| More Infomation: Banana Pi BPI-CM4 |
Prepare a usb-serial cable, a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download and ADB debug.
Prepare a SDcard at least 8GB for linux development, android only support emmc boot.
The SOC rom first boot media is emmc, so board can’t bootup from SDcard if the emmc is bootable with any image flashed, more info please refer to board boot sequence.
Download and install the AML Usb Burning Tool for android image download via type-c, only support windows.
Download the latest android image, and confirm that the md5 checksum is correct.
Open USB_Burning_Tool.exe, select menu File→Import image, and select android image.
Short the usb boot test point on the main board, plugin type-c usb cable to PC or press the RST button if power adapter already connected, about two seconds later, the board will enter usb download mode and be identified correctly by PC. You can also enter usb download mode with adb command "adb reboot update" or console command "reboot update" if a bootable android already flashed, make sure typec usb connected to PC before doing this.
Click the Start button of the download tool and wait for upgrade complete.
After Burning successfull, Unplug the type-c usb and connect to power supply adaptor to startup.
Click the Stop button to cancel the upgrade process and close the USB Buring Tool.
Aml-flash-tool is a linux platform opensource image flash util for Amlogic android.
Get Android 9.0 source code:
Build the Android 9.0 Source code Please read the source code README.md
Bananapi CM4 DTBO idx value table, default idx value is 0 in release image.
| Bananapi CM4 DTBO idx value table | ||
idx value |
device tree overlay |
description |
0 |
android_p_overlay |
default dtbo, no use |
1 |
wifi_bt_rtl8822cs |
enable bpi rtl8822cs wifi/bt module |
2 |
i2c1 |
enable i2c 1 |
3 |
i2c2 |
enable i2c 2 |
4 |
sdio |
enable sdio |
5 |
uart1 |
enable 2 pins uart 1 |
6 |
uart1_cts_rts |
enable 4 pins uart 1 |
7 |
uart2 |
enable 2 pins uart 2 |
8 |
hifi_pcm5122 |
enable i2s pcm5122 HiFi DAC |
How to apply a new dtbo
ADB command via sysfs
restarting adbd as root
remount succeeded
bananapi_m2s:/ # reboot
Uart console command via sysfs
console:/ $
console:/ $ su
[ 115.702781@0] unifykey: name_store() 1302, name dtbo, 4
[ 115.702856@0] unifykey: name_store() 1311
console:/ #
[ 129.262659@0] unifykey: write_store() is a string
[ 129.262733@0] unifykey: dtbo, 1, 1
[ 129.265312@0] unifykey: amlkey_write 393
[ 129.292347@1] emmc_key_write:149, write ok
console:/ #
console:/ # reboot
Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Default build-in overlays are defined in device/bananapi/bananapi_m2s/Kernel.mk, you can add a new overlay dtbo here.
Default apply DTBO idx is defined in device/bananapi/bananapi_m2s/BoardConfig.mk, you can change the idx value to set which overlay dtbo will be applied default.
DTS files are in common/arch/arm64/boot/dts/amlogic/overlay/bananapi_m2s/
Download install package from OpenGapps, Android release image is arm/android 9.0 variant.
Download device_id.apk.
Copy the OpenGapp package to a udisk or sdcard root directory.
Create a txt file named factory_update_param.aml in udisk or sdcard root directory with the following android recovery parameter content, and replace the file name with the actual downloaded package.
udisk:
--wipe_cache
sdcard:
--wipe_cache
Plugin the udisk or sdcard to the board and poweron.
OpenGapps install and certify.
YouTube : https://youtu.be/fXOKmWfpqF8
The default android release image only support one mipi panel because hw has no detect logic for different panel at boot, so [800x1280 bpi panel] enabled as default, but you can change to [1200x1920 bpi panel] as defualt in Settings→Panel Output
UI Rotation in Settings→Display→Screen rotation
SurfaceFlinger rotation, need modify android source code and build
index 1f51703..d592a44 100644
else
ro.sf.lcd_density=213 \
endif
index 4a698b0..3d41b63 100755
@@ -876,8 +876,8 @@
reg = <0x5d>;
Compress the bmp file to boot-logo.bmp.gz
Download m2s_android_bootlogo_tool.zip
Extract this tool
$ ls -l logo/
Copy the boot-logo.bmp.gz
Create target logo.img with img pack tool, the binary and related libs of m2s_android_bootlogo_tool are copy from <android-source-dir>/out/host/linux-x86
. Flash boot logo with fastboot
$ adb root
$ adb remount
$ adb reboot fastboot
$ fastboot device
1234567890 fastboot
$ fastboot reboot
Linux image support SDcard or EMMC bootup.
It’s recommended to use A1 rated cards, 8GB at least.
