| More Infomation: Banana Pi BPI-W2 |
Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System
Using your USB-Serial Connect debug console on W2
| Rx and Tx need to be connected in reverse, so TTL lines are connected in black, green, and white order. |
BPI-W2 USB flash tool is a usb download tool for flashing android image to board emmc, and only support Windows platform.
Make sure SW4 switch to '0' for emmc boot.
| There is a document description in the doc folder. |
After launching rtumdfsample.exe, you can see the window shown in above figure. Please:
Choose flash type. (EMMC)
Select DDR type.
Open file, choose an install image file
Press and hold the usb button beside SW4 and connect board to PC with USB cable at the same time, If connected like the following figure1, release usb button and click the green robot icon, the tool will start to burn-in.
Burner has the icon to indicate status
Burner has recognized the target board, and read to burn.
The board has finished the burning process.
During the burning process will be show icon
Burn install.img to target but fail, the debug log will save to log\error_log
If you are already load install.img with step3, you could click ‘reload img’ to use previous setting in current burn-in process. (green frame)
Linux image support SDcard or EMMC bootup
It’s recommended to use A1 rated cards, 8GB at least.
M2 Ultra and M2 Berry are compatiable with same Linux image.
Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can’t access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
$ apt-get install pv
Download latest Linux Image, and confirm that the md5 checksum is correct.
Default login: pi/bananapi or root/bananapi
Make sure SW4 switch to '1' for SD boot.
Windows PC
Install Image with Balena Etcher.
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
Linux PC
There are two methods for you to choose from.
Install Image with dd command on Linux, umount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
sudo apt-get install pv unzip
sudo unzip -p xxx-bpi-w2-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
Install image with bpi-tools on Linux, plug SDcard to Linux PC and run
sudo bpi-copy xxx-bpi-w2-xxx.img.zip /dev/sdX
Prepare a SDcard with Linux image flashed and bootup board with this SDcard.
Unzip the image and copy it to a USB drive, plug the udisk to board and mount it.(If automatically mounted, ignore this step)
mount /dev/sdx /mnt
There are two ways to install the linux image to board.
Install with dd command.
sudo dd if=/mnt/xxx.bpi-w2-xxx.img of=/dev/mmcblk0 bs=10M status=noxfer
Install the linux image in udisk with bpi-tools command
sudo bpi-copy xxx-bpi-w2-xxx.img.zip /dev/mmcblk0
After download complete, power off safely and eject the SDcard.
Mount dev on W2
After insert sata interface, execute
fdisk -l
mount /dev/sdx /mnt/xxx
If you meet some errors when you mount SATA, try these following commands:
Create new partition
fdisk /dev/sdx
set your partition numbers and size, after created partitions, input "wq" to save and quit.
Format the SATA
mkfs.ext2 /dev/sdx
Mount sata
After you success to insert SATA, we could input following commands to test SATA interface:
Test read speed
time dd if=/dev/xxx of=/dev/null bs=1M count=1000
Test write speed
time dd if=/dev/zero of=/dev/sdx bs=1M count=1000
Test read speed
Test write speed
iperf3 -c [server]
iperf3 -u -c [server]
iperf3 -s
Use commands to setup WiFi client
ip link set wlan0 up
iw dev wlan0 scan | grep SSID
vim /etc/wpa_supplicant/wpa_supplicant.conf
network={
ssid="ssid"
psk="password"
priority=1
wpa_supplicant -iwlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
dhclient wlan0
Use UI interface to setup WiFi Client
Start OpenGL test
glmark2-es
glmark2 Score: 30
