| More Infomation:Banana Pi BPI-WiFi5 Router |
Ethernet cable
BPI-WiFi5
12V power supply
Download the image you want to upgrade.
Power on the BPI-WiFi5 and connect it to your computer using an Ethernet cable.
Open the web interface in your browser,and enter the password:
default IP: 192.168.4.1
Password: admin
Select “More"
Select “System", then select "Backup/Upgrade".
Select “Flash image…".
Select the image you want to upgrade, and then click "OK" to upload.
Uncheck "Keep settings and retain the current configuration".Select "Continue".
Wait a few minutes, after the upgrade is completed, it will automatically restart and the web page will automatically refresh.
Ethernet cable
BPI-WiFi5
12V power supply
USB to TTL cable
Connect the BPI-WiFi5 to your computer using an Ethernet cable.
Set the computer’s IP to 192.168.4.100, as shown in the image below.
Connect to the computer using a USB to TTL cable and open a serial terminal tool.
Power on the BPI-WiFi5.
Press any key during startup to enter the U-Boot terminal.
Type httpd 192.168.4.1 and press Enter.
Open a browser, type the address 192.168.4.1, and access it.
Click "Browse" to select the image file and Click "Update firmware" to upload it.
Wait for the update to complete, which is expected to take about 2 minutes.
Ethernet cable
BPI-WiFi5
12V power supply
Ubuntu18.04
Install the required dependencies:
sudo apt install make gcc g++ device-tree-compiler bc libncurses-dev perl-modules-5.26 patch gawk unzip python git
Get source code
git clone https://github.com/BPI-SINOVOIP/BPI-WiFi5-Siflower
cd ./BPI-WiFi5-Siflower/uboot
./make.sh sfa28_ac28
cd ./BPI-WiFi5-Siflower/openwrt-18.06
#If you want to compile the luci interface
./make.sh a28_bpi
#If you want to compile the luci2 interface
./make.sh a28_bpi_luci2
After the compilation is complete, a bin file will appear in the current directory. This is the firmware you have compiled.
Ethernet cable
BPI-WiFi5
12V power supply
You’ll need the BPI-WiFi5 source code and a new image the size of the original logo on your PC.
First get the source code and compile uboot.
Add the logo image to the source project under /openwrt-18.06/feeds/xluci2/luci2-bpi/htdocs/luci2/res.
Make this change in the source project path file below(/home/qubot/bpi/siflower/wifi5-test/openwrt-18.06/feeds/xluci2/luci2-bpi/htdocs/luci2/css/siflower_icon.css):
/*siflower logo*/
.siflower_logo {
background-image: url('../res/bananapilogo1.png');
background-size: 100%;
The original source path".. /res/bananapilogo.png" replaced with the source path of the new logo".. /res/bananapilogo1.png". (.. /res/ "the name of the logo".png)
Compile kernel & OpenWrt and Upgrade Firmware.
The original logo:
after replacing the logo:
