Banana Pi BPI-R2 Pro is the next generation smart router developement board from Banana Pi in 2021. It is powered by Rockchip RK 3568 processor.Onboard 2GB LPDDR4 memory and 16GB eMMC storage, and supports 2 USB 3.0 interface, 5 gigabit network port. M.2 key-E and mini PCIe interface, 2 mipi DSI interface(one can change to LVDS by software), 1 CSI camera interface,1 HDMI output.
Rockchip RK3568 design : Banana Pi BPI-R2 Pro Router board Rockchip RK3568 design : Banana Pi BPI-CM2 Computer module kit Rockchip RK3568 design : Banana Pi BPI-KVM PiKVM for KVM over IP |
Banana Pi BPI-CM2 Computer module also design with Rockchip RK3568,if you want to customize your own products, you just need to develop baseboards based on BPI-CM2 and quickly mass produce your products based on RK3568 solution.
| BPI-R2 Pro same size as Banana Pi BPI-R2 , and interface is also same .so can use BPI-R2 case. |
Rockchip RK3568 Quad-core ARM Cortex-A55 CPU
Mali-G52 1-Core-2EE
2G LPDDR4 SDRAM (option 4G)
Mini PCIE interface and M.2 key-e interface
support 1 SATA interface
MicroSD slot supports up to 256GB expansion
16G eMMC flash (option 16/32/64G)
2 MIPI display interface support
5 port 10/100/1000 Mb Ethernet port
2 USB 3.0 and 1 USB 2.0 otg port
HardWare Specification of Banana Pi R2 Pro |
CPU |
Rockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz |
GPU |
Mali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0 |
Memory |
2G LPDDR4 SDRAM (option 4G) |
Storage |
Onboard 16GB eMMC Flash, Micro SD-Card slot, SATA 3.0 Port,SPI flash |
Network |
5 x 10/100/1000 Mbit/s Ethernet |
Display(s) |
1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software) |
Camera |
1 CSI camera interface |
Video decoder(s) |
H.265 HEVC/MVC Main10 Profile [email protected] up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps |
Video encoder(s) |
H.264/AVC BP/MP/[email protected],up to 1920x1080@100fps, H.265/HEVC [email protected], up to 1920x1080@100fps (4096x4096@10fps with TILE) |
Audio Output(s) |
HDMI & I2S & Speaker & Headphone |
USB port |
USB 3.0 PORT (x2), micro USB OTG (x1) |
mini PCIE |
1 mini pcie interface & 1 M.2 key-e interface |
Remote |
IR Receiver (x1) |
GPIO |
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). Some of I/O Pin can be used for specific functions as UART, I2C, SPI or PWM |
Switches |
Reset button, Power button, U-boot button |
LED |
Power Status and 8P8C |
Power Source |
12 volt @2A via DC Power and/or Micro USB (OTG) |
Size & Weight |
148 mm × 100.5mm 100g |
OS |
OpenWRT, Linux and others OS |
40 PIN GPIO of Banana pi BPI-R2 Pro |
GPIO Pin Name |
Default :GPIO |
Function2 |
Function3 |
CON2-P01 |
VCC3V3_SYS |
CON2-P02 |
VCC5V0_SYS |
CON2-P03 |
GPIO3_B4 |
I2C5_SDA_M0 |
CON2-P04 |
VCC5V0_SYS |
CON2-P05 |
GPIO3_B3 |
