The Banana Pi BPI-W2 is a router based development board, which can run on a variety of open source operating systems including OpenWrt, Android, and linux. It has 1 Gigabit LAN ports, 1 Gigabit WAN. it design with Realtek RTD1296, Quad-core ARM Cortex-A53. with 2G DDR4 and 8G eMMC flash onboard.
Mali T820 MP3 GPU
2G DDR4 SDRAM
8G eMMC flash
Mini PCIE 2.0 , 1.1 interface ,SDIO,M.2 intereface
MicroSD slot supports up to 256GB expansion
2xMIC in/Audio out
2 SATA interface
1XGigabit LAN 1x Gigabit WAN
1xUSB 3.0 2xUSB 2.0
HDMI in & HDMI out
Mini DP
TYPE C
the inner and outer diameter of the power plug adapter datasheet: https://drive.google.com/file/d/1k3AWmYOs2XE7lnRxCyytZu0Vpq_Bzcu_/view?usp=sharing
| HardWare Specification of Banana Pi W2 | |
Soc |
Realtek RTD1296 quad-core ARM A53 |
GPU |
Mali T820 MP3 GPU |
SDRAM |
2GB DDR4 \(shared with GPU\) |
Power |
12V @ 2A via DC power 5.0mmx2.0mm jack |
Low-level peripherals |
40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. |
Onboard Network |
2x 10/100/1000Mbps Ethernet |
Wifi/Bluetooth |
Option,not support onboard WIFI |
RGMII |
1 RGMII interface with PIN |
On board Storage |
MicroSD \(TF\) card; 2 native SATA 3 6Gbps ;eMMC;SIM card slot |
Display |
HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP |
Video decoder/encode |
The Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on. |
Aideo decoding |
Audio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing |
Audio |
support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in |
HDMI Out/In |
1* HDMI 2.0a out port and 1* HDMI 2.0a In port |
Audio outputs/Inputs |
HDMI, I2S audio,Audio micro out, Audio out/in with PIN define |
M.2 KEY E:PCIE 2.0/USB 2.0 |
1 pcie 2.0 interface |
M.2 KEY E:PCIe 1.1 / SDIO / USB 2.0 |
1 pcie 1.1 and SDIO interface |
USB 3.0 |
1x USB 3.0 host |
USB 2.0 |
2x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN |
M.2 KEY B |
1 * M.2 interface USB 2.0 for 4G with Micro SIM card slot |
Mini DP |
1* Mini DP |
TYPE C |
1 type C interface |
RTC battery |
RTC battery power interface |
Buttons |
Reset button, Power button, U-boot button |
Leds |
Red, Green, Blue |
Other |
IR reciever |
Sizes |
148 mm × 100.5mm |
Weight |
100g |
| 40 PIN GPIO of Banana pi BPI-W2 | ||
GPIO Pin Name |
Default Function |
Function 2:GPIO |
CON1-P01 |
VCC-3V3 |
CON1-P02 |
5VD |
CON1-P03 |
I2C5\_SCL |
GPIO13 |
CON1-P04 |
5VD |
CON1-P05 |
I2C5\_SDA |
GPIO14 |
CON1-P06 |
GND |
CON1-P07 |
PWM0\_0 |
IGPIO21 |
CON1-P08 |
UR2\_TX |
IGPIO3 |
CON1-P09 |
GND |
CON1-P10 |
UR2\_RX |
IGPIO2 |
CON1-P11 |
GPIO17 |
GPIO17 |
CON1-P12 |