Make sure bootable EMMC is formatted if you want bootup from SDcard
Make sure SDcard is formatted without Linux image flashed if you want bootup from EMMC and use Sdcard as storage.
Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can’t access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
$ apt-get install pv
Download Linux latest Linux Image, and confirm that the md5 checksum is correct.
Default login: pi/bananapi or root/bananapi
Install Image with Balena Etcher on Windows, Linux and MacOS.
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
Install Image with Balena Cli on Windows, Linux and MacOS.
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2 --yes
Install Image with dd command on Linux
Mount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
$ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
Install image with bpi-tools on Linux
Plug SDcard to Linux PC and run
$ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/sdX
Prepare a SDcard with Linux image flashed and bootup board with this SDcard.
Copy Linux image to udisk, plug the udisk to board and mount it.
There are two ways to install the linux image to board.
Install with dd command, umount mmcblk0p1 and mmcblk0p2 partition if mounted automatically. Actually bpi-copy is the same as this dd command.
$ sudo unzip -p xxx-bpi-cm4-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
Install the linux image in udisk with bpi-tools command
$ sudo bpi-copy xxx-bpi-cm4-xxx.img.zip /dev/mmcblk0
After download complete, power off safely and eject the SDcard.
Get the Linux bsp source code
Build the bsp source code
If you want build uboot and kernel separately, please download the u-boot the kernel only, get the toolchains, boot script and other configuration files from BPI-M2S-bsp
DTB overlay is used for 40pin gpios multi-function configuration and install in vfat boot partition, you can check the mount point with mount command.
custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo
ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo
hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo
hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo
i2c1.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo
i2c2.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo
pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
Update the overlays env in vfat /boot/env.txt to enable what you want.
# Device Tree Overlays
# uart1 -- Enable UART1 (uart_A, GPIO Header PIN8 & PIN10)
# pwm_c -- Enable PWM_C (GPIO Header PIN7)
# i2c2 -- Enable i2c2 (GPIO Header PIN3 & PIN5)
# spi0 -- Enable SPI0 (GPIO Header PIN19 & PIN21 & PIN23 & PIN24)
overlays="i2c2 spi0 uart1"
Must be restart the board for overlay dtb loaded.
The linux release image is camera disabled default, according to the following configuration, it can be enabled by yourself.
Update the dtb overlays env in /boot/env.txt to enable camera dtbo.
overlays="os08a10"
Add camera modules to /etc/modules
iv009_isp_iq
iv009_isp_lens
iv009_isp_sensor
iv009_isp
Create and add camera modules options to /etc/modprobe.d/os08a10.conf
#choose isp register sequence
Enable camera isp systemd service
# Mipi panel type
# Symbol | Resolution
# "lcd_0" | 10" 800x1280 panel
# "lcd_1" | 10" 1200x1920 panel
panel_type=lcd_0
| Note: Dual display is not work on linux, so disconnect hdmi cable when mipi used. |
Section "Device"
# Rotate off
# Option "Rotate" "off"
Option "Rotate" "CW"
# Option "Rotate" "UD"
# Option "Rotate" "CCW"
EndSection
Section "InputClass"
MatchIsTouchscreen "on"
MatchProduct "goodix-ts"
MatchDriver "libinput"
EndSection
Sysfs dynamically change.
echo 0 > /sys/class/graphics/fbcon/rotate //origin 0 degree
echo 1 > /sys/class/graphics/fbcon/rotate //90 degree
echo 2 > /sys/class/graphics/fbcon/rotate //180 degree
echo 3 > /sys/class/graphics/fbcon/rotate //270 degree
Boot Configuration change.
# Framebuffer Rotate
# 0 - origin 0 degree
# 1 - 90 degree
# 2 - 180 degree
# 3 - 270 degree
fb_rotate=0
| Note: This WiringPi only support set 26pin gpio to output, input, pwm or software pwm, for io functions as i2c, spi, …, you must enable dtb overlay in boot.ini |
Build and install wiringPi, for debian, you must install sudo before build
$ sudo apt-get update
$ cd amlogic-wiringPi
$ chmod a+x build
$ sudo ./build
Run gpio readall to show all 40pins status.
BPI GPIO Extend board and examples in amlogic-wiringPi/examples
$ sudo apt-get install build-essential python python-dev python-setuptools git
$ cd RPi.GPIO-Amlogic
$ sudo apt-get install build-essential python python-dev python-setuptools swig git
$ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git
$ cd WiringPi2-Python-Amlogic
copy the target file to /boot/firmware/ or /boot/ directory.
AT test
After the module is connected and Linux OS bootup. several ttyUSB* device files are created in the directory /dev. For EC20, /dev/ttyUSB2 is the AT port.
