bytes:8538 (8.3 KiB)
RX bytes:0 (0.0 B) TX bytes:4408 (4.3 KiB)
Interrupt:124
RX bytes:0 (0.0 B) TX bytes:8674 (8.4 KiB)
Interrupt:124
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:6
2.5G Ethernet:
R3miniA(WAN)--- |
2.5G wwitch |
---Ethernet |
R3miniB(WAN)--- |
R3miniA ←------iperf3-----→ R3miniB |
R3miniA(WAN)--- |
2.5G wwitch |
---Ethernet |
R3miniC(WAN)---(LAN)R3miniB(WAN)--- |
R3miniC ←------iperf3-----→ R3miniA |
5GWi-Fi:
iPhone 5Gwifi ←------iperf3-----→ (Wi-Fi) BPI-R3mini
| Note: The distance between iPhone and R3mini is about one meter. |
You can change its configuration in the system’s /etc/config/wireless directory.
config wifi-device 'radio0'
option type 'mac80211'
option path 'platform/18000000.wbsys'
option channel '1'
option band '2g'
option htmode 'HE20'
option cell_density '0'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option encryption 'none'
option ssid 'OpenWrt-2.4G'
config wifi-device 'radio1'
option path 'platform/18000000.wbsys+1'
option channel '36'
option band '5g'
option htmode 'HE80'
config wifi-iface 'default_radio1'
option device 'radio1'
option mode 'ap'
option ssid 'OpenWrt-5G'
You can set it up via the web.the WiFi setup interfaces differ between the two official websites.
| If MTK is listed in the section, then the WiFi settings interface will be the one within MTK. |
The first method involves using the Wireless interface within the Network settings. You’ll see the corresponding 2.4G and 5G WiFi connections, with an Edit button on the right for configuration.
Setting Mode
Set encryption (set password)
The second method involves configuring WiFi within the MTK settings.
There is a config button on the right.
echo xxx > /sys/class/gpio/export
echo in/out > /sys/class/gpio/gpioxxx/direction
echo 0/1 > /sys/class/gpio/gpioxxx/value
echo 433(22+411) > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio433/direction
echo 1 > /sys/class/gpio/gpio433/value
echo 0 > /sys/class/pwm/pwmchip0/export
echo 10000 > /sys/class/pwm/pwmchip0/pwm0/period
echo 5000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle
echo normal > /sys/class/pwm/pwmchip0/pwm0/polarity
echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable
Currently, M.2 KEY B slot only support USB 4G/5G module, example: Quectel RM500U-CN or RM520N-GL
when you install one 4G/5G module, you may check it.
BPI-R3mini supports M.2 KEYB USB interface Cellular network module: 4G LTE EM05, 5G Quectel RM500U-CN/RG200U-CN and RM520N-GL/RM500Q-GL Series.
The released image(2023-09-12 or later) default driver is RM500U-CN and RM520N-GL, Install one of these two modules and you can use it directly.
If use EM05 or others,you will most likely need to modify the driver.
Install 4G/5G Cellular Module into CN4 Slot(M.2 KEYB)
Inset the NANOSIM Card
Install antenna on the module
After powering on, it will automatically dial
| Note: The availability of 4G/5G depends on the local carrier frequency band. |
RM520N-GL
wwan0 Link encap:Ethernet HWaddr C2:CA:76:42:83:EC
NOARP MTU:1500 Metric:1
wwan0_1 Link encap:Ethernet HWaddr C2:CA:76:42:83:EC
root@OpenWrt:/#
root@OpenWrt:/# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.188 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 2c7c:0801 Quectel RM520N-GL
Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.188 xhci-hcd xHCI Host Controller
root@OpenWrt:/#
root@OpenWrt:/# ping ping baidu .com
PING baidu.com (110.242.68.66) 56 data bvtes
64 bytes from 110.242.68.66: seq=0 ttl=50 time=38.540 ms
64 bytes from 110.242.68.66: seq=1 ttl=50 time=38.276 ms
64 bytes from 110.242.68.66: seq=2 ttl=50 time=38.355 ms
64 bytes from 110.242.68.66: seq=3 ttl=50 time=38.788 ms
^C
--- baidu.com ping statistics ---
4 packets transmitted, 4 received,0% packet loss
round-trip min/avg/max = 38.276/38.490/38.788 ms
root@OpenWrt:/#
RM500U-CN
usb0 Link encap:Ethernet HWaddr 46:F7:1B:36:AE:26
inet addr:10.101.26.65 Bcast:10.101.26.255 Mask:255.255.255.0
inet6 addr: 2409:895a:30a9:55e2:44f7:1bff:fe36:ae26/64 Scope:Global
inet6 addr: fe80::5c3b:9cff:fe76:7c46/64 Scope:Link
RX packets:191 errors:0 dropped:2 overruns:0 frame:0
TX packets:243 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:71800 (70.1 KiB) TX bytes:35923 (35.0 KiB)
root@R3mini-Router:/#
root@R3mini-Router:/# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.171 xhci-hcd xHCI Host Controller
Bus 002 Device 002: ID 2c7c:0900 RM500U-CN
Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.171 xhci-hcd xHCI Host Controller
ra0 is MT7986a 2.4G wifi
rax0 is MT7986a 5G wifi
Because the UART0_TXD of the debug port is also a wifi strap pin, this pin needs to be pull-low when poweron,
some serial cable have strong pull-up, such as PL2303,if it is inserted before powering on, it will cause the wifi chip to be recognized incorrectly, and the wifi function will fail.
Other types including cp2102,ch340 and FDTI are all available, serial cable power domian must be 3.3v TTL standard.
You can buy the serial cable here: https://www.aliexpress.us/item/3256805457599756.html
If your computer has a USB TypeC connector and supports PD12V/1.5A (20W) or above, you can also directly use the computer to power BPI-R3mini.
Moreover, since BPI-R3mini has built-in USB to serial port chip CH340E, you do not need to use additional serial cables.
| NOTE: If your computer does not support USB PD, then the R3mini will most likely keep restarting. |
Because the power consumption of R3mini is relatively large (all peripherals are plugged in and the power consumption is close to 20W when running)
Source code address: https://github.com/BPI-SINOVOIP/BPI-R3MINI-OPENWRT-V21.02.3
NAND-generated image name: openwrt-mediatek-mt7986-BPI-R3MINI-NAND-squashfs-sysupgrade.bin
NAND image Generate path:BPI-R3MINI-OPENWRT-V21.02.3/bin/targets/mediatek/mt7986
EMMC-generated image name: mtk-bpi-r3mini-EMMC.img
EMMC image Generate path:BPI-R3MINI-OPENWRT-V21.02.3/build_dir/target-aarch64_cortex-a53_musl/linux-mediatek_mt7986
NAND burn :
You can flash the program using Xmodem by selecting "upgrading single image" in the uboot menu.
| You can refer to the EMMC programming method: https://docs.banana-pi.org/en/BPI-R3_Mini/GettingStarted_BPI-R3_Mini#_install_image_to_onboard_emmc |
MT7986a Reference Manual for Develope Board(BPi)
The debug uart is 3.3V TTL power domain.
