Banana Pi BPI-CM2 is a computer module with Rockchip RK3568 Quad-core ARM Cortex-A55 CPU, Mali-G52 1-Core-2EE GPU,2GB LPDDR4/LPDDR4x ,16G eMMC flash (Max 128G),Designed with Board to Board connectors for enhanced stability same as Raspberry Pi CM4 , which means that it should work with carrier boards designed for the Raspberry Pi CM4.
Rockchip RK3568 provides a wealth of interface resources. In addition to the board-to-board connectors compatible with the Raspberry PI, other interfaces are also drawn from the board-to-board interface, so that you can design your own base board and use of the rich interface resources of the RK3568.
Rockchip RK3568 design : Banana Pi BPI-R2 Pro Router board Rockchip RK3568 design : Banana Pi BPI-CM2 Computer module kit Rockchip RK3568 design : Banana Pi BPI-KVM PiKVM for KVM over IP |
Maker DIY
Internet service gateway
Robot control
Industrial control and industrial automation gateway
NAS device
Network and communication applications
2GB LPDDR4/LPDDR4x (Max 8G)
Support Android and Linux system.
| OEM&ODM please contact : [email protected] |