AO\_BCK |
GPIO58 |
CON1-P13 |
I2C3\_SDA |
GPIO25 |
CON1-P14 |
GND |
CON1-P15 |
I2C3\_SCL |
GPIO27 |
CON1-P16 |
UR2\_RTS |
IGPIO5 |
CON1-P17 |
VCC-3V3 |
CON1-P18 |
UR2\_CTS |
IGPIO4 |
CON1-P19 |
G\_MOSI |
GPIO7 |
CON1-P20 |
GND |
CON1-P21 |
G\_MISO |
GPIO4 |
CON1-P22 |
IR\_TX |
IGPIO9 |
CON1-P23 |
G\_SCK |
GPIO5 |
CON1-P24 |
G\_CS |
GPIO6 |
CON1-P25 |
GND |
CON1-P26 |
GPIO8 |
GPIO8 |
CON1-P27 |
I2C4\_SDA |
GPIO12 |
CON1-P28 |
I2C4\_SCL |
GPIO11 |
CON1-P29 |
GPIO100 |
GPIO100 |
CON1-P30 |
GND |
CON1-P31 |
AI\_CK |
GPIO21 |
CON1-P32 |
SPDIF |
GPIO54 |
CON1-P33 |
AO\_CK |
GPIO59 |
CON1-P34 |
GND |
CON1-P35 |
AO\_LRCK |
GPIO57 |
CON1-P36 |
AI\_BCK |
GPIO22 |
CON1-P37 |
AI\_LRCK |
GPIO23 |
CON1-P38 |
AI\_SDO |
GPIO24 |
CON1-P39 |
GND |
CON1-P40 |
AO\_D0 |
GPIO60 |
CON2-P1 |
GND |
CON2-P2 |
UART0-RX |
CON2-P3 |
UART0-TX |
voltage domain is RGMII.
| Linux 4.9.x Source code on github: https://github.com/BPI-SINOVOIP/BPI-W2-bsp |
| HDMI-IN sample code: https://drive.google.com/open?id=17RXX_-mrZh2N6NgyVY6ofKs-NNC48bAM |
| BPI-W2 Android 7 source code : https://github.com/BPI-SINOVOIP/BPI-1296-Android7 |
| BPI-W2 Android 6 source code : https://github.com/BPI-SINOVOIP/BPI-1296-Android6 |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| BPI-W2 hardware schematic diagram : |
Baidu cloud: https://pan.baidu.com/s/1z2FgGpWY4nPGvocx8ymmew pinecode: r5tv
| BPI-W2 DXF file download : https://drive.google.com/file/d/1JDVRxcXdSi8cnX32plBmyrTiKiWDK_ev/view?usp=sharing |
| BPI-W2 Realtek 1296 documents download link |
Baidu cloud : https://pan.baidu.com/s/1geV5JNl
| SATA-RSM-C052-X22XX spec |
| Banana Pi BPI-W2 play video with openwrt (kernel 4.9.119): https://www.youtube.com/watch?v=ZQxxMRzK84Q&feature=youtu.be |
| Banana Pi BPI-W2 passed Amazon AWS Greengrass: https://devices.amazonaws.com/detail/a3G0h000000OvNJEA0/Banana-Pi-BPI-W2 |
| 2020-07-23 update |
Android 7.1, kernel 4.1
Android Normal Version: Normal android image without hwnat and openwrt enabled
Android Router Version: Router mode android image with hwnat and openwrt enabled, ethernet and wifi network must be configured in Openwrt system(Settings→More→Openwrt Settings). The port with bar code label is wan port and br-lan ip is 172.16.1.1.
Android ATV version: ATV version android image without hwnat and openwrt enabled. Click the right button to show the navigation bar If you use mouse for testing.
Android 6.0, kernel 4.1
Android 6.0 image is only support normal android build without second ethernet port enabled. Android 6.0 is no longer maintained and this is the final release.