Connect Network via qmi_wwan on Ubuntu Desktop
Click edit connections in network manager menu
Add a new mobile broadband connection
Choose qmi channel device
When the qmi_wwan_q driver has been installed in the module, a network device and a QMI channel are created. The network device is named as wwanX and the QMI channel is /dev/cdc-wdmX. The network device is used for data transmission, and QMI channel is used for QMI message interaction
Choose carrier provider’s country region
Choose carrier provider.
Set connection name, carrier connection username/password and APN if needed.
Setup finished, now you can connect it.
Connect Network via pppd on Ubuntu&Debian Server
Install pppd
$ sudo apt install ipppd
Change AT device, username and password to your local carrier in /etc/ppp/peers/quectel-ppp
Change APN to your local carrier in /etc/ppp/peers/quectel-chat-connect
Two ways command to start pppd, you can check the process of PPP calling setup log here.
# pppd call quectel-ppp &
or
Terminate pppd process:
# quectel-ppp-kill
Connect Network via qmi_wwan on Ubuntu&Debian Server [quectel-CM] is a connection manager program for you to set up data connection manually. You can check the process of qmi_wwan calling setup log here.
# quectel-CM &
Terminate quectel-CM process:
# killall quectel-CM
A311d soc rom and BPI-M2S-bsp uboot are both not support nvme boot, so the only way for booting linux from SSD is create a bootable sdcard or emmc with bootloader and boot partition flashed, then load rootfs from SSD. After bootup, everything will run from SSD. You need a minipcie to nvme adapter board because bananapi cm4io has a minipcie slot onboard.
The simple way is flash the CM4 Linux image to sdcard or emmc for bootable and also flash it to the nvme ssd for loading rootfs.
Bootup the CM4 board with sdcard or emmc, modify /boot/boot.ini to load rootfs from nvme partition for kernel.
diff a/boot/boot.ini b/boot/boot.ini
index 2222e79..c485067 100755
--- a/boot/boot.ini
+++ b/boot/boot.ini
@@ -20,6 +20,8 @@ fi;
# Load env.txt
Reboot the system, kernel will load rootfs from nvme ssd.
Test performance You can verify the performance of your SSD on Pi Benchmarks using the following command:
Test results for sd, emmc and nvme ssd (Samsung 970EVOPlus)
| Category | Test | Sdcard Test Result | Emmc Test Result | Nvme SSD Test Result |
HDParm |
Disk Read |
60.67 MB/s |
148.80 MB/s |
351.29 MB/s |
HDParm |
Cached Disk Read |
56.71 MB/s |
141.02 MB/s |
347.03 MB/s |
DD |
Disk Write |
14 MB/s |
51.0 MB/s |
244 MB/s |
FIO |
4k random read |
2176 IOPS (8704 KB/s) |
8438 IOPS (33753 KB/s) |
101386 IOPS (405544 KB/s) |
FIO |
4k random write |
932 IOPS (3729 KB/s) |
10876 IOPS (43505 KB/s) |
43206 IOPS (172827 KB/s) |
IOZone |
4k read |
8586 KB/s |
20311 KB/s |
119475 KB/s |
IOZone |
4k write |
2385 KB/s |
19016 KB/s |
90619 KB/s |
IOZone |
4k random read |
6734 KB/s |
20807 KB/s |
51517 KB/s |
IOZone |
4k random write |
3737 KB/s |
22731 KB/s |
95139 KB/s |
Score: 1076 |
Score: 5446 |
Score: 24550 |
Add disableuhs option to kernel bootargs in /boot/env.txt to disable sdcard uhs capability
# User kernel args
# Add customer kernel args here
user_kernel_args=pci=pcie_bus_safe disableuhs
CM4 has onboard wifi/bt RTL8822CS, and is not enabled in default image, you can enable it with the following procedure.
Add the wifi module name to /etc/modules for loaded automatically next boot.
88x2cs
Install bluetooth packages for server images
$ sudo apt update
$ sudo apt install bluez rfkill
Reboot system
Linux Wifi STA mode
network:
version: 2
renderer: networkd
wifis:
wlan0:
dhcp4: true
access-points:
"bananapi":
password: "123456789"
Linux Wifi AP mode
Prepare the setup the wifi adater correctly.
Get the wifi adapter Band, Frequencies, Channel, HT Capability, VHT Capability or other properties $ iw list
Manage wifi access point mode with Netplan and Network-Manager. Install NetworkManager because ap is only supported with NetworkManager renderer
network:
version: 2
renderer: NetworkManager
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 2.4GHz
channel: 6
auth:
key-management: psk
network:
version: 2
wifis:
wlan0:
dhcp4: no
access-points:
"bananapi":
mode: ap
band: 5GHz
channel: 36
auth:
key-management: psk
Manage wifi access point mode with Netplan and Hostapd.