I2C5_SCL_M0 |
CON2-P06 |
GND |
CON2-P07 |
GPIO3_B5 |
PWM10_M0 |
CON2-P08 |
GPIO0_C1 |
UART0_TX |
CON2-P09 |
GND |
CON2-P10 |
GPIO0_C0 |
UART0_RX |
CON2-P11 |
GPIO3_C4 |
UART7_TX_M1 |
PWM14_M0 |
CON2-P12 |
GPIO3_A3 |
I2S3_SCLK_M0_BT |
CON2-P13 |
GPIO3_C5 |
UART7_RX_M1 |
SPDIF_TX1_M1 |
CON2-P14 |
GND |
CON2-P15 |
GPIO3_B6 |
PWM11_IR_M0 |
CON2-P16 |
GPIO0_C4 |
UART0_RTS |
CON2-P17 |
VCC3V3_SYS |
CON2-P18 |
GPIO0_C7 |
UART0_CTS |
CON2-P19 |
GPIO4_C3 |
SPI3_MOSI_M1 |
CAN1_TX |
CON2-P20 |
GND |
CON2-P21 |
GPIO4_C5 |
SPI3_MISO_M1 |
UART9_TX |
CON2-P22 |
GPIO4_C4 |
SPDIF_TX |
CON2-P23 |
GPIO4_C2 |
SPI3_CLK_M1 |
CAN1_RX |
CON2-P24 |
GPIO4_C6 |
SPI3_CS0_M1 |
UART9_RX |
CON2-P25 |
GND |
CON2-P26 |
GPIO3_C3 |
UART5_RX_M1 |
CON2-P27 |
GPIO1_A4 |
CON2-P28 |
GPIO3_C2 |
UART5_TX_M1 |
CON2-P29 |
GPIO1_B0 |
CON2-P30 |
GND |
CON2-P31 |
GPIO1_B1 |
CON2-P32 |
GPIO4_D2 |
CON2-P33 |
GPIO1_B2 |
CON2-P34 |
GND |
CON2-P35 |
GPIO3_A4 |
I2S3_LRCK_M0_BT |
CON2-P36 |
GPIO3_A2 |
I2S3_MCLK_M0 |
CON2-P37 |
GPIO2_D7 |
CON2-P38 |
GPIO3_A6 |
I2S3_SDI_M0_BT |
CON2-P39 |
GND |
CON2-P40 |
GPIO3_A5 |
I2S3_SDO_M0_BT |
CON3-P1 |
GND |
CON3-P2 |
UART0-RX |
CON3-P3 |
UART0-TX |
CSI Pin Name |
Default Function |
Function2:GPIO |
CN6-P01 |
GND |
CN6-P02 |
MIPI_CSI_D3N |
CN6-P03 |
MIPI_CSI_D3P |
CN6-P04 |
GND |
CN6-P05 |
MIPI_CSI_D2N |
CN6-P06 |
MIPI_CSI_D2P |
CN6-P07 |
GND |
CN6-P08 |
MIPI_CSI_CLK1N |
CN6-P09 |
MIPI_CSI_CLK1P |
CN6-P10 |
GND |
CN6-P11 |
MIPI_CSI_D1N |
CN6-P12 |
MIPI_CSI_D1P |
CN6-P13 |
GND |
CN6-P14 |
MIPI_CSI_D0N |
CN6-P15 |
MIPI_CSI_D0P |
CN6-P16 |
GND |
CN6-P17 |
MIPI_CSI_CLK0N |
CN6-P18 |
MIPI_CSI_CLK0P |
CN6-P19 |
NC/MIPI_CAM0_PDN |
CN6-P20 |
CAM0_CLKOUT |
CN6-P21 |
CAM0_IRCUT |
CN6-P22 |
I2C2_SCL_M1 |
CN6-P23 |
I2C2_SDA_M1 |
CN6-P24 |
CAM0_CSI_RST |
CN6-P25 |
VCC1V8_DOVDD |
CN6-P26 |
GND |
CN6-P27 |
GND |
CN6-P28 |
VCC33 |
CN6-P29 |
VCC33 |
CN6-P30 |
VCC33 |
DSI Pin Name |
Default Function |
Function2 |
CN8-P01 |
NC |
CN8-P02 |
VCC3V3_LCD0 |
CN8-P03 |
VCC3V3_LCD0 |
CN8-P04 |
GND |
CN8-P05 |
MIPI_LCD0_RST |
CN8-P06 |
SARADC_VIN5 |
CN8-P07 |
GND |
CN8-P08 |
MIPI_DSI_TX0_D0N |
LVDS_TX0_D0N |
CN8-P09 |
MIPI_DSI_TX0_D0P |
LVDS_TX0_D0P |
CN8-P10 |
GND |
CN8-P11 |
MIPI_DSI_TX0_D1N |
LVDS_TX0_D1N |
CN8-P12 |
MIPI_DSI_TX0_D1P |
LVDS_TX0_D1P |
CN8-P13 |
GND |
CN8-P14 |
MIPI_DSI_TX0_CLKN |
LVDS_TX0_CLKN |
CN8-P15 |
MIPI_DSI_TX0_CLKP |
LVDS_TX0_CLKP |
CN8-P16 |
GND |
CN8-P17 |
MIPI_DSI_TX0_D2N |
LVDS_TX0_D2N |
CN8-P18 |
MIPI_DSI_TX0_D2P |
LVDS_TX0_D2P |
CN8-P19 |
GND |
CN8-P20 |
MIPI_DSI_TX0_D3N |
LVDS_TX0_D3N |
CN8-P21 |
MIPI_DSI_TX0_D3P |
LVDS_TX0_D3P |
CN8-P22 |
GND |
CN8-P23 |
NC |
CN8-P24 |
NC |
CN8-P25 |
GND |
CN8-P26 |
LCD0_BL_PWM |
CN8-P27 |
MIPI0_LCM_PWMOUT |
CN8-P28 |
NC |
CN8-P29 |
NC |
CN8-P30 |
GND |
CN8-P31 |
LED0- |
CN8-P32 |