| 2019-8-16 update This release is for banana pi W2 board, and it is based on Android6.0 & 7.1 Operation system with kernel 4.1 |
Android 6.0
Baidu Drive : https://pan.baidu.com/s/1ZdI4Y7B-u7kp8XguGXFkuQ (PinCode:8noz)
MD5 : 1a90335d798863e31f99c1fae615c43c
Android 7.1
Baidu Drive : https://pan.baidu.com/s/12MkYp0oQ9cUN2N8J3WrHrg (PinCode:2cyy)
MD5 : 713ddd26e6f2c085c464442e058cf390
| 2019-01-14 update : BPI-W2 Android7 new image support google GMS |
Baidu drive: https://pan.baidu.com/s/1_aT1jJHrOJdeEeGa6J1EYA
| 2019-05-09 update, This release is for banana pi W2 board which is based on RTD1296, Android 6.0 Operation system with kernel 4.1.17. |
BPI-W2 Android 6.0 Features Map : http://newwiki.banana-pi.org/en/BPI-W2/W2_Image_Map#_android_6_0_hdmi
Baidu Drive : https://pan.baidu.com/s/13CNmfW5ZlSmzgrDLp6mptg (PinCode:m8qt)
MD5 : 30226f82f85b88b7c345affa202268eb
| 2019-6-18 update,This release is for banana pi M4 & W2 board, and it is based on Ubuntu Mate 18.04 & Ubuntu Server 16.04 Operation system with kernel 4.9.119. |
Baidu Drive : https://pan.baidu.com/s/1tB_QZ6zgmKiYstcZwn51gg (PinCode:edrc)
MD5 : 7409b48a46e0bbc2d0ae2e70a49bfb36
Baidu Drive : https://pan.baidu.com/s/1lkG6gyzn-KPbvrEhf6Q85w (PinCode:5jbo)
MD5 : 328706256bec238df50f9bd6ab8dfd1b
| Issue: if HDMI doesn’t display, please try "ctrl + alt + F1" to change terminal then "ctrl + alt + F7" change to desktop display. |
Forum pthread: http://forum.banana-pi.org/t/bpi-m4-demo-image-release-ubuntu-mate-18-04-ubuntu-server-16-04-2019-06-18/9362
| 2018-09-17 update.This release is for banana pi W2 board which is based on realtek RTD1296, and it is based on Ubuntu 18.04 operation system with kernel 4.9.119. |
W2 Features Map: http://newwiki.banana-pi.org/en/BPI-W2/W2_Image_Map
Baidu Drive: https://pan.baidu.com/s/1iLOa1MOgtSqY6dVsQ_SyQg
| 2019-08-13 update BPI-M4/BPI-W2 Debian10 Buster Desktop New Demo Image ,This release is for banana pi M4 and W2 board, and it is based on Debian 10 Operation system with kernel 4.9.Debian 10 buster desktop(32bit) |
Baidu Drive : https://pan.baidu.com/s/1WcrBkxm5OyBLedCBwaUz6Q (PinCode:e6m3)
MD5 : 300b37cdfa092d72dceddd4f33825b40
Forum Pthread: http://forum.banana-pi.org/t/bpi-m4-bpi-w2-debian10-buster-desktop-new-demo-image-20190813/9712
Issue: if HDMI doesn’t display, please try “ctrl + alt + F1” to change terminal then “ctrl + alt + F7” change to desktop display. SW2: switch to 0,if insert SD, SD start;if doesn’t insert SD,EMMC start. |
| 2019-08-06 update,BPI-M4/BPI-W2 Debian 10 Buster Lite Demo Image ,This release is for banana pi M4 and W2 board, and it is based on Debian 10 Operation system with kernel 4.9. |
Baidu Drive : https://pan.baidu.com/s/1CGxGUi8rt06tHwfk134Seg (Pincode:7rcz)
MD5 : 5a8b1eb36b782fdd742ba746c645593d
Debian 10 buster (32bit)
Baidu Drive : https://pan.baidu.com/s/1lTtcMTWqE0jG_1PWGtWSqw (Pincode:gny6)
MD5 : a59f2e6a298237a08bb523b53372d937
| 2018-09-18 update.This release is for banana pi W2 board which is based on realtek RTD1296, and it is based on Debian 9 operation system with kernel 4.9.119. |