Create a netplan configuration file, 01-wlan0-ap-hostapd.yaml
network:
version: 2
renderer: networkd
ethernets:
wlan0:
dhcp4: no
addresses:
- 192.168.11.1/24
Install hostapd
$ sudo apt install hostapd
interface=wlan0
ssid=bananapi
driver=nl80211
auth_algs=1
wpa=2
wpa_passphrase=123456789
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
#bridge=br0
beacon_int=500
#SSID not hidden
ignore_broadcast_ssid=0
hw_mode=a
channel=36
max_num_sta=8
### IEEE 802.11n
ieee80211n=1
#require_vht=0
### IEEE 802.11ac
ieee80211ac=1
#require_vht=0
#vht_oper_chwidth=1
### WMM
wmm_enabled=1
To support 80MHz channel width you need load driver with rtw_vht_enable=2 option, Or you can create /etc/modprobe.d/8822cs.conf with content
Install and configure dhcp server service, use isc-dhcp-server for example
# Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACESv4="wlan0"
option routers 192.168.11.1;
Start Service
Routing configuration.
sysctl net.ipv4.ip_forward=1
Rom load bootloader from SDcard (Linux log example)
BL2 Built : 15:21:42, Mar 26 2020. g12a g486bc38 - gongwei.chen@droid11-sz
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
Use GP1_pll as DSU clk.
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 1
fw parse done
PIEI prepare done
fastboot data verify
result: 255
DDR4 probe
Rom load bootloader from EMMC(Android Log example)
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 1
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
ddr saved addr:00016000
00000000
Bootable EMMC with Android image flashed
Using usb burning tool, unplug the type-c usb cable while the download process at 7% formatting
Using Android Fastboot tool, make sure the adb/fastboot tools is work on your PC before doing this.
remount succeeded
1234567890 fastboot
OKAY [ 0.044s]
finished. total time: 0.044s
OKAY [ 0.047s]
finished. total time: 0.047s
erasing 'bootloader'...
OKAY [ 0.059s]
finished. total time: 0.059s
erasing 'bootloader-boot0'...
OKAY [ 0.036s]
finished. total time: 0.036s
erasing 'bootloader-boot1'...
OKAY [ 0.035s]
finished. total time: 0.035s
Using uboot command, connect a debug console cable and press ESC while power on to enter uboot command line
start = 0,end = 57343
start = 221184,end = 30535679
start = 0,end = 8191
bananapi_m2s_v1#reset
resetting ...
These two ways actually erase the bootloader part of EMMC android, After bootup from SDcard Linux, You’d better format the whole EMMC by dd command.
The simplest way is insert the SDcard with Linux image flashed before power on, the Android bootloader will check boot.ini file whether exist in SDcard vfat partition, so that the SDcard Linux will bootup. After bootup, you can format the whole EMMC by dd command and then flash the Linux image to EMMC.
BPI: try boot from sdcard
reading boot.ini
Starting boot.ini...
reading env.txt
HDMI: Autodetect: 1080p60hz
reading Image.gz
reading bananapi_m2s.dtb
reading uInitrd
Bootable EMMC with Linux image flashed
Linux u-boot also check boot.ini file whether exist in SDcard vfat partition so that the SDcard Linux will bootup. After bootup, you can format the whole EMMC by dd command or flash the Linux image directly to EMMC.
A extreme situation is bootloader or uboot corrupted, Rom load it from EMMC but hangup in u-boot or BL2, for example the boot process will hangup in BL2 of EMMC if dram init failed, The only way is format the EMMC with usb burning tool, or download the Android image completely and then try other ways to erase EMMC or flash Linux image to EMMC.
Rom will try to load bootloader from SDcard directly if EMMC is empty. Erase Emmc Android by dd command If the board is flashed android before, the whole emmc must be erased by these commands if you want bootup it with SDcard Linux image.
$ sync
$ sync
disable or remove cloud-init
or
$ sudo apt purge cloud-init
disable or remove snap
$ sudo apt purge snapd
[Unit]
After=network.target
[Service]
Type=forking
ExecStart=/etc/rc.local start
TimeoutSec=0
RemainAfterExit=yes
GuessMainPID=no
[Install]
WantedBy=multi-user.target
Alias=rc-local.service
Create /etc/rc.local file.
sudo nano /etc/rc.local
#!/bin/sh
# rc.local
# value on error.
# bits.
exit 0
$ sudo chmod +x /etc/rc.local
$ sudo reboot
$ su root
Password:(enter bananapi)
# apt-get update
# apt-get install sudo
# adduser pi sudo
Set up the repository
Set up the stable repository
$ echo \
Verify the Docker Engine is installed correctly by running the hello-world image.
$ sudo docker run hello-world