LED0- |
CN8-P33 |
NC |
CN8-P34 |
TP_INT_L_GPIO0_B5 |
CN8-P35 |
TP_RST_L_GPIO0_B6 |
CN8-P36 |
I2C1_SCL_TP |
CN8-P37 |
I2C1_SDA_TP |
CN8-P38 |
NC |
CN8-P39 |
LED0+ |
CN8-P40 |
LED0+ |
DSI Pin Name |
Default Function |
Function2 |
CN7-P01 |
NC |
CN7-P02 |
VCC3V3_LCD1 |
CN7-P03 |
VCC3V3_LCD1 |
CN7-P04 |
GND |
CN7-P05 |
MIPI_LCD1_RST |
CN7-P06 |
SARADC_VIN2 |
CN7-P07 |
GND |
CN7-P08 |
MIPI_DSI_TX1_D0N |
CN7-P09 |
MIPI_DSI_TX1_D0P |
CN7-P10 |
GND |
CN7-P11 |
MIPI_DSI_TX1_D1N |
CN7-P12 |
MIPI_DSI_TX1_D1P |
CN7-P13 |
GND |
CN7-P14 |
MIPI_DSI_TX1_CLKN |
CN7-P15 |
MIPI_DSI_TX1_CLKP |
CN7-P16 |
GND |
CN7-P17 |
MIPI_DSI_TX1_D2N |
CN7-P18 |
MIPI_DSI_TX1_D2P |
CN7-P19 |
GND |
CN7-P20 |
MIPI_DSI_TX1_D3N |
CN7-P21 |
MIPI_DSI_TX1_D3P |
CN7-P22 |
GND |
CN7-P23 |
NC |
CN7-P24 |
NC |
CN7-P25 |
GND |
CN7-P26 |
LCD1_BL_PWM |
CN7-P27 |
MIPI1_LCM_PWMOUT |
CN7-P28 |
NC |
CN7-P29 |
NC |
CN7-P30 |
GND |
CN7-P31 |
LED1- |
CN7-P32 |
LED1- |
CN7-P33 |
NC |
CN7-P34 |
TP_INT_L_GPIO0_B5 |
CN7-P35 |
TP_RST_L_GPIO0_B6 |
CN7-P36 |
I2C1_SCL_TP |
CN7-P37 |
I2C1_SDA_TP |
CN7-P38 |
NC |
CN7-P39 |
LED1+ |
CN7-P40 |
LED1+ |
DSI Pin Name |
Default Function |
Function2 |
CN9-P01 |
EDP_TX_AUXN |
CN9-P02 |
EDP_TX_AUXP |
CN9-P03 |
EDP_TX_D0P |
CN9-P04 |
EDP_TX_D0N |
CN9-P05 |
EDP_TX_D1P |
CN9-P06 |
EDP_TX_D1N |
CN9-P07 |
EDP_TX_D2P |
CN9-P08 |
EDP_TX_D2N |
CN9-P09 |
EDP_TX_D3P |
CN9-P10 |
EDP_TX_D3N |
CN9-P11 |
NC |
CN9-P12 |
NC |
CN9-P13 |
NC |
CN9-P14 |
NC |
CN9-P15 |
LCD1_RST |
CN9-P16 |
LCD1_BL_PWM |
CN9-P17 |
SARADC_VIN4 |
CN9-P18 |
VCC3V3_LCD1 |
CN9-P19 |
VCC3V3_LCD1 |
CN9-P20 |
GND |
CN9-P21 |
GND |
CN9-P22 |
GND |
CN9-P23 |
VCC12V_LCD1 |
CN9-P24 |
VCC12V_LCD1 |
Running on android11 system, connecting with 2x dsi panel + 1x eDP panel: https://www.youtube.com/watch?v=HpDAmNVDwXI
RK3568 custom board, industrial control board
| linux-4.19.xx kernel BSP Source code on github : https://github.com/BPI-SINOVOIP/BPI-R2PRO-BSP/ |
| Compilation environment: Ubuntu 18.04 64-bit host machine |
| linux-5.10.66 kernel BSP Source code on github : https://github.com/BPI-SINOVOIP/BPI-R2PRO-BSP-5.10.x/ |
BPI-R2 PRO Android11 Source Code : Baidu Cloud: https://pan.baidu.com/s/1c2vw-df4hh55VB3gSsM6Uw?pwd=8888 (Pincode: 8888) |
| Because of the Google security update some of the old links will not work if the images you want to use cannot be downloaded from the new link bpi-image Files |
| All banana pi docement(SCH file,DXF file,and doc) |
| BPI-R2 Pro schematic diagram : https://drive.google.com/file/d/1aDOL8U6-4bxn7iB_MzCOgHoDhUu0wuQu/view?usp=sharing |
| BPI-R2 Pro DXF file : https://drive.google.com/file/d/1N9AWJVHC4fZEko5_RIkc3pI0gK1I0XiV/view?usp=sharing |
| MT7531 switch chip datasheet: https://drive.google.com/file/d/1aVdQz3rbKWjkvdga8-LQ-VFXjmHR8yf9/view?usp=sharing |
