BPI-RT2 Wifi 6 Router use Realtek RTL8198D design. It is a high performance wireless router for small and micro businesses, homes and other networking environments.
BPI-RT2 Router dual-band wireless router, 2.4G 2T2R, 5G 2T2R coexist at the same time. The use of four omni-directional high-gain antennas, with strong signal penetration and wider coverage, which makes the already strong signal more powerful, data transmission is also smoother. MU-MIMO multi-device transceiver technology has low latency and multiple devices are stably connected simultaneously, thus ensuring a good experience for multiple devices.
The Realtek RTL8198D is a highly integrated system-on-chip (SoC) designed for high-performance networking devices. It integrates a dual-core CPU, a hardware switching engine, multi-port Gigabit Ethernet PHY transceivers, and comprehensive network protocol processing acceleration functions, making it an ideal core solution for building enterprise-grade gateways, smart routers, and network switching equipment. The RTL8198D integrates four Gigabit Ethernet physical layer transceivers for 10Base-T, 100Base-TX, and 1000Base-TX, and two HSGMII interfaces to operate with an external phy
The RTL8198D Dual core MIPS interAptivTM CPU
256MB DDR3(embedded with the RTL8198D)
128MB SPI-NAND Flash
1 x 1 G RJ45 WAN
3 x 1 G RJ45 LAN
1x UART Debug
1x USB 3.0 slot
Gigabit enterprise gateways
VPN routers
smart Wi-Fi APs
integrated access devices
other embedded systems requiring high-performance network processing and VoIP functionality.
| HardWare Specification of Banana Pi BPI-RT2 | |
CPU |
RTL8198D Dual core MIPS interAptivTM CPU |
SDRAM |
256MB DDR3(embedded with the RTL8198D) |
On board Storage |
128MB SPI-NAND Flash |
On board Network |
4 Port 10/100/1000Mbps Ethernet |
Wifi 6 |
RTL8832 and RTL8192 Wifi6 support |
USB |
1x USB 3.0 TypeA |
Buttons |
Reset button,WPS Key, boot switch |
Leds |
Power status Led and RJ45 Led |
DC Power |
12V/2A |
Sizes |
97mm x 65mm |
Weight |
250g |
| BPI-RT2 OpenWRT 22.03 BSP on Github: https://github.com/BPI-SINOVOIP/BPI-RT2/ |
| BPI-RT2 SCH |
| BPI-RT2 DXF |
| 20260519-RT2-openwrt22.03-upgrade |
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-rt2ax3000router-design-with-realtek-rtl8198d.html |
| SINOVOIP Aliexpress shop: https://ko.aliexpress.com/item/1005013469839126.html?gatewayAdapt=glo2kor |
| Bipai Aliexpress shop: https://ko.aliexpress.com/item/1005013470815236.html?gatewayAdapt=glo2kor |
| BPI OpenSource Aliexpress shop: https://fr.aliexpress.com/item/1005013484142419.html?gatewayAdapt=glo2fra |
| JOOM Platform: https://www.joom.com/products/6adaf8a1afa4a801df45277c |
| OEM & ODM : [email protected] |