W2 Features Map: http://newwiki.banana-pi.org/en/BPI-W2/W2_Image_Map#_debian_9
Baidu Drive: https://pan.baidu.com/s/1bmTektF0ufRL9_FOpdoO2w
| 2019-10-04 update Banana Pi BPI-W2 (RTD1296) new image : Openwrt Lede with Kernel 4.9 |
forum pthread : http://forum.banana-pi.org/t/banana-pi-bpi-w2-rtd1296-new-image-openwrt-lede-with-kernel-4-9/10013
| Image Link: Linux kernel 4.4 |
Baidu Drive: https://pan.baidu.com/s/1Rs9F46wNJibORaeCfVh4wg PinCode:1w4w
| 2019-6-19 update,This release is for banana pi M4 & W2 board, and it is based on Raspbian 9.8 stretch & AArch64 Linux Mate & AArch Linux Lite Operation system with kernel 4.9.119. |
Baidu Drive : https://pan.baidu.com/s/1gwD5ok9XLLQa0InU_-b7EA (PinCode:uuqn)
MD5 : a397a9c4d078c2841f0c243c573dc9a8
Issue: if HDMI doesn’t display, please try "ctrl + alt + F1" to change terminal then "ctrl + alt + F7" change to desktop display. SW2: switch to 0,if insert SD, SD start;if doesn’t insert SD,EMMC start. |
| 2018-09-17 uptate ,This release is for banana pi W2 board which is based on realtek RTD1296, and it is based on Raspbian 9.4 operation system with kernel 4.9.119. |
BPI-W2 Features Map: http://newwiki.banana-pi.org/en/BPI-W2/W2_Image_Map#_raspbian_9_4
Baidu Drive: https://pan.baidu.com/s/1aL5ZsHIRwM-1rvnZDiR3EA
| 2019-6-19 update,This release is for banana pi M4 & W2 board, and it is based on AArch64 Linux Mate & AArch linux liteOperation system with kernel 4.9.119. |
Baidu Drive : https://pan.baidu.com/s/1GvGsfs7t018EoRIv-au1GA (PinCode:o496)
MD5 : d284b2326a36d2d9039fb8d7e20e2600
| AArch64 Linux Lite |
Baidu Drive : https://pan.baidu.com/s/1WivDWZHu_GnWOxhVOjoqIQ (PinCode:uhcg)
MD5 : 53bb6f8d00f8708dab96bc865eaddc5e
| 2018-09-25 uptate,This release is for banana pi W2 board which is based on realtek RTD1296, and it is based on OpenSUSE operation system with kernel 4.9.119. |
Baidu Drive: https://pan.baidu.com/s/1UZl-UFUugPhCPaFHBB9_GA
| 2018-09-25 update,This release is for banana pi W2 board which is based on realtek RTD1296, and it is based on Kali operation system with kernel 4.9.119. |
Baidu Drive: https://pan.baidu.com/s/1eslUG_xlHHsGwHk_Lq_bVw
| 2018-09-03 update :RPiTCv3_1.12-demo-bpi-w2-beta with Linux kernel 4.9.119 |
baidu cloud: https://pan.baidu.com/s/1sd9hoOwyfAxWlGroDMOj4A
more abot RPiTC : http://rpitc.blogspot.com/
Now we support to use bpi-copy to burn image to sd card, before this, we need to update our spi rom code, please watch the attachment to update your W2 spi rom code.
SPI ROM Tool:
Baidu Drive: https://pan.baidu.com/s/1017nmgw6ZVb5_NgLDz54HQ
SPI ROM Image:
Baidu Drive: https://pan.baidu.com/s/1rpfpWK8eoOdPhKwyWoR2Tw
How-To Update W2 SPI ROM:
Baidu Drive: https://pan.baidu.com/s/1CZdY_4yFk5r5MSxoog9uOg
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-w2.html |
| BPI Aliexpress shop: https://www.aliexpress.com/item/1005004574856719.html |
| SINOVOIP Aliexpress shop: https://www.aliexpress.com/item/32862157238.html |
| Taobao shop: https://item.taobao.com/item.htm?id=567700943779 |
| OEM&ODM, please contact: [email protected] |