| RTL8367RB-VB-CG Switch chip datasheet: https://drive.google.com/file/d/1Rua-SRJLPoV0NLnvwJg-fopsD178KIts/view?usp=sharing |
| BPI-R2 Pro CE,FCC,RoHS certificate : https://banana-pi.org/en/bpi-honor/ |
| Install google play on Bananapi BPI-R2 pro Android 11/12: https://www.youtube.com/watch?v=pMKBVcJhsx4 |
| Note: the network disk include linux-4.19.xx and linux-5.10.66 kernel version, linux-5.10.66 kernel version can support DSA feature. |
All image for BPI-R2 Pro google : https://drive.google.com/drive/folders/1gHNGVL_uq8L4t987k-nzg6MKWDSmDcfC
All image for BPI-R2 Pro : Baidu : https://pan.baidu.com/s/1u5bIp0fMJPre-j0bXGfDWA?pwd=i8q6 Pincode: i8q6
| All Android image can find here: |
Google Drive: https://drive.google.com/drive/folders/1Bs0lhnukZ4A_BmbY-QPiJsFguPXh6imh?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/19_nZls-1tzAsIB3_B-PWrg?pwd=6zw8 (pincode: 6zw8)
| 2023-03-17-Android11-atv-bpi-r2pro.img |
Google Drive: https://drive.google.com/drive/folders/1TZMsaeg99bC8WwxEb8zOMTOAA0TurQ_E?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/1_Hb0dB_4mHhTXiWP6TAzDA?pwd=bdxa (pincode: bdxa)
| 2023-03-17-Android11-bpi-r2pro.img |
Google Drive: https://drive.google.com/drive/folders/108SbohEB8OsWYaxvFeYhGDzxHaUJ1OcW?usp=share_link
Baidu Cloud: https://pan.baidu.com/s/1FKdN2b3qA2Cc4syO15zbng?pwd=rnxd (pincode: rnxd)
| 2022-11-16 release, Android12-bpi-r2pro.img |
Baidu Cloud: https://pan.baidu.com/s/1tQ5Fg47R0fpUajYpNIsJ3g?pwd=8888 (pincode: 8888)
MD5: a7b5faf7818f1ab2d36253a5d3ca1d18
| 2022-06-10 release, Android 11 with kernel 4.19.219, tablet variant image |
Baidu Cloud: https://pan.baidu.com/s/1EUiGaXuPxAkR69g7EOnVaw?pwd=4n6c (pincode: 4n6c)
MD5: ebd336bad0c27c66ae65a4d38103bced
| 2022-06-10 release, Android 11 with kernel 4.19.219, atv variant image |
Baidu Cloud: https://pan.baidu.com/s/1RbNf1dFqMxy1Dx_ysym82w?pwd=v4u8 (pincode: v4u8)
MD5: 49506a8a3183ab189046b5e2e2833b87
| kernel 5.10.66 , support DSA feature, Ubuntu 16.04. Ubuntu 20.04, Ubunutu 22.04. |
Baidu : https://pan.baidu.com/s/19B6AYrHfbIFgRytTpW8Mbg?pwd=6me6 Pincode: 6me6
user/password:bpi/bananapi,root/bananapi
| kernel 5.10.66, support DSA feature, Debian10. |
| 2023-07 Armbian_2023.02.0 for BPI-R2 PRO |
Baidu Cloud: https://pan.baidu.com/s/1Ey02SbYbTjdYpiB1MdgL7A?pwd=8888 (pincode:8888)
| kernel 5.10.66, support DSA feature, OpenWRT |
User/Password: root/123456
| BANANAPI Official Shop: https://www.bpi-shop.com/products/banana-pi-bpi-r2-pro.html |
| Aliexpress shop : https://www.aliexpress.com/item/1005004224551525.html?spm=a2g0o.store_pc_newArrival.8148356.1.2d8330d9Jco2ZH |
| Taobao shop : https://item.taobao.com/item.htm?spm=a2oq0.12575281.0.0.282d1debCwvgH0&ft=t&id=673191560298 |
| BPI-R2 Pro RK3568 OEM&ODM : [email protected] |
